Upgraded to Serviio 1.0 And No Transcoding
• Page 1 of 1
I don't know if anyone else is having this issue, but I upgraded to Serviio 1.0 and none of my movies will transcode on my Sony Blu-Ray player. I downgraded back to 0.6.2 and it works just fine.
Re: Upgraded to Serviio 1.0 And No Transcoding
You're going to need to be more specific. Which OS are you running Serviio on? Which files don't transcode? None of them? Just MKVs? Which model of BDP do you have?
Make sure youre still using the right profile.
Petr
Help translate Serviio
It's running on Linux and all my movies are MKV files. The Blu-ray is a Sony BDP-S580.
make sure you are running up-to-date version of FFmpeg - there have been changes that break compatibility with anything earlier to 0.8 or 0.9
Petr
• Page 1 of 1
Users browsing this forum: No registered users and 69 guests
