Serviio 1.0, Windows 8 RP and Samsung TV D8000
cobbly
Post Wed Jul 25, 2012 8:02 am
Hi All
Now I know windows 8 is pre release software and therefore doesn't have to be supported but I was hoping someone may be able to help me anyway.
Basically, serviio is installed and running fine. My TV detects serviio however when it try to go to it it sits on "Loading..." for about half an hour before eventually timing out.
I have a DLNA app on my phone and that is able to access serviio fine, and I am even able to use this app to select the files I want to play and send them to the TV and they play fine (i have been using this as a workaround).
This was also a problem with previous versions of serviio so it's not a 1.0 problem.
I am fairly confident it is not my router because it works fine on my phone and also worked fine when i was using windows 7, and no settings on the router have changed.
The obvious answer is that windows 8 is the issue, but then I don't understand why it would work with my phone.
Does anyone have any ideas as to what could be wrong here?
Post Wed Jul 25, 2012 9:51 pm
Re: Serviio 1.0, Windows 8 RP and Samsung TV D8000
turn on detailed logging and try to browse serviio from the TV. Send the bit of log when it makes the requests when it says Loading... and just before.
cobbly
Post Thu Jul 26, 2012 7:51 am
Log file:
2012-07-26 17:46:46,380 DEBUG [RendererManager] Adding renderer Renderer [uuid=d54a22a6-83f9-3472-bc9c-c91d1e102388, ipAddress=192.168.0.5, name=UA55D8000, profileId=7, manuallyAdded=false, forcedProfile=true, enabled=true, accessGroupId=1] to list of active renderers
2012-07-26 17:46:46,995 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.5:1025
2012-07-26 17:46:46,995 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:46,997 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-ce-org:device:RemoteUIServerDevice:1 from address /192.168.0.5:1026
2012-07-26 17:46:46,997 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:46,997 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.5:1025
2012-07-26 17:46:46,999 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:RemoteUIServerDevice:1 from address /192.168.0.5:1027
2012-07-26 17:46:46,999 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:47,387 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.5:1025
2012-07-26 17:46:47,387 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:47,388 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.5:1025
2012-07-26 17:46:47,389 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-ce-org:device:RemoteUIServerDevice:1 from address /192.168.0.5:1026
2012-07-26 17:46:47,389 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:47,391 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:RemoteUIServerDevice:1 from address /192.168.0.5:1027
2012-07-26 17:46:47,391 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:47,592 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.5:1025
2012-07-26 17:46:47,592 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:47,592 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.5:1025
2012-07-26 17:46:47,593 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-ce-org:device:RemoteUIServerDevice:1 from address /192.168.0.5:1026
2012-07-26 17:46:47,594 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:47,596 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:RemoteUIServerDevice:1 from address /192.168.0.5:1027
2012-07-26 17:46:47,596 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:48,694 DEBUG [WebServer] Incoming connection from /192.168.0.5:39304
2012-07-26 17:46:48,696 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:48,697 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c5db91ac-54f5-3daa-b7ba-6fea634c26b1 from 192.168.0.5 (headers = [HOST: 192.168.0.3:8895,USER-AGENT: SEC_HHP_[TV]UA55D8000/1.0,ACCEPT-LANGUAGE: en-us])
2012-07-26 17:46:48,697 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:48,697 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.3:8895,USER-AGENT: SEC_HHP_[TV]UA55D8000/1.0,ACCEPT-LANGUAGE: en-us]
2012-07-26 17:46:48,698 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:48,869 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV / player (C/D/E-series)'
2012-07-26 17:46:53,327 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.5:1029
2012-07-26 17:46:53,327 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:53,328 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.5:1029
2012-07-26 17:46:53,332 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-ce-org:device:RemoteUIServerDevice:1 from address /192.168.0.5:1028
2012-07-26 17:46:53,332 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:53,334 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:RemoteUIServerDevice:1 from address /192.168.0.5:1030
2012-07-26 17:46:53,334 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:53,743 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.5:1029
2012-07-26 17:46:53,743 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:53,744 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.5:1029
2012-07-26 17:46:53,745 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-ce-org:device:RemoteUIServerDevice:1 from address /192.168.0.5:1028
2012-07-26 17:46:53,745 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:53,747 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:RemoteUIServerDevice:1 from address /192.168.0.5:1030
