Upgrading to 1.0 breaks FLV (RSS) Steam for Samsung D Series
unfurled
Post Wed Aug 08, 2012 5:00 pm
After upgrading to 1.0, my Samsung UA40D5500 is unable to view any of the FLVs I previously set in the Online RSS Feeds. I get a video codec not supported error. I've tried replacing the profiles.xml with the one used in 0.62; it still doesn't work. When I revert back to 0.62 it plays fine.
I've traced it down to the way Serviio calls ffmpeg.exe in 1.0 :
In 0.62 :
2012-08-09 00:38:15,125 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i http://1234.flv -y -threads 1 -async 1 -vcodec mpeg2video -b 20000k -maxrate 20000k -bufsize 20000k -r 25 -g 15 -copyts -acodec ac3 -ab 80k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:\WINDOWS\TEMP\Serviio\transcoding-temp-1000000000010001-MPEG2TS.stf
In 1.0 :
2012-08-08 22:59:03,163 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i http://1234.flv -y -threads 2 -copyts -c:v mpeg2video -b:v 20000k -r 25 -g 15 -c:a ac3 -b:a 80k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-1000000000420001-7-ORIGINAL.stf
Is there a way I can revert back to the same command lines in 0.62 for 1.0?
Post Wed Aug 08, 2012 5:06 pm
Re: Upgrading to 1.0 breaks FLV (RSS) Steam for Samsung D Se
the form of ffmpeg commands changed with 1.0 in line with the latest ffmpeg version. I suggest you post a detailed log of the failure so the real reason can be determined. Try copying and renaming the .stf to .mpg and see if it plays.
unfurled
Post Thu Aug 09, 2012 1:41 am
Actually if you notice, maxrate and bufsize params are not included in 1.0. I'm not too sure if this affects anything.
Well I extracted the STF files from 0.62 and 1.0, compared the differences. It would seem the format encoded is different. I suspect its the missing Maximum bit rate variable. Any idea on how to add back that param?
0.62 Log
2012-08-09 09:27:59,328 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000010001 (online)
2012-08-09 09:27:59,328 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2012-08-09 09:27:59,338 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000010001, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D-series)
2012-08-09 09:27:59,338 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://abcd.tv/vods/ns/bd1_x15d2_1.flv
2012-08-09 09:27:59,338 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://abcd.tv/vods/ns/bd1_x15d2_1.flv: MPEG_TS_SD_EU_ISO
2012-08-09 09:27:59,338 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://abcd.tv/vods/ns/bd1_x15d2_1.flv: MPEG_TS_SD_NA_ISO
2012-08-09 09:27:59,338 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://abcd.tv/vods/ns/bd1_x15d2_1.flv: MPEG_TS_SD_KO_ISO
2012-08-09 09:27:59,338 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-08-09 09:27:59,338 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Thu, 09 Aug 2012 01:27:59 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-08-09 09:27:59,348 DEBUG [WebServer] Incoming connection from /192.168.1.246:35507
2012-08-09 09:27:59,388 DEBUG [ResourceTransportRequestHandler] GET /resource/1000000000010001/MEDIA_ITEM/MPEG_TS_SD_KO_ISO*0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,TimeSeekRange.dlna.org: npt=0-,Host: 192.168.1.89:8895]]
2012-08-09 09:27:59,388 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.246
2012-08-09 09:27:59,388 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.246, Profile=Samsung TV / player (C/D-series)'
2012-08-09 09:27:59,388 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000010001 and type 'MEDIA_ITEM' received
2012-08-09 09:27:59,388 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000010001 (online)
2012-08-09 09:27:59,388 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2012-08-09 09:27:59,388 DEBUG [VideoDeliveryEngine] Delivering item '1000000000010001' for client 'IPAddress=/192.168.1.246, Profile=Samsung TV / player (C/D-series)'
2012-08-09 09:27:59,388 DEBUG [VideoDeliveryEngine] Delivering file 'http://abcd.tv/vods/ns/bd1_x15d2_1.flv' using transcoding
2012-08-09 09:27:59,388 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.246, Profile=Samsung TV / player (C/D-series)'
2012-08-09 09:27:59,388 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: http://abcd.tv/vods/ns/bd1_x15d2_1.flv
2012-08-09 09:27:59,398 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i http://abcd.tv/vods/ns/bd1_x15d2_1.flv -y -threads 1 -async 1 -vcodec mpeg2video -b 20000k -maxrate 20000k -bufsize 20000k -r 25 -g 15 -copyts -acodec ac3 -ab 80k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:\WINDOWS\TEMP\Serviio\transcoding-temp-1000000000010001-MPEG2TS.stf
