have a question about this program
• Page 1 of 1
i like to know why this happens. Every time my computer resets this program does not work. When you put in the ip for the computer the ip for the PS3 & the ip for a Samsung Tv & you hit save & refresh it still does not work what is going on
Re: have a question about this program
I guess you're binding to a IP address, that changes once you restart the PC - so set up static IP addresses for both, your PC and the devices on your router
Petr
Help translate Serviio
well how do you set up a set up static IP addresses & i have no problem when i reset the computer with the other program i use PS3 Media Server
try not binding to any IP address nd do not add any renderers into the console manually - they should appear autmatically.
Petr
well they appear but they have the wrong ip address for each one
Sounds like your router is giving a new ip address each time.
ok what do i do then
still have no clue what to do here because this program will show back up sometimes when you restart the computer & sometimes it does not & i have no clue why i keep getting a different ip address when the computer restarts & i only have problems with this program the other program i use i have no problems with that one at & it is the PS3 Media Server
cooltwou wrote:still have no clue what to do here because this program will show back up sometimes when you restart the computer & sometimes it does not & i have no clue why i keep getting a different ip address when the computer restarts & i only have problems with this program the other program i use i have no problems with that one at & it is the PS3 Media Server
what is the model of your router?
NetGear N600
i listed my router so what now & how & why does this program so compacted compared to the other program i use
• Page 1 of 1
Users browsing this forum: Google [Bot] and 13 guests