2012-07-26 17:46:53,747 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:53,942 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.5:1029
2012-07-26 17:46:53,942 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:53,942 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.5:1029
2012-07-26 17:46:53,943 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-ce-org:device:RemoteUIServerDevice:1 from address /192.168.0.5:1028
2012-07-26 17:46:53,944 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:53,946 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:RemoteUIServerDevice:1 from address /192.168.0.5:1030
2012-07-26 17:46:53,946 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:57,703 DEBUG [WebServer] Incoming connection from /192.168.0.5:35092
2012-07-26 17:46:57,704 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:46:57,704 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2012-07-26 17:47:01,979 DEBUG [WebServer] Incoming connection from /192.168.0.5:49835
2012-07-26 17:47:01,980 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:47:01,981 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.0.5:
2012-07-26 17:47:01,981 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:47:02,036 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-26 17:47:02,042 DEBUG [WebServer] Incoming connection from /192.168.0.5:52769
2012-07-26 17:47:02,043 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:47:02,043 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.0.5:
2012-07-26 17:47:02,048 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-26 17:47:02,060 DEBUG [WebServer] Incoming connection from /192.168.0.5:42870
2012-07-26 17:47:02,060 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:47:02,061 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.0.5:
2012-07-26 17:47:02,061 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:47:02,065 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-26 17:47:02,076 DEBUG [WebServer] Incoming connection from /192.168.0.5:39214
2012-07-26 17:47:02,077 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:47:02,077 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-07-26 17:47:02,197 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-07-26 17:47:02,197 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-07-26 17:47:02,208 DEBUG [RepositoryDAOImpl] Retrieving list of Repositories for VIDEO (from=0, count=1) [No_Restriction]
2012-07-26 17:47:02,243 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [No_Restriction]
2012-07-26 17:47:02,393 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-07-26 17:47:02,411 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-26 17:47:02,418 DEBUG [WebServer] Incoming connection from /192.168.0.5:36674
2012-07-26 17:47:02,418 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:47:02,419 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-07-26 17:47:02,419 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:47:02,422 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 30, sortCriteria =
2012-07-26 17:47:02,423 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-07-26 17:47:02,424 DEBUG [RepositoryDAOImpl] Retrieving list of Repositories for VIDEO (from=0, count=30) [No_Restriction]
2012-07-26 17:47:02,437 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [No_Restriction]
2012-07-26 17:47:02,468 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [No_Restriction]
2012-07-26 17:47:02,531 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [No_Restriction]
2012-07-26 17:47:02,592 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [No_Restriction]
2012-07-26 17:47:02,636 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-07-26 17:47:02,645 DEBUG [VideoDAOImpl] Retrieving number of 10 last viewed videos [No_Restriction]
2012-07-26 17:47:02,736 DEBUG [VideoDAOImpl] Retrieving number of 10 last added videos
2012-07-26 17:47:02,736 DEBUG [VideoDAOImpl] Retrieving number of videos of type 0 [No_Restriction]
2012-07-26 17:47:02,856 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-07-26 17:47:02,874 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-07-26 17:47:02,886 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-07-26 17:47:02,886 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-07-26 17:47:02,892 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-26 17:47:02,898 DEBUG [WebServer] Incoming connection from /192.168.0.5:56181
2012-07-26 17:47:02,924 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-07-26 17:47:02,924 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-07-26 17:47:02,928 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 6, count = 30, sortCriteria =
2012-07-26 17:47:02,928 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-07-26 17:47:02,929 DEBUG [RepositoryDAOImpl] Retrieving list of Repositories for VIDEO (from=6, count=30) [No_Restriction]
2012-07-26 17:47:02,941 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-07-26 17:47:02,942 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-07-26 17:47:02,943 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-07-26 17:47:02,943 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-07-26 17:47:02,946 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-26 17:47:02,956 DEBUG [WebServer] Incoming connection from /192.168.0.5:49901
It seems to keep repeating itself after that, let me know if you need more.
