HDTRAILERS VIDEO WEBRESOURCE
Post Sat Jul 07, 2012 4:02 pm
HD-Trailers.com provides access to Movie Trailers gathered from multiple source sites, including Apple, Moviefone, Yahoo, YouTube, Disney, MSN, MTV, Funnieordie.
This hdtrailers.groovy "webresource" will access all these sites and display the most recently posted trailer or teaser for each movie in the requested list. If there are no trailers or teasers, the most recently posted item will display.
If the option pref=apple is specified and there is an apple trailer in the list, the latest apple trailer will be displayed instead of the latest trailer overall.
The following lists are supported:
* Latest trailers: "http://www.hd-trailers.net?start=nn&res=yyy&pref=apple
* Most watched: "http://www.hd-trailers.net/most-watched?res=yyy
* Top 10: "http://www.hd-trailers.net/top-movies?res=yyy
* Opening-this-week: "http://www.hd-trailers.net/opening-this-week?res=yyy
* Coming soon: "http://www.hd-trailers.net/coming-soon?res=yyy
* Netflix-new-releases: "http://www.hd-trailers.net/netflix-new-releases?res=yyy
* where start=1 to start=2700 & res=480, 720 or 1080
* and the defaults are start=1 and res=480
Note that many of the 720 and particularly the 1080 resolution videos use a bit rate that exceeds 5mbps and may not play smoothly on normal DSL connections.
V5: Aug. 13, 2012 - version logging and Serviio 1.0 prereq
V6: Sep. 17, 2012 - exclude restricted "Red Band Trailers"
V7: Sep. 20, 2012 - support changed YouTube links
V8: Nov. 13, 2012 - corrected titles
V9: Feb. 3, 2013 - New yahoo format
V10: Mar 13,2013- Fix thumbs and ' in Titles
V11: May 30, 2013 - Use Protected read
V12: Nov 1, 2013 - Remove Protected read
V13: June 8,2016 - Restore missing Thumbnails
HDTrailers.groovy
V13 - June 8, 2016
(14.78 KiB) Downloaded 2170 times
Xmantium
Post Sun Jul 08, 2012 4:39 pm
Re: HDTRAILERS VIDEO WEBRESOURCE
Excellent! Another quality jhb50 plugin release :)
Scoty
Post Fri Jul 27, 2012 4:29 pm
Is this a Live Stream or how add this? Work this with Serviio 0.6.2 to?
Post Fri Jul 27, 2012 7:06 pm
Read the thread. Only supported on latest Serviio release.
Post Sun Jul 29, 2012 6:40 pm
Version 2 posted, with support for apple trailers based on Serviio 1.0
Post Mon Jul 30, 2012 12:37 am
Version 3 posted with new option to select latest apple trailer if available in place of latest trailer overall. This is equivalent to an apple-trailers groovy plus others not available on apple.
Xmantium
Post Fri Aug 03, 2012 1:11 am
Hi jhb50, theres some trailers missing on some, this is because HD-Trailers put files in the "Clips" section
Some like the new movies Robocop and Cloud Atlas has teaser trailers in the clips section
Was hoping if you can change to if trailer does not exist yet, play the latest clip file instead
Post Fri Aug 03, 2012 2:36 am
On my list... give me an example.
Xmantium
Post Fri Aug 03, 2012 3:39 am
http://www.hd-trailers.net/most-watched/
[3] - Iron Man3, Nothings shows in serviio, would be nice to see the comic con clip
[5] - Cloud Atlas, again nothing shows in serviio, but clip has preview trailer
[7] - Robocop, clip has teaser
Post Fri Aug 03, 2012 1:24 pm
Version 4 released which will display the latest posted item for any film if there are no trailer or teaser entries. This can include promotional videos or clips. It ensures that all films are displayed in Serviio regardless of the availble material.
fibula
Post Wed Aug 08, 2012 8:54 am
I´m back to client 0.6.2, because I had many problems with 1.0.
Otherwise I can`t see HD-Trailers anymore ("There are no items in list"), but I didn´t change anything.
Perhaps the new plugin doesn´t correspond to the odl client anymore?
Post Wed Aug 08, 2012 3:09 pm
dup
Xmantium
Post Wed Aug 08, 2012 8:25 pm
fibula wrote:I´m back to client 0.6.2, because I had many problems with 1.0.
Works better on 1.0 as it includes Apple Trailers.
Are you sure your using Web Resource?
fibula
Post Thu Aug 09, 2012 8:24 am
Yes, I´m using Web resource with URL "http://www.hd-trailers.net?start=1&res=720".
Is this right?
I´m back to 0.6.2, because I have no audio on onlinesources at all on 1.0, especially with AVC- and wmv-sources.
NX3
Post Thu Aug 09, 2012 11:49 am
Do you have a 2011 model Sony tv by any chance ? Check out this : viewtopic.php?f=11&t=6858
Basically in Serviio 1.0 audio is missing on Sony 2011 series and trying work out what's going wrong.
NX3
Post Mon Aug 13, 2012 8:29 pm
How can you tell if the trailer is from apple ?
Xmantium
Post Mon Aug 13, 2012 8:56 pm
NX3 wrote:How can you tell if the trailer is from apple ?
Theres usually an Apple watermark on the bottom right
Post Mon Aug 13, 2012 9:34 pm
Version 5 released with version logging and Serviio 1.0 prereq.
Return to Available plugins
