problems adding to library with 1.0
Post Thu Jul 26, 2012 11:31 pm
Re: problems adding to library with 1.0
can you try executing this and posting the result?
ffmpeg.exe -i C:\Users\Mark\Videos\Test Videos\matroska\test4.mkv
It looks like it stops on this command and then stops indexing anything else, therefore never getting to the Pictures folder. Try to remove this file and restart Serviio.
Scoty
Post Fri Jul 27, 2012 9:13 am
I have the same problem (look in the other http://forum.serviio.org/viewtopic.php?f=5&t=6846) but i dont find the problem.
Helios61
Post Fri Jul 27, 2012 1:08 pm
Hi Petr!
Unfortunately i can confirm the issue with grabbing files! Here seervio 1.0 does only grab 9 movies of 63 in folder "G:\Filme\" ! Ver. 0.6.2 is working fine! Debug Log is attached! I hope, you can solve this issue!
Best regards
Helios
In log i have noticed this error code:
2012-07-27 14:58:43,260 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i G:\Filme\Eine dunkle Begierde (2011) (tt1571222)\Eine dunkle Begierde (2011) (tt1571222).mkv
2012-07-27 14:58:43,428 DEBUG [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video file type.
But these files are working fine with 0.6.2! Mediainfo of this file:
Allgemein
UniqueID/String                          : 182082822064629428805159239476708902522 (0x88FBE03D6CF41D3BBB6685078168067A)
Vollständiger Name                       : M:\Filme\Eine dunkle Begierde (2011) (tt1571222)\Eine dunkle Begierde (2011) (tt1571222).mkv
Format-Version                           : Version 2
Dateigröße                               : 21,1 GiB
Dauer                                    : 1h 40min
Modus der Gesamtbitrate                  : variabel
Gesamte Bitrate                          : 30,2 Mbps
Filmname                                 : A Dangerous Method
Kodierungs-Datum                         : UTC 2012-06-11 11:16:26
Kodierendes Programm                     : mkvmerge v5.6.0 ('Kenya Kane') built on May 27 2012 16:44:04
verwendete Encoder-Bibliothek            : libebml v1.2.3 + libmatroska v1.3.0
Format-Profil                            : High@L4.1
Format-Einstellungen für CABAC           : Ja
Format-Einstellungen für ReFrames        : 3 frames
Codec-ID                                 : V_MPEG4/ISO/AVC
Dauer                                    : 1h 40min
Bitraten-Modus                           : variabel
Bitrate                                  : 28,1 Mbps
maximale Bitrate                         : 35,0 Mbps
Breite                                   : 1 920 Pixel
Höhe                                     : 1 080 Pixel
Bildseitenverhältnis                     : 16:9
Bildwiederholungsrate                    : 23,976 FPS
Standard                                 : NTSC
ColorSpace                               : YUV
ChromaSubsampling                        : 4:2:0
BitDepth/String                          : 8 bits
Scantyp                                  : progressiv
Bits/(Pixel*Frame)                       : 0.564
Stream-Größe                             : 19,7 GiB (93%)
Titel                                    : Eine dunkle Begierde (2011)
Sprache                                  : Deutsch
Default                                  : Ja
Forced                                   : Nein
colour_primaries                         : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
transfer_characteristics                 : BT.709-5, BT.1361
matrix_coefficients                      : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio #1
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Codec-ID                                 : A_DTS
Dauer                                    : 1h 40min
Bitraten-Modus                           : konstant
Bitrate                                  : 755 Kbps
Kanäle                                   : 6 Kanäle
Kanal-Positionen                         : Front: L C R, Side: L R, LFE
Samplingrate                             : 48,0 KHz
BitDepth/String                          : 24 bits
Stream-Größe                             : 541 MiB (3%)
Titel                                    : DTS 5.1 - 755 Kbps
Sprache                                  : Deutsch
Default                                  : Ja
Forced                                   : Nein
Audio #2
Format                                   : DTS
Codec-ID                                 : A_DTS
Dauer                                    : 1h 40min
Bitrate                                  : 755 Kbps
Kanäle                                   : 6 Kanäle
Sprache                                  : Englisch
Default                                  : Nein
