Web UI in PHP - support thread
qoolbox
Post Tue Jul 24, 2012 7:20 pm
Re: Web UI in PHP (revised)
Hello, is the PHP WEBui is compatible with new 1.0 version :D ??
Third Party Thecus NAS Develloper
http://forum.thecus.com
http://www.tsuga.fr
Post Tue Jul 24, 2012 7:22 pm
Pretty much via this branch https://github.com/mpemberton5/Web-UI-f ... o/tree/1.0
There are a few issues that need to be fixed, nothing major though.
qoolbox
Post Wed Jul 25, 2012 6:59 am
will wrote:Pretty much via this branch https://github.com/mpemberton5/Web-UI-f ... o/tree/1.0
I was excited to make a Serviio Module for Thecus...
but doesnt work very nice,
Serviio is well launched as background service, but when i launch Webui 1.1 i have got a big red message on top of page :
WARNING: There is a version mismatch between Serviio and Web UI. There may be a loss of functionality.
And also impossible to save any config, all remain to default whatever i do...
the Embedded PHP is 5.3.14 (XML and Curl are well present) :(
log display :
2012-07-25 08:46:35,770 INFO  [MediaServer] ------------------------------------------------------------------------
2012-07-25 08:46:35,775 INFO  [MediaServer] Serviio DLNA media streaming server v 1.0 (rev. 34c915f37185+)
2012-07-25 08:46:35,775 INFO  [MediaServer] Petr Nejedly 2009-2012
2012-07-25 08:46:35,775 INFO  [MediaServer] http://www.serviio.org
2012-07-25 08:46:35,776 INFO  [MediaServer] Java 1.6.0_30-Sun Microsystems Inc.
2012-07-25 08:46:35,776 INFO  [MediaServer] OS Linux i386 2.6.33N7700
2012-07-25 08:46:35,777 INFO  [MediaServer] File encoding: US-ASCII
2012-07-25 08:46:35,779 INFO  [MediaServer] Headless mode enabled: true
2012-07-25 08:46:35,779 INFO  [MediaServer] User home dir: /root
2012-07-25 08:46:35,779 INFO  [MediaServer] Temp dir: /tmp
2012-07-25 08:46:35,779 INFO  [MediaServer] ------------------------------------------------------------------------
2012-07-25 08:46:36,433 INFO  [WebServer] Socket buffer set to 65535 bytes
2012-07-25 08:46:36,442 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2012-07-25 08:46:36,638 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2012-07-25 08:46:36,641 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2012-07-25 08:46:36,740 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-07-25 08:46:53,338 INFO  [DBSchemaUpdateExecutor] Updating DB schema
2012-07-25 08:46:59,913 WARN  [ServiioStatusService] ExceptionInInitializerError occured. Returning error code 500 to the REST layer. Message: null
2012-07-25 08:47:04,655 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:04,798 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:04,859 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:05,114 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:09,424 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:09,525 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:14,238 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:14,340 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:16,043 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:16,147 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:19,261 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:19,353 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:24,182 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:24,284 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:29,191 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:29,292 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:32,997 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:33,199 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:34,200 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:34,301 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:40,712 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:40,812 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:40,903 INFO  [WebServer] WebServer starting on port 8895
2012-07-25 08:47:40,934 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:44,705 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:44,796 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:45,596 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:45,698 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:50,605 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:50,706 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:53,322 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:55,618 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:47:55,721 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:00,128 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:00,727 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:00,827 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:01,837 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:05,635 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:05,735 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:10,646 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:10,741 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:13,181 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:15,748 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:15,852 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:20,655 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:20,760 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:24,893 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-07-25 08:48:25,783 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:25,885 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:28,306 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:30,698 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:30,799 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:35,704 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:35,806 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:39,634 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:40,711 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:40,811 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:45,716 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:45,818 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:49,021 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:50,723 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:50,825 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:55,433 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:55,730 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:48:55,831 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:00,638 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:00,737 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:02,758 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:05,741 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:05,843 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:07,844 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:08,045 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:10,647 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:10,749 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:17,355 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:17,457 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:18,027 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:22,361 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:22,463 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:24,965 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:26,170 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:26,276 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:26,477 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:31,081 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:31,182 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:33,890 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:33,987 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:36,189 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:36,293 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:37,390 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:37,591 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:41,094 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:41,195 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:41,703 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:41,796 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:46,301 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:46,310 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:46,405 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:50,410 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:51,319 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:51,419 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:55,322 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:56,125 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:56,225 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:49:57,528 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:01,133 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:01,233 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:03,553 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:06,138 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:06,238 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:10,645 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:10,744 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:11,145 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:11,245 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:16,152 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:16,251 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:21,157 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:21,257 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:26,163 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:26,265 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:31,171 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:31,271 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:36,177 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:36,278 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:41,184 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:41,285 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:46,190 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:46,290 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:51,196 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:51,298 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:56,102 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:50:56,203 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:01,108 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:01,209 