Serviio Profile Switcher
It was pointed out on the AVS forum that in order to play avi with the Sony BD S590 a slight mod to the renderer profile was needed. Once a single line was changed I had no problem playing avi videos that earlier drew corrupt or unknown file messages.
There was another mod to the Sony profile to play Divx files. However, it's my understanding once that code is modded, all avi would be transcoded, rather than played natively, and unless you had many Divx files, it would be best to change the FourCC code in the files you wanted to play.
I'm more or less a beginner at this but, is it possible to make a simple batch file to switch profiles as needed without breaking the installation? And will a custom profile allow one to delete profiles not needed such as LG, Panasonic, Philips etc?