Forced                                   : Nein
Text #1
Format                                   : PGS
Muxing-Modus                             : zlib
Codec-ID                                 : S_HDMV/PGS
Codec-ID/Info                            : The same subtitle format used on BDs/HD-DVDs
Titel                                    : Deutsch
Sprache                                  : Deutsch
Default                                  : Ja
Forced                                   : Nein
Text #2
Format                                   : PGS
Muxing-Modus                             : zlib
Titel                                    : Deutsch Forced
Sprache                                  : Deutsch
Default                                  : Nein
Forced                                   : Ja
Text #3
Format                                   : PGS
Muxing-Modus                             : zlib
Titel                                    : English
Sprache                                  : Englisch
Default                                  : Nein
Forced                                   : Nein
Text #4
Format                                   : UTF-8
Codec-ID                                 : S_TEXT/UTF8
Codec-ID/Info                            : UTF-8 Plain Text
Titel                                    : WDTV Forced
Sprache                                  : Deutsch
Default                                  : Nein
Forced                                   : Nein
Menü
00:00:00.000                             : en:Chapter 00
00:05:09.309                             : en:Chapter 01
00:09:44.959                             : en:Chapter 02
00:15:35.893                             : en:Chapter 03
00:21:32.124                             : en:Chapter 04
00:25:36.326                             : en:Chapter 05
00:30:37.252                             : en:Chapter 06
00:36:42.116                             : en:Chapter 07
00:41:39.914                             : en:Chapter 08
00:46:20.444                             : en:Chapter 09
00:51:46.061                             : en:Chapter 10
00:57:23.857                             : en:Chapter 11
01:01:01.699                             : en:Chapter 12
01:06:34.991                             : en:Chapter 13
01:11:35.749                             : en:Chapter 14
01:16:48.854                             : en:Chapter 15
01:20:45.966                             : en:Chapter 16
01:27:12.352                             : en:Chapter 17
01:31:59.055                             : en:Chapter 18
01:35:39.525                             : en:Chapter 19
pc5dczc_log.rar
(29.77 KiB) Downloaded 501 times
Post Fri Jul 27, 2012 3:09 pm
I'll need ffmpeg -i of the affected file(s)
Helios61
Post Fri Jul 27, 2012 3:23 pm
Strange :?
C:\Program Files\Serviio_1.0\lib>ffmpeg.exe -i G:\Filme\Eine dunkle Begierde (20
g-config
G:\Filme\Eine: No such file or directory
kram
Post Fri Jul 27, 2012 4:15 pm
zip wrote:can you try executing this and posting the result?
Ok, removed that matroska folder and everything works now :D I can even add more locations to the library 8-)
Im not sure what went wrong with the files in the matroska folder but some of them wont even play in VLC when they did a few weeks ago when I downloaded them. I did however install the newest version of VLC the other day, maybe that has broken something.
Another thing that keeps happening is that the console forgets what TV I have and what profile to use, it keeps trying to set itself to Panasonic 2010. If i refresh and change the profile to Panasonic Viera E/G/GT/DT/UT (2011/2012) the Device name will usually change to Panasonic VIEra but it gets forgoten again later if i exit the console.
kram
Post Fri Jul 27, 2012 4:56 pm
Here is the ffmpeg -i thing of test4. (its in a different location now because I deleted it from the previous location so it wouldnt affect Serviio.)
C:\Program Files\Serviio\lib>ffmpeg.exe -i C:\Users\Mark\Documents\matroska_test
_w1_1\test4.mkv
g-config
[matroska,webm @ 013EBD00] Invalid EBML number size tag 0x0a at pos 35 (0x23)
[theora @ 013ECB60] 7 bits left in packet 82
[matroska,webm @ 013EBD00] Estimating duration from bitrate, this may be inaccur
ate
Input #0, matroska,webm, from 'C:\Users\Mark\Documents\matroska_test_w1_1\test4.
mkv':
creation_time : 2010-08-21 08:42:15
Duration: N/A, start: 0.000000, bitrate: N/A
Stream #0:0: Video: theora, yuv420p, 1280x720, SAR 1:1 DAR 16:9, 24 fps, 24
tbr, 1k tbn, 24 tbc (default)
Stream #0:1: Audio: vorbis, 48000 Hz, stereo, s16 (default)
Im sure I have played this file before on VLC (old version) wont work on this new VLC though.
