How To Upgrade
DrGerm
Post Sun Jul 22, 2012 5:51 pm
How To Upgrade
Sorry, this is probably a stupid question, but I'm getting an error when trying to search this forum, a potentially relevant FAQ is "coming soon" (http://serviiowhs.codeplex.com/wikipage ... umentation), and I don't see anything in the Wiki (http://wiki.serviio.org/doku.php) for this question.
I have Serviio add-in (v0.6.1.0) for Windows Home Server v1 installed and Serviio Media Server v0.6.1 installed on that server.
When I remote desktop to my server, there is a message regarding a new version being available (currently v0.6.2).
Apparently the WHS Addin does not automatically upgrade the software on the server. What would be the process to upgrade? i.e. is it necessary to uninstall old versions (through Control Panel -> Add or Remove Programs) or can/do you just run the install file over the old version?
Post Sun Jul 22, 2012 6:03 pm
Re: How To Upgrade
Just install 0.6.2 over 0.6.1. If you do want to remove it first (which isn't needed), make a backup of the under C:\Program Files\Serviio\library
DrGerm
Post Sun Jul 22, 2012 8:36 pm
Re: How To Upgrade
will wrote:Just install 0.6.2 over 0.6.1. If you do want to remove it first (which isn't needed), make a backup of the under C:\Program Files\Serviio\library
Thank you :)
Users browsing this forum: Baidu [Spider] and 25 guests