Appreciate your help.
Post Thu Jul 26, 2012 10:35 am
Thanks, do you have any special settings on your Presentation tab or do you have everything set to Enabled? Did you try to upgrade the firmware of your TV?
cobbly
Post Thu Jul 26, 2012 10:59 am
In Presentation settings I have:
Video -- Display category
- Folders -- Display content only
- Last Viewed -- Display category
- Last Added -- Display category
- Online -- Display content only
Everything else is disabled.
TV firmware is up to date.
jlcooke
Post Thu Jul 26, 2012 12:43 pm
My samsung TV works with serviio-0.6.2 but not 1.0. TV model: UN55ES6100
My tv's firmware is uptodate and 8player on my iphone can browse serviio-1.0 just fine. yes I've told 1.0 that my device is a samsung c/d/e model TV.
Would you also like my DEBUG log for when the TV talks to serviio-1.0?
Post Thu Jul 26, 2012 3:15 pm
cobbly wrote:In Presentation settings I have:
Just to confirm, can you set everything to Enabled and see if you still experience this?
EDIT: also, are all your media added or is it still in the middle of updating after 1.0 update?
cobbly
Post Fri Jul 27, 2012 8:06 am
Omg I cannot believe it was that simple. I set everything to 'Display category' and now it works.
Thank you!! :D
Post Fri Jul 27, 2012 1:01 pm
well it looks like a bug .... can you send me PM with list of your Online sources, I'll try to recreate this on my machine
cobbly
Post Sat Jul 28, 2012 2:29 am
I don't have any online source's (hadn't got around to adding them in yet)
Which is probably the issue...
Went back to my old settings but with one change, set online to 'display category' instead of 'display content only', now it's working fine.
Post Sat Jul 28, 2012 6:24 pm
Can you try with just Online resources set to Show contents only. I'll need something I can easily reproduce, ie just online if possible.
cobbly
Post Sat Jul 28, 2012 10:23 pm
Do you mean have everything else disabled?
Post Sat Jul 28, 2012 10:57 pm
yes.
cobbly
Post Sun Jul 29, 2012 1:31 am
Well Online on "display content only" and everything else disabled seems to work too.
It says no videos available but that's to be expected, and it doesn't do the loading forever thing.
So I guess its a combination of them then...
I've done some testing....
Online: Display content only
Everything else: Disabled
Result: Works
Folders: Display content only
Result: Works
Online: Display category
Result: Works
Folders: Display category
Result: Doesn't Work
Last Viewed: Display content only
Last Viewed: Display category
Result: Works
So, it seems that Online being Display content only while anything else is enabled results in the loading issue.
Hope this helps, let me know if you need anything else.
Post Sun Jul 29, 2012 7:40 pm
Great,
so with this:
Can you capture detailed log of browsing to the Loading screen?
