New Serviio Install
NeutronJames
Post Sun Jul 29, 2012 6:46 pm
New Serviio Install
Hi forum,
I just upgraded my desktop to ubuntu 12.04 and installed Serviio 1.0. I have it working except I can only start the program and console by clicking on the folder. If I go into /serviio-1.0/bin/ and try to start with a command line I get the following error.
name@thunderbolt:~/serviio-1.0/bin$ /serviio.sh
bash: /serviio.sh: No such file or directory
chad@thunderbolt:~/serviio-1.0/bin$
I don't understand. Everything works...I just cannot get it to work using command line codes.
Post Sun Jul 29, 2012 6:49 pm
Re: New Serviio Install
Use ./serviio.sh (not /serviio.sh)
If you are using the version of ffmpeg that came with ubuntu, you will need to update it (download a newer one/compile from source ideally), as it is too old and doesn't support some of the commandline options used by 1.0
Return to General discussion
Users browsing this forum: Google [Bot] and 10 guests