Post Fri Jul 27, 2012 6:00 pm
Helios61 wrote:Strange :?
g-config
you have to wrap the file name in quotes, as there are spaces
ffmpeg.exe -i "G:\Filme\Eine dunkle Begierde (2011) (tt1571222)\Eine dunkle Begierde (2011) (tt1571222).mkv"
Helios61
Post Fri Jul 27, 2012 6:16 pm
Uups :oops:
C:\Program Files\Serviio_1.0\lib>ffmpeg.exe -i "G:\Filme\Eine dunkle Begierde (2
g-config
[matroska,webm @ 013EBD60] Unsupported encoding typeUnsupported encoding typeUns
upported encoding typeInput #0, matroska,webm, from 'G:\Filme\Eine dunkle Begier
de (2011) (tt1571222)\Eine dunkle Begierde (2011) (tt1571222).mkv':
    title           : A Dangerous Method
    creation_time   : 2012-06-11 11:16:26
  Duration: 01:40:15.52, start: 0.000000, bitrate: 30170 kb/s
    Chapter #0.0: start 0.000000, end 309.309000
      title           : Chapter 00
    Chapter #0.1: start 309.309000, end 584.959356
      title           : Chapter 01
    Chapter #0.2: start 584.959356, end 935.893289
      title           : Chapter 02
    Chapter #0.3: start 935.893289, end 1292.124156
      title           : Chapter 03
    Chapter #0.4: start 1292.124156, end 1536.326444
      title           : Chapter 04
    Chapter #0.5: start 1536.326444, end 1837.252067
      title           : Chapter 05
    Chapter #0.6: start 1837.252067, end 2202.116578
      title           : Chapter 06
    Chapter #0.7: start 2202.116578, end 2499.914067
      title           : Chapter 07
    Chapter #0.8: start 2499.914067, end 2780.444333
      title           : Chapter 08
    Chapter #0.9: start 2780.444333, end 3106.061289
      title           : Chapter 09
    Chapter #0.10: start 3106.061289, end 3443.857067
      title           : Chapter 10
    Chapter #0.11: start 3443.857067, end 3661.699689
      title           : Chapter 11
    Chapter #0.12: start 3661.699689, end 3994.991000
      title           : Chapter 12
    Chapter #0.13: start 3994.991000, end 4295.749778
      title           : Chapter 13
    Chapter #0.14: start 4295.749778, end 4608.854244
      title           : Chapter 14
    Chapter #0.15: start 4608.854244, end 4845.966111
      title           : Chapter 15
    Chapter #0.16: start 4845.966111, end 5232.352111
      title           : Chapter 16
    Chapter #0.17: start 5232.352111, end 5519.055200
      title           : Chapter 17
    Chapter #0.18: start 5519.055200, end 5739.525444
      title           : Chapter 18
    Chapter #0.19: start 5739.525444, end 6015.520000
      title           : Chapter 19
    Stream #0:0(ger): Video: h264 (High), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9],
 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
      title           : Eine dunkle Begierde (2011)
    Stream #0:1(ger): Audio: dts (DTS), 48000 Hz, 5.1(side), s16, 768 kb/s (defa
ult)
      title           : DTS 5.1 - 755 Kbps
    Stream #0:2(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), s16, 768 kb/s
    Stream #0:3(ger): Subtitle: hdmv_pgs_subtitle (default)
      title           : Deutsch
    Stream #0:4(ger): Subtitle: hdmv_pgs_subtitle (forced)
      title           : Deutsch Forced
    Stream #0:5(eng): Subtitle: hdmv_pgs_subtitle
      title           : English
    Stream #0:6(ger): Subtitle: text
      title           : WDTV Forced
Post Fri Jul 27, 2012 6:33 pm
Helios61 wrote:Uups :oops:
g-config
      title           : Chapter 00
      title           : Chapter 01
      title           : Chapter 02
      title           : Chapter 03
      title           : Chapter 04
      title           : Chapter 05
      title           : Chapter 06
      title           : Chapter 07
      title           : Chapter 08
      title           : Chapter 09
      title           : Chapter 10
      title           : Chapter 11
      title           : Chapter 12
      title           : Chapter 13
      title           : Chapter 14
      title           : Chapter 15
      title           : Chapter 16
      title           : Chapter 17
      title           : Chapter 18
      title           : Chapter 19
ult)
      title           : Deutsch
      title           : English
      title           : WDTV Forced
Thanks, it looks like a bug in FFmpeg. I've now fixed it for 1.0.1. Can you, just to double check, post another file that fails adding? Are they all MKVs?