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:06,115 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:06,215 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:11,121 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:11,221 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:16,127 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:16,229 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:21,133 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:21,234 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:26,140 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:26,240 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:31,147 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:31,247 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:36,653 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:36,754 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:41,159 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:41,259 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:46,166 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:46,266 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:51,073 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:51,173 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:51,274 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:56,280 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:51:56,380 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:01,186 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:01,287 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:06,194 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:06,294 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:11,198 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:11,299 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:16,204 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:16,305 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:21,211 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:21,311 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:26,217 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:26,317 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:31,223 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:31,323 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:36,229 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:36,330 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:41,236 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:41,336 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:46,142 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:46,242 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:51,148 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:51,249 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:56,162 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:52:56,255 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:01,160 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:01,261 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:06,167 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:06,266 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:11,173 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:11,273 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:16,179 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:16,279 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:21,185 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:21,285 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:26,191 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:26,292 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:31,198 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:31,298 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:36,203 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:36,304 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:41,209 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:41,310 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:46,215 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:46,316 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:51,222 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:51,323 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:56,229 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:53:56,328 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:01,234 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:01,335 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:06,240 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:06,341 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:11,246 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:11,347 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:16,153 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:16,253 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:21,159 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:21,261 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:26,267 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:26,366 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:31,171 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:31,272 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:36,178 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:36,278 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:41,185 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:41,286 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:46,190 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:46,291 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:51,197 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:51,297 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:56,203 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:54:56,303 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:01,211 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:01,311 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:06,217 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:06,318 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:11,223 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:11,322 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:16,228 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:16,329 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:21,234 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:21,335 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:26,241 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:26,341 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:31,247 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:31,347 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:36,254 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:36,355 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:41,159 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:41,259 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:46,166 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:46,267 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:51,171 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:51,273 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:56,178 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:55:56,278 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:01,184 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:01,285 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:06,290 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:06,390 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:11,196 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:11,296 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:16,202 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:16,303 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:21,208 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:21,308 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:26,214 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:26,315 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:31,220 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:31,321 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:36,226 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:36,326 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:41,232 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:41,332 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:46,238 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:46,338 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:51,244 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:51,345 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:56,251 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:56:56,351 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:57:01,157 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:57:01,257 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:57:06,162 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:57:06,263 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:57:11,169 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:57:11,269 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:57:16,181 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:57:16,275 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:57:21,181 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:57:21,281 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:57:26,187 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:57:26,287 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2012-07-25 08:57:31,193 WARN  [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
http://www.tsuga.fr
Post Wed Jul 25, 2012 7:31 am
Goto the about tab of the webui, you have to download it from the branch on gitbub, the download zip files are for 0.6.2
Check you are on webui 1.1 and that it says which edition of Serviio you have along with expires in...
qoolbox
Post Wed Jul 25, 2012 7:42 am
Thanks Will, i finally resolve the problem it seems that the Serviio binary folder and web files was CHMOD 755, i CHMOD it 777, all run fine now... no more message and config can saved
I see just a little bug :
in Presentation TAB, i select french language, even if i restart console or module the webui stay in English
http://www.tsuga.fr
qoolbox
Post Wed Jul 25, 2012 8:12 am
Another bug, i cannot set directory in "shared folder", once it is set, and saved... i change TAB and come back in Library and the directory is deleted and not display anymore :?
http://www.tsuga.fr
Xmantium
Post Wed Jul 25, 2012 8:55 am
Mark mentioned this is a beta test version so may have few bugs.