cobbly
Post Wed Aug 01, 2012 10:24 am
Log:
2012-08-01 20:16:02,577 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net4 (NETGEAR WNDA3100v2 N600 Wireless Dual Band USB Adapter) and address 192.168.0.3, timeout = 0
2012-08-01 20:16:02,578 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c5db91ac-54f5-3daa-b7ba-6fea634c26b1
2012-08-01 20:16:03,205 DEBUG [WebServer] Incoming connection from /192.168.0.5:47661
2012-08-01 20:16:03,206 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:03,215 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c5db91ac-54f5-3daa-b7ba-6fea634c26b1 from 192.168.0.5 (headers = [HOST: 192.168.0.3:8895,USER-AGENT: SEC_HHP_[TV]UA55D8000/1.0,ACCEPT-LANGUAGE: en-us])
2012-08-01 20:16:03,215 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:03,215 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.3:8895,USER-AGENT: SEC_HHP_[TV]UA55D8000/1.0,ACCEPT-LANGUAGE: en-us]
2012-08-01 20:16:03,216 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:03,285 DEBUG [WebServer] Incoming connection from /192.168.0.5:52117
2012-08-01 20:16:03,285 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:03,286 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c5db91ac-54f5-3daa-b7ba-6fea634c26b1 from 192.168.0.5 (headers = [HOST: 192.168.0.3:8895,USER-AGENT: SEC_HHP_[TV]UA55D8000/1.0,ACCEPT-LANGUAGE: en-us])
2012-08-01 20:16:03,286 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:03,287 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.3:8895,USER-AGENT: SEC_HHP_[TV]UA55D8000/1.0,ACCEPT-LANGUAGE: en-us]
2012-08-01 20:16:03,287 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:03,390 DEBUG [WebServer] Incoming connection from /192.168.0.5:41863
2012-08-01 20:16:03,391 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:03,391 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c5db91ac-54f5-3daa-b7ba-6fea634c26b1 from 192.168.0.5 (headers = [HOST: 192.168.0.3:8895,USER-AGENT: SEC_HHP_[TV]UA55D8000/1.0,ACCEPT-LANGUAGE: en-us])
2012-08-01 20:16:03,392 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:03,392 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.3:8895,USER-AGENT: SEC_HHP_[TV]UA55D8000/1.0,ACCEPT-LANGUAGE: en-us]
2012-08-01 20:16:03,480 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV / player (C/D/E-series)'
2012-08-01 20:16:03,603 DEBUG [WebServer] Incoming connection from /192.168.0.5:42481
2012-08-01 20:16:03,603 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:03,604 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2012-08-01 20:16:03,725 DEBUG [WebServer] Incoming connection from /192.168.0.5:42482
2012-08-01 20:16:03,726 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:03,726 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2012-08-01 20:16:04,379 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:50
2012-08-01 20:16:08,981 DEBUG [WebServer] Incoming connection from /192.168.0.5:47051
2012-08-01 20:16:08,983 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:08,983 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.0.5:
2012-08-01 20:16:09,193 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,200 DEBUG [WebServer] Incoming connection from /192.168.0.5:33986
2012-08-01 20:16:09,200 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,201 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.0.5:
2012-08-01 20:16:09,201 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,206 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,211 DEBUG [WebServer] Incoming connection from /192.168.0.5:37820
2012-08-01 20:16:09,211 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,211 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.0.5:
2012-08-01 20:16:09,216 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,251 DEBUG [WebServer] Incoming connection from /192.168.0.5:56370
2012-08-01 20:16:09,251 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,251 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,260 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-01 20:16:09,260 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,284 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,317 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,336 DEBUG [WebServer] Incoming connection from /192.168.0.5:45196
2012-08-01 20:16:09,336 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,337 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,337 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,341 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 30, sortCriteria =
2012-08-01 20:16:09,342 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,343 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,367 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,459 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,597 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,597 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,601 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,608 DEBUG [WebServer] Incoming connection from /192.168.0.5:40487
2012-08-01 20:16:09,609 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,609 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,613 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 30, sortCriteria =
2012-08-01 20:16:09,613 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,615 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,615 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,616 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,616 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,619 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,626 DEBUG [WebServer] Incoming connection from /192.168.0.5:43444
2012-08-01 20:16:09,627 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,627 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,631 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-01 20:16:09,632 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,632 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,638 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,646 DEBUG [WebServer] Incoming connection from /192.168.0.5:47419
2012-08-01 20:16:09,646 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,646 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,650 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 30, sortCriteria =
2012-08-01 20:16:09,650 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,652 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,653 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,653 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,656 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,663 DEBUG [WebServer] Incoming connection from /192.168.0.5:40470
2012-08-01 20:16:09,663 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,663 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,667 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-01 20:16:09,667 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,668 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,673 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,680 DEBUG [WebServer] Incoming connection from /192.168.0.5:35610
2012-08-01 20:16:09,680 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,681 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,681 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,685 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 30, sortCriteria =
2012-08-01 20:16:09,685 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,687 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,687 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,690 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,702 DEBUG [WebServer] Incoming connection from /192.168.0.5:41927
2012-08-01 20:16:09,703 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,703 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,708 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-01 20:16:09,708 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,708 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,713 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,720 DEBUG [WebServer] Incoming connection from /192.168.0.5:47932
2012-08-01 20:16:09,720 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,721 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,721 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,725 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 30, sortCriteria =
2012-08-01 20:16:09,726 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,727 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,727 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,728 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,728 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,730 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,736 DEBUG [WebServer] Incoming connection from /192.168.0.5:42750