Helios61
Post Fri Jul 27, 2012 10:23 pm
zip wrote:I've now fixed it for 1.0.1. Can you, just to double check, post another file that fails adding? Thanks, it looks like a bug in FFmpeg.
Of course!
C:\Program Files\Serviio_1.0\lib>ffmpeg.exe -i "g:\filme\Safe House (2012) (tt15
99348)\Safe House (2012) (tt1599348).mkv"
g-config
[matroska,webm @ 0141BD00] Unsupported encoding typeUnsupported encoding typeUns
upported encoding typeUnsupported encoding typeUnsupported encoding typeInput #0
, matroska,webm, from 'g:\filme\Safe House (2012) (tt1599348)\Safe House (2012)
(tt1599348).mkv':
    title           : Safe House
    creation_time   : 2012-06-19 06:28:18
  Duration: 01:54:54.56, start: 0.000000, bitrate: 28173 kb/s
    Chapter #0.0: start 0.000000, end 292.000022
      title           : Chapter 00
    Chapter #0.1: start 292.000022, end 824.615444
      title           : Chapter 01
    Chapter #0.2: start 824.615444, end 1124.456667
      title           : Chapter 02
    Chapter #0.3: start 1124.456667, end 1438.228444
      title           : Chapter 03
    Chapter #0.4: start 1438.228444, end 1766.931822
      title           : Chapter 04
    Chapter #0.5: start 1766.931822, end 2239.987733
      title           : Chapter 05
    Chapter #0.6: start 2239.987733, end 2483.981489
      title           : Chapter 06
    Chapter #0.7: start 2483.981489, end 2909.031111
      title           : Chapter 07
    Chapter #0.8: start 2909.031111, end 3408.780356
      title           : Chapter 08
    Chapter #0.9: start 3408.780356, end 3653.983667
      title           : Chapter 09
    Chapter #0.10: start 3653.983667, end 4022.309956
      title           : Chapter 10
    Chapter #0.11: start 4022.309956, end 4277.982022
      title           : Chapter 11
    Chapter #0.12: start 4277.982022, end 4585.581000
      title           : Chapter 12
    Chapter #0.13: start 4585.581000, end 4883.128244
      title           : Chapter 13
    Chapter #0.14: start 4883.128244, end 5174.002156
      title           : Chapter 14
    Chapter #0.15: start 5174.002156, end 5365.109733
      title           : Chapter 15
    Chapter #0.16: start 5365.109733, end 5734.478733
      title           : Chapter 16
    Chapter #0.17: start 5734.478733, end 6265.217289
      title           : Chapter 17
    Chapter #0.18: start 6265.217289, end 6584.202622
      title           : Chapter 18
    Chapter #0.19: start 6584.202622, end 6894.560000
      title           : Chapter 19
      title           : Safe House (2012)
ult)
    Stream #0:2(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), s16, 1536 kb/s
      title           : DTS 5.1 - 1510 Kbps
      title           : Deutsch
    Stream #0:5(ger): Subtitle: hdmv_pgs_subtitle
      title           : Deutsch Kommentar
    Stream #0:6(eng): Subtitle: hdmv_pgs_subtitle
      title           : English
    Stream #0:7(eng): Subtitle: hdmv_pgs_subtitle
      title           : English Forced
    Stream #0:8(ger): Subtitle: text
      title           : WDTV Forced
zip wrote:Are they all MKVs?
Yes, all .mkv's!
Post Fri Jul 27, 2012 10:37 pm
thanks
reiffert
Post Sun Aug 05, 2012 7:28 am
Is there any way for pulling serviio 1.0.1 from github or similar?
Regards
Thomas
Post Sun Aug 05, 2012 5:01 pm
Nope
Previous
Users browsing this forum: No registered users and 165 guests