I'm finally going to install it on my QNAP NAS tonight, been very difficult as Serviio on my NAS is used 24/7 in my household, let you know how it goes.
Post Wed Jul 25, 2012 12:48 pm
Re: Web UI in PHP (revised)
Xmantium wrote:as Serviio on my NAS is used 24/7 in my household
:-) this kind of comments always make my day - it makes all the work worth while
Xmantium
Post Wed Jul 25, 2012 5:32 pm
Thanks again zip for Serviio! Trust me when you have children, it's immensely useful and highly cost saving on the amount of interest they pick up every week.
I do think Serviio is best used on a NAS, this way it can run 24/7. Running costs are low and vast media storage space. The cool thing is even if my NAS is switched off, if I try to access Serviio on my Bravia TV it wakes my NAS up!
DJR
Post Fri Jul 27, 2012 12:01 pm
Hi there, eagerly awaiting progress on this one.. :)
Any clue if for Sony Bravia TV sets subtitles may be transcoded? e.g. SRT files including with the stream?
Thank you.
Xmantium
Post Fri Jul 27, 2012 8:58 pm
I can say Mark does have something special cooked up for this Web UI ;)
Off topic - Last i heard Sony UK are working with zip to come with some solution for Bravia TVs to add subs. FFMpeg does not currently support "burning" subs on video
qoolbox
Post Sun Jul 29, 2012 9:05 am
Xmantium wrote:I can say Mark does have something special cooked up for this Web UI ;)
I thought it was possible if FFmpeg is compiled with libass (and dependencies), may be i am wrong :)
Third Party Thecus NAS Develloper
http://forum.thecus.com
http://www.tsuga.fr
mpemberton5
Post Sun Aug 12, 2012 7:08 pm
Hey all, hoping to release an updated version of Web UI in the coming days that will work well with Serviio 1.0.
Cheers,
mpemberton5
Post Mon Aug 13, 2012 8:15 pm
It's official! Go grab the latest release on the wiki page!
This release should be fully compliant with all the new features of Serviio 1.0.
Kudo's to Xmantium for his awesome help in the final testing!
Cheers,
Xmantium
Post Mon Aug 13, 2012 8:36 pm
My pleasure in testing this awesome web UI :)
Works amazingly good on my iPad
npuser
Post Tue Aug 14, 2012 1:03 am
Thank you again Mark. You did it again.
NPuser
Xmantium
Post Thu Aug 16, 2012 10:05 am
Can anyone confirm Upload licence option is there on the latest version? Mark has gone on holiday (well deserved!)
I could not test this since ive already registered as PRO user
Ive got alot QNAP users asking how to apply the licence
Post Thu Aug 16, 2012 10:11 am
You can re-upload a license file as much as you want, Serviio will just use the most recent valid one.
Not there isn't an option, there is a place holder in the code, but it is commented out.
https://github.com/mpemberton5/Web-UI-f ... /about.php
Xmantium
Post Thu Aug 16, 2012 10:31 am
will wrote:Not there isn't an option, there is a place holder in the code, but it is commented out.
Well spotted Will, hopefully Mark can add this feature on the next build
I just have to tell QNAP users to use your ServiiDroid app or remotely connect the Windows console in the meantime
Post Thu Aug 16, 2012 10:51 am
They can also do it using curl
curl -i -H "Content-Type: plain/text; Accept: application/json" -X PUT "http://127.0.0.1:23423/rest/license-upload" -T Serviio_XXX.lic
Users browsing this forum: Baidu [Spider] and 8 guests