2012-08-01 20:16:09,737 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,737 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,741 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-01 20:16:09,741 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,742 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,747 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,752 DEBUG [WebServer] Incoming connection from /192.168.0.5:33293
2012-08-01 20:16:09,755 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,755 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,759 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 30, sortCriteria =
2012-08-01 20:16:09,759 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,761 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,761 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,762 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,765 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,774 DEBUG [WebServer] Incoming connection from /192.168.0.5:42597
2012-08-01 20:16:09,774 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,775 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,775 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,779 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-01 20:16:09,779 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,779 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,784 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,791 DEBUG [WebServer] Incoming connection from /192.168.0.5:52971
2012-08-01 20:16:09,791 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,792 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,792 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,795 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 30, sortCriteria =
2012-08-01 20:16:09,795 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,797 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,797 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,800 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,807 DEBUG [WebServer] Incoming connection from /192.168.0.5:38022
2012-08-01 20:16:09,807 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,807 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,811 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-01 20:16:09,811 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,812 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,817 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,827 DEBUG [WebServer] Incoming connection from /192.168.0.5:32771
2012-08-01 20:16:09,828 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,829 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,829 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,833 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 30, sortCriteria =
2012-08-01 20:16:09,833 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,834 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,834 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,835 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,835 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,838 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,847 DEBUG [WebServer] Incoming connection from /192.168.0.5:44347
2012-08-01 20:16:09,850 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,850 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,855 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-01 20:16:09,855 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,856 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,860 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,866 DEBUG [WebServer] Incoming connection from /192.168.0.5:51052
2012-08-01 20:16:09,867 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,867 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,871 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 30, sortCriteria =
2012-08-01 20:16:09,871 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,872 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,872 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,875 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,884 DEBUG [WebServer] Incoming connection from /192.168.0.5:52155
2012-08-01 20:16:09,884 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,885 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,885 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,889 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-01 20:16:09,889 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,890 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,894 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,901 DEBUG [WebServer] Incoming connection from /192.168.0.5:34286
2012-08-01 20:16:09,902 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,902 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,905 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 30, sortCriteria =
2012-08-01 20:16:09,906 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,906 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,907 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,907 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,909 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,918 DEBUG [WebServer] Incoming connection from /192.168.0.5:44388
2012-08-01 20:16:09,918 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,919 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,919 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,922 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-01 20:16:09,922 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,923 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,926 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,933 DEBUG [WebServer] Incoming connection from /192.168.0.5:51099
2012-08-01 20:16:09,933 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,934 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,934 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,938 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 30, sortCriteria =
2012-08-01 20:16:09,938 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,938 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,939 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,939 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,941 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,950 DEBUG [WebServer] Incoming connection from /192.168.0.5:54394
2012-08-01 20:16:09,951 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,951 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,955 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-01 20:16:09,955 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,956 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,960 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,965 DEBUG [WebServer] Incoming connection from /192.168.0.5:59282
2012-08-01 20:16:09,965 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,966 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,966 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,970 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 30, sortCriteria =
2012-08-01 20:16:09,970 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,970 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,971 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,971 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,973 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,979 DEBUG [WebServer] Incoming connection from /192.168.0.5:53880
2012-08-01 20:16:09,980 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,980 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,984 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-01 20:16:09,984 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:09,985 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-01 20:16:09,989 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:09,995 DEBUG [WebServer] Incoming connection from /192.168.0.5:35257
2012-08-01 20:16:09,996 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:09,997 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:09,997 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,000 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 30, sortCriteria =
2012-08-01 20:16:10,000 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:10,001 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,001 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,002 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,004 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:10,011 DEBUG [WebServer] Incoming connection from /192.168.0.5:43052
2012-08-01 20:16:10,011 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,011 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:10,015 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-01 20:16:10,015 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:10,015 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,019 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:10,025 DEBUG [WebServer] Incoming connection from /192.168.0.5:44347