2012-08-09 09:28:00,399 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-08-09 09:28:00,399 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://abcd.tv/vods/ns/bd1_x15d2_1.flv: MPEG_TS_SD_EU_ISO
2012-08-09 09:28:00,409 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://abcd.tv/vods/ns/bd1_x15d2_1.flv: MPEG_TS_SD_NA_ISO
2012-08-09 09:28:00,409 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://abcd.tv/vods/ns/bd1_x15d2_1.flv: MPEG_TS_SD_KO_ISO
2012-08-09 09:28:00,409 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
1.0 Log
2012-08-09 09:30:42,412 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000410001 (online)
2012-08-09 09:30:42,412 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 41)
2012-08-09 09:30:42,413 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000410001, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D-series)
2012-08-09 09:30:42,413 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://abcd.tv/vods/ns/bd1_x15d2_1.flv
2012-08-09 09:30:42,413 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://abcd.tv/vods/ns/bd1_x15d2_1.flv: MPEG_TS_SD_EU_ISO
2012-08-09 09:30:42,413 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://abcd.tv/vods/ns/bd1_x15d2_1.flv: MPEG_TS_SD_NA_ISO
2012-08-09 09:30:42,413 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://abcd.tv/vods/ns/bd1_x15d2_1.flv: MPEG_TS_SD_KO_ISO
2012-08-09 09:30:42,413 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-08-09 09:30:42,414 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Thu, 09 Aug 2012 01:30:42 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-08-09 09:30:42,430 DEBUG [WebServer] Incoming connection from /192.168.1.246:42947
2012-08-09 09:30:42,431 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.246
2012-08-09 09:30:42,431 DEBUG [ResourceTransportRequestHandler] GET /resource/1000000000410001/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,TimeSeekRange.dlna.org: npt=0-,Host: 192.168.1.102:8895]]
2012-08-09 09:30:42,432 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.246
2012-08-09 09:30:42,432 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.246, Profile=Samsung TV / player (C/D-series)'
2012-08-09 09:30:42,433 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000000410001 and type 'MEDIA_ITEM' received
2012-08-09 09:30:42,433 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000410001 (online)
2012-08-09 09:30:42,433 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 41)
2012-08-09 09:30:42,434 DEBUG [VideoDeliveryEngine] Delivering item '1000000000410001' for client 'IPAddress=/192.168.1.246, Profile=Samsung TV / player (C/D-series)'
2012-08-09 09:30:42,434 DEBUG [VideoDeliveryEngine] Delivering file 'http://abcd.tv/vods/ns/bd1_x15d2_1.flv' using transcoding
2012-08-09 09:30:42,435 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-1000000000410007-7-ORIGINAL.stf', will stop the job
2012-08-09 09:30:42,435 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-1000000000410007-7-ORIGINAL.stf'
2012-08-09 09:30:42,435 DEBUG [ProcessExecutor] Stopping external process: Thread[Thread-5278,5,main]
2012-08-09 09:30:42,435 DEBUG [ProcessUtils] Killing the Windows process: 1152
2012-08-09 09:30:42,443 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2012-08-09 09:30:42,457 DEBUG [TranscodingJobListener] Deleted temp file 'C:\Windows\TEMP\Serviio\transcoding-temp-1000000000410007-7-ORIGINAL.stf': true
2012-08-09 09:30:42,457 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.246, Profile=Samsung TV / player (C/D-series)'
2012-08-09 09:30:42,458 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: http://abcd.tv/vods/ns/bd1_x15d2_1.flv
2012-08-09 09:30:42,459 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i http://abcd.tv/vods/ns/bd1_x15d2_1.flv -y -threads 2 -copyts -c:v mpeg2video -b:v 20000k -r 25 -g 15 -c:a ac3 -b:a 80k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-1000000000410001-7-ORIGINAL.stf
2012-08-09 09:30:42,959 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-08-09 09:30:42,960 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://abcd.tv/vods/ns/bd1_x15d2_1.flv: MPEG_TS_SD_EU_ISO
2012-08-09 09:30:42,960 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://abcd.tv/vods/ns/bd1_x15d2_1.flv: MPEG_TS_SD_NA_ISO
2012-08-09 09:30:42,960 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://abcd.tv/vods/ns/bd1_x15d2_1.flv: MPEG_TS_SD_KO_ISO
2012-08-09 09:30:42,962 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-08-09 09:30:42,962 DEBUG [ResourceDeliveryProcessor] Sending file back
Post Thu Aug 09, 2012 1:31 pm
Fixed for 1.0.1
unfurled
Post Thu Aug 09, 2012 1:57 pm
Thanks! :D
Users browsing this forum: Google [Bot] and 24 guests
