[Readme] Sony Bravia 2011 series
Post Mon Jul 30, 2012 6:29 pm
Re: [Readme] Sony Bravia 2011 series
Ok, can we test these profiles and if it's all ok, I'll add them. I assume the detection should be removed if we cannot distinguish then from the EU versions.
Post Mon Jul 30, 2012 7:04 pm
zip wrote:Ok, can we test these profiles and if it's all ok, I'll add them. I assume the detection should be removed if we cannot distinguish then from the EU versions.
Don't know, I could not test that, its only for 2011/2012 and I have a 2010 model. Any tester ?
koan00
Post Mon Jul 30, 2012 7:08 pm
I can test 2011. You might need to ask in the 2012 thread for that year testers...
koan00
Post Tue Jul 31, 2012 12:44 am
Having the DAR attribute set to 16:9 distorts all of my 4:3 content, so I removed that attribute from the entry. Now it looks correct. Here is what I am now using (which is working for all of my media):
 <Profile id="sony2011us" name="Sony Bravia TV (2011) - US" extendsProfileId="sony2011">
         <!-- 2011 models for US (without avi/divx)
             - Still images: JPEG
             - Music: MP3, linear PCM, WMA
             - Video: AVCHD, MPEG2, MPEG1, MP4 (AVC), MP4 (MPEG4), WMV -->
      <Detection>
         <UPnPSearch>
            <FriendlyName>BRAVIA KDL-\d{2}([A-Z]X\d2\d|CX400).*</FriendlyName>
         </UPnPSearch>
      </Detection>
         <!-- Transcode DivX, AVI -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="384" forceInheritance="true">
            <Matches container="avi" vCodec="mpeg4" />
            <Matches container="avi" vCodec="msmpeg4" />
Edit: Just noticed the "extends sony2011" bit which is why the audio section isnt needed. DAR issue still stands..
Liten
Post Thu Aug 02, 2012 2:59 am
Just tried the profile code and audio comes across great but the video is studdering. Literally going back a frame about every 5 frames. Any thoughts? I am running a KDL-46EX723.
koan00
Post Thu Aug 02, 2012 12:44 pm
Liten wrote:Just tried the profile code and audio comes across great but the video is studdering. Literally going back a frame about every 5 frames. Any thoughts? I am running a KDL-46EX723.
Have you tried playing back the transcoded file natively on a PC?
Liten
Post Sat Aug 04, 2012 8:38 am
yes it plays back just fine on two PC's, two PS3's and a wdtv live.
fibula
Post Mon Aug 27, 2012 7:09 am
I have a 46EX720 and problems with new client.
I´ve no audio in all "AVC"-files.
Can you help me?
Thanks in advance
Post Mon Aug 27, 2012 2:15 pm
I suppose that "Sony Bravia 2011" is selected.
Could you provide information about this file? (see signature link)
Could you enable detailed logging and check the ffmpeg command line used to transcode tis file ?
fibula
Post Mon Aug 27, 2012 2:51 pm
I´ve attched a log file (it was very big, so I have deleted something, but I think, the main items were left).
thanks
(66.11 KiB) Downloaded 548 times
Post Mon Aug 27, 2012 6:32 pm
There are only online resources (what is the plugin used?), do you try with local AVC media ?
Post Mon Aug 27, 2012 6:47 pm
I retry the Arte.groovy with 360°GEO RSS feed, without problem on my EX500 (2010)
C:\Serviio\bin\\..\lib/ffmpeg.exe -fflags +genpts -i rtmp://artestras.fcod.llnwd.net:443 app=a3903/o35 swfUrl=http://videos.arte.tv/blob/web/i18n/view/player_23-3188338-data-4993762.swf playpath=mp4:geo/videothek/ALL/arteprod/2010/12/21/GEO-nh-bonus-Anatolien_FR_73756_16by9_800_MP4?h=3457b476aba05c700640157f02460214 swfVfy=1 buffer=100000000 -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts D:\temp\ServiioTemp\Serviio\transcoding-temp-1000000000170002-sony2010-ORIGINAL.stf
What is your feed link ?
karlsus
Post Mon Aug 27, 2012 8:08 pm
I have a 40NX723 and I lost audio in all online resources with the new client (tried v.1.0 and 1.0.1).
Video files saved on my PC play correctly.
Can you help me?
EDIT : Changed back to version 0.6.2 and got the audio back.
djoimania
Post Tue Aug 28, 2012 2:18 am
same problem here but i only copied the profiles.xml from 0.6.2 to the 1.0.1 folder
and got audio back.
0.6.2 has no playlist support ;)
fibula
Post Tue Aug 28, 2012 11:21 am
djoimania wrote:Hi,
and got audio back.
Thanks for this! Now all is right.
koan00
Post Tue Aug 28, 2012 12:34 pm
I have a some mp4:avc/aac files. I guess this is the no longer transcode AAC change in the 1.x series that causes the problem?
boeingaviation
Post Wed Aug 29, 2012 2:03 am
Hi all,
I've been using Serviio on my Sony Bravia TV KDL-32CX520. I have coded some movies into both MPEG-4 & AVI formats.
Now sometimes videos will play fine and sometimes they wont. For example I was just watching a video on my TV which is streaming via my router using Serviio and 25 minutes into the video it freezes and I can't rewind or fast forward.
Serviio has automatically selected the Sony Bravia 2011 model in the profile.
Also sometimes after a few days I can't get serviio to show up on my tv, even though the console is showing that the server is running.
Are there any special settings or anything that I need to set?
Cheers,
Chris.
koan00
Post Wed Aug 29, 2012 12:32 pm
boeingaviation wrote:Hi all,
Cheers,
Chris.
Frist, can you post a detailed log file from serviio?
Is this both avi and mp4 media types? Any others have issues?
What is your network like? WLAN, wired, speed, etc?
Do you have enough free temp space on the server?
If you are in the US, I wouldnt recommend the AVI container, as the TV does not support it natively. MP4 would be better. Also, if in the US, manually select the Sony Bravia 2011 (US) profile in the console.
For issues with serviio not being seen, it could be quite a few things. I think it is recomended to have both the server and the clients to have IP's that don't change. You can either use a static IP for each, or a DHCP reservation. Also, don't let the server machine go to sleep or hibernate.
koan00
Post Tue Nov 13, 2012 6:52 pm
I'd like to suggest backing out the AAC audio changes from the 2011-us profile.
I get about a 60% success rate for playing back AAC with the new profile. Backing out the AAC part allows me to have 100% working. Not sure what the issue is, a cursory look with media info doesnt seem to show many differences between what plays, and what doesnt.
playwithfire
Post Sat Nov 17, 2012 4:09 pm
djoimania wrote:Hi,
and got audio back.
How did you get this to work? I am having the same issue but I copied the profiles from 0.62 to the 1.01 folder and then Serviio will not load up (it gives that error message Serviio seems to be running....exciting crap).
