HD-Trailers.net
Moderator: martyn
CigDangle
Post Mon Dec 19, 2011 11:11 pm
HD-Trailers.net
The best RSS feed of recent movie trailers I have found. If someone has a better one, I'd be interested.
Test and works, although seem to be very bandwidth intensive...
http://feeds.hd-trailers.net/hd-trailers
Xbox 360 - PlayStation 3 - Sony BDP-S370 - HTC Evo V & HP TouchPad running CM9 (Android) - serviio 1.0.1 - Windows 2003 Server Standard x64 Edition
antz
Post Wed Dec 21, 2011 10:02 pm
Re: HD-Trailers.net
Tried it on my Samsung LA32D550 it keeps saying video codec not supported.
Is there a chance I can watch those trailers?
Post Wed Dec 21, 2011 11:33 pm
Re: HD-Trailers.net
might be fixed in 0.6.1
Post Thu Dec 22, 2011 12:02 am
Re: HD-Trailers.net
Don't know how it could work since its not a valid rss format, From what I can see it just turns around and uses apple trailers which others have been unable to get to work with Serviio.
Am I missing something?
devil2
Post Thu Dec 22, 2011 10:31 am
Re: HD-Trailers.net
Work for me on a Samsung c7000 :P
Post Thu Dec 22, 2011 11:12 am
Re: HD-Trailers.net
Thanks for posting. It made me try again. Last night at 6PM all the items refused to be added due to "not of type video"... this morning they all add except the apple trailer ones. Now I need to find out why that format of rss worked without a plugin!
Post Fri Dec 23, 2011 4:30 am
Re: HD-Trailers.net
Still confused about this one...posters say "it works" but many are apple feeds which do not work with serviio and others are slow download links which spend all their time loading and never play. So trying to find the few that do play seems pointless.
CigDangle
Post Fri Dec 30, 2011 1:08 am
Re: HD-Trailers.net
The feed works for me, but stops often, or requires me to pause the video long enough to buffer/download enough.
Eventually, I gave up and went on to another stream, but it does work. It's just too damn slow.
jt323bd
Post Sun Jan 08, 2012 2:42 pm
Re: HD-Trailers.net
This one may be better, using the youtube plugin.
A channel of all HD Major Motion Picture Trailers
http://gdata.youtube.com/feeds/api/user ... by=updated
Geronemo3
Post Sun Aug 19, 2012 3:12 am
Re: HD-Trailers.net
Where do i add the gdate.youtube file?
and after that what changes am i suppose to do in serviio console?
How are you guys adding these files and viewing them??
Do i need to make groovy files or add them somewhere?
What i am doing is going into lib/online resources/add.........now here i've added RSS feeds source URL and set Source as Online RSS.
After doing the above i can see the folder created by Serviio but those folders are empty....
Thanks for the help.
Post Sat Aug 31, 2013 12:40 pm
Re: HD-Trailers.net
Use the HDTrailers plugin now.
flyerblade
Post Wed Oct 29, 2014 11:32 pm
Re: HD-Trailers.net
Am running Serviio 1.4.1.2 (Std version) on Mac OS 10.10 (all up to date).
Have added the plug-ins inside the the Serviio App, rebooted the machine.
Tried lots of Web Resource URLs for BBC etc from this forum. All I ever get is an empty Online folder.
Got one RSS style feed to work (HD Trailers) but never any Web Resource ones.
Should this work on the std version of Serviio ? In v1.4.1.2 ? On a Mac ? Can't think what to try next. :?
tiya069
Post Fri Jun 19, 2015 8:46 am
Re: HD-Trailers.net
hortur
Post Thu Feb 21, 2019 6:10 pm
Re: HD-Trailers.net
CigDangle wrote:The best RSS feed of recent movie trailers I have found. If someone has a better one, I'd be interested.
Also having the same issue. Anyone?
Anyway thanks for sharing,this will work for some time.
Per aspera, ad astra, ad infinitum.
:D :ugeek: 8-)
Return to Films, TV & Comedy
