Help with Personal RSS folders
dcolhoun
Post Tue Jul 24, 2012 3:59 am
Hi
I have followed instructions by jhb50 to create a personal rss folder on sites.google.com and have added it to the online library in the Serviio console.
RSS file is here https://sites.google.com/site/dcgermant ... rmantv.rss.
But when i go to Online-> GermanTV all I get is there are no titles here. The log shows nothing.
I have tested other rss folders created by other forum members and they work ok.
Does anyone have any pointers as I may be missing something obvious?
grolschie
Post Tue Jul 24, 2012 9:15 am
Re: Help with Personal RSS folders
Does your URL have "?attredirects=0" at the end? If so, you should remove anything after the ".rss".
I don't have type="video" in my .rss files.
Also, I tried one of your URLs and it wasn't valid (for me - geoblocked?):
C:\Program Files\Serviio\lib>ffmpeg.exe -i "rtmp://cp108475.live.edgefcs.net/liv
e/ swfUrl=http://www.wilmaa.com/player/main_v3.176.swf pageUrl=http://www.wilmaa
.com/ playpath=3sat_1_800@45493"
g-config
HandleCtrl: Ignoring SWFVerification request, use --swfVfy!
Closing connection: NetStream.Play.StreamNotFound
rtmp://cp108475.live.edgefcs.net/live/ swfUrl=http://www.wilmaa.com/player/main_
v3.176.swf pageUrl=http://www.wilmaa.com/ playpath=3sat_1_800@45493: Unknown err
or occurred
dcolhoun
Post Tue Jul 24, 2012 11:00 am
Hi grolschie
How do you remove "?attredirects=0 - - this only appears in the URL if you copy the download link.
I am not that concerned at the moment whether the actual feeds work :) just want them to appear.
It was your GreekTV feed that I used to test and that works fine
If you access https://sites.google.com/site/dcgermant ... rmantv.rss the rss file can be accessed.
Any idea if the plugin has specific naming conventions it is looking for?
Post Tue Jul 24, 2012 11:34 am
I am not that concerned at the moment whether the actual feeds work just want them to appear.
Entries are tested by Serviio and will only appear if they are valid. The log will show if yours were all rejected.
dcolhoun
Post Tue Jul 24, 2012 12:55 pm
Ah so I am doing this arse about face!
Thanks - will get a working feed then test from there
grolschie
Post Tue Jul 24, 2012 7:59 pm
dcolhoun wrote:Hi grolschie
Simply remove those characters from URL when you paste it into Serviio, so that it says:
https://sites.google.com/site/dcgermantv/LiveFeeds_germantv.rss
instead of:
https://sites.google.com/site/dcgermantv/LiveFeeds_germantv.rss?attredirects=0
It's best to test your streams from the commandline first e.g.
dcolhoun
Post Wed Jul 25, 2012 2:30 am
Hi
I did remove the extra characters before adding to Serviio.
I will definitely test prior to adding the feed - thanks
grolschie
Post Wed Jul 25, 2012 8:35 pm
No problem. All the best.
Users browsing this forum: Google [Bot] and 19 guests