2012-08-01 20:16:10,026 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,026 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:10,031 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 30, sortCriteria =
2012-08-01 20:16:10,031 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:10,032 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,032 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,035 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:10,042 DEBUG [WebServer] Incoming connection from /192.168.0.5:60853
2012-08-01 20:16:10,043 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,043 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:10,047 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-01 20:16:10,047 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:10,047 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,051 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:10,056 DEBUG [WebServer] Incoming connection from /192.168.0.5:40767
2012-08-01 20:16:10,057 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,058 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:10,058 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,061 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 30, sortCriteria =
2012-08-01 20:16:10,061 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:10,062 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,062 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,063 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,065 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:10,072 DEBUG [WebServer] Incoming connection from /192.168.0.5:57230
2012-08-01 20:16:10,073 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,073 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:10,074 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,077 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-01 20:16:10,077 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:10,078 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,083 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:10,089 DEBUG [WebServer] Incoming connection from /192.168.0.5:49337
2012-08-01 20:16:10,089 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,090 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:10,090 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,093 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 30, sortCriteria =
2012-08-01 20:16:10,093 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:10,094 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,095 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,095 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,098 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:10,105 DEBUG [WebServer] Incoming connection from /192.168.0.5:36138
2012-08-01 20:16:10,106 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,106 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:10,110 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-01 20:16:10,110 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:10,111 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,115 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:10,122 DEBUG [WebServer] Incoming connection from /192.168.0.5:41426
2012-08-01 20:16:10,122 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,123 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:10,123 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,126 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 30, sortCriteria =
2012-08-01 20:16:10,126 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:10,127 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,127 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,128 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,130 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:10,136 DEBUG [WebServer] Incoming connection from /192.168.0.5:57057
2012-08-01 20:16:10,136 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,137 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:10,137 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,141 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-01 20:16:10,141 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:10,141 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,145 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:10,155 DEBUG [WebServer] Incoming connection from /192.168.0.5:46814
2012-08-01 20:16:10,155 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,156 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:10,156 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,160 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 30, sortCriteria =
2012-08-01 20:16:10,160 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:10,160 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,160 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,161 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,161 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,163 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:10,169 DEBUG [WebServer] Incoming connection from /192.168.0.5:39509
2012-08-01 20:16:10,170 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,170 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:10,174 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-01 20:16:10,174 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:10,174 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,177 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:10,184 DEBUG [WebServer] Incoming connection from /192.168.0.5:36527
2012-08-01 20:16:10,184 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,185 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:10,185 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,188 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 30, sortCriteria =
2012-08-01 20:16:10,188 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:10,189 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,189 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,192 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:10,199 DEBUG [WebServer] Incoming connection from /192.168.0.5:33089
2012-08-01 20:16:10,199 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,200 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:10,200 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,203 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-01 20:16:10,203 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:10,204 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,208 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:10,214 DEBUG [WebServer] Incoming connection from /192.168.0.5:48669
2012-08-01 20:16:10,215 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,216 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:10,216 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,221 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 30, sortCriteria =
2012-08-01 20:16:10,221 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:10,222 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,222 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,224 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:10,235 DEBUG [WebServer] Incoming connection from /192.168.0.5:35123
2012-08-01 20:16:10,235 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,236 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:10,236 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,240 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-01 20:16:10,240 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:10,240 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,244 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:10,249 DEBUG [WebServer] Incoming connection from /192.168.0.5:43071
2012-08-01 20:16:10,249 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,250 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.5:
2012-08-01 20:16:10,250 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.5
2012-08-01 20:16:10,254 DEBUG [ContentDirectory] Browse() called for renderer UA55D8000 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 30, sortCriteria =
2012-08-01 20:16:10,254 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-01 20:16:10,254 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,255 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,255 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-01 20:16:10,257 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-01 20:16:10,264 DEBUG [WebServer] Incoming connection from /192.168.0.5:49194
Let me know if you need more of the log.
Users browsing this forum: No registered users and 55 guests
