Logitech Harmony
jorickdd
Post Thu Aug 16, 2012 11:38 am
Logitech Harmony
Hi!
I have a few problems with installing my Logitech Harmony 700 remote.
Is it possible to program the remote so, that if when I press the 'Watch a movie' button, the remote automatically selects Serviio from input?
As of now, I can only select fysical devices in the setup program I think...
Post Thu Aug 16, 2012 12:30 pm
Re: Logitech Harmony
Depends on what your TV menu needs to select Serviio. For my Samsung D model I programmed the following sequence, based on Serviio being available and the only DLNA server detected by the TV. This just emulates the buttons I need to press on the TV controller to do the same.
- TV Power On - Discrete
- TV InputPC
- TV Source (Recalls PC)
- TV Source (Displays "Serviio")
- TV Select - Servio (Displays "Videos")
- Pause 2 Sec (Time to Load Serviio)
- TV Select - "Videos" (Displays "Folders")
jorickdd
Post Thu Aug 16, 2012 4:57 pm
thanks i think i figured it out.
indeed when i press watch a movie, the remote just enters a sequence
Source
Downbutton 5 times
Select
End result is the same, but it would be better if there was just an option to select AllShare right from one button
Also from a Samsung D model btw :)
My TV also automatically recognizes another DLNA source, called Windows Media. Any idea how i can remove that?
jorickdd
Post Thu Aug 16, 2012 5:12 pm
Nvm, already figured that last thing out :)
Post Thu Aug 16, 2012 6:02 pm
Problem with using the down 5 times, is that if another source is added to the TV then the count is wrong. That's why I start with PC so I'm insulated from that.
Scoty
Post Thu Jul 23, 2015 10:42 am
jhb50 wrote:Depends on what your TV menu needs to select Serviio. For my Samsung D model I programmed the following sequence, based on Serviio being available and the only DLNA server detected by the TV. This just emulates the buttons I need to press on the TV controller to do the same.
- TV InputPC
Hi
I need you help. I have a Harmony 650 and use also the D Serie. Can you say what have you make for working Allshare Input?
Sorry my english is very bad.
