serviio 1.0 and 1.0.1 broken
strawsy
Post Sun Aug 19, 2012 3:38 am
Basically nothing shows up in any of my folders. Can connect to the server just fine but there isn't anything in my folders. Servioo 0.6.2 works perfect. I've read through the forums quite a bit but the closest thing I see is people having issues with some files not showing up. None of my files show up. I can see the folders but there isn't anything in them. I would love some help on this. I have tried this on windows 7, windows 8 and even ubuntu. Serviio 1.0 or 1.0.1 doesn't work.
grolschie
Post Sun Aug 19, 2012 7:48 am
Re: serviio 1.0 and 1.0.1 broken
More info please. What device are you trying to stream to?
Post Sun Aug 19, 2012 10:32 am
and post the log
strawsy
Post Sun Aug 19, 2012 7:13 pm
Well I've tried streaming to all my devices which are sony bravia, sony smp, lg tv, lg bluray, xbox. I reverted back to 0.6.2 and it is doing the same thing. Oh and I installed homestream to test it and it looks like it is taking over serviio. Same thing regargless. I get same issue either way.
2012-08-18 22:31:39,108 INFO [MediaServer] ------------------------------------------------------------------------
2012-08-18 22:31:39,109 INFO [MediaServer] Homestream DLNA media streaming server v 1.1 (rev. d545abee9a9a)
2012-08-18 22:31:39,109 INFO [MediaServer] (c) 2012 Penline Consulting Ltd.
2012-08-18 22:31:39,109 INFO [MediaServer] Powered by Serviio (www.serviio.org)
2012-08-18 22:31:39,109 INFO [MediaServer] Java 1.7.0_05-Oracle Corporation
2012-08-18 22:31:39,109 INFO [MediaServer] OS Windows NT (unknown) x86 6.2
2012-08-18 22:31:39,109 INFO [MediaServer] File encoding: windows-1252
2012-08-18 22:31:39,109 INFO [MediaServer] Headless mode enabled: true
2012-08-18 22:31:39,109 INFO [MediaServer] User home dir: C:\
2012-08-18 22:31:39,109 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-08-18 22:31:39,109 INFO [MediaServer] ------------------------------------------------------------------------
2012-08-18 22:31:39,187 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-08-18 22:31:39,220 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-08-18 22:31:48,021 INFO [DBSchemaUpdateExecutor] Updating DB schema
2012-08-18 22:32:01,048 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-08-18 22:32:01,290 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-08-18 22:32:01,414 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-08-18 22:32:01,648 INFO [ProfilesDefinitionParser] Added profile 'Sony BRAVIA' (id=9)
2012-08-18 22:32:01,977 INFO [ProfilesDefinitionParser] Added profile 'Sony Blu-ray / Blu-ray Home Theatre' (id=10)
2012-08-18 22:32:02,176 INFO [ProfilesDefinitionParser] Added profile 'Sony Netbox (SMP-Nx00)' (id=11)
2012-08-18 22:32:02,910 INFO [WebServer] Socket buffer set to 65535 bytes
2012-08-18 22:32:02,911 INFO [Device] Created UPnP Device with UUID: d346a009-dd96-377e-ab0a-411830ab4392, bound address: 192.168.11.46
2012-08-18 22:32:02,924 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Homestream\bin\..\plugins
2012-08-18 22:32:02,953 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-08-18 22:32:02,956 ERROR [MediaServer] cannot start web server, exiting
2012-08-18 22:32:02,957 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-08-18 22:32:02,959 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-08-18 22:32:02,961 INFO [DatabaseManager] Shutting down database
2012-08-18 22:32:05,261 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-08-18 22:33:30,755 INFO [ServiioConsole] Starting Serviio Console
2012-08-18 22:33:30,820 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-08-18 22:33:31,278 ERROR [ServiioConsole] Unexpected REST error: Internal Server Error (500) - checkForUpdates : checkForUpdates : checkForUpdates : checkForUpdates
---- Debugging information ----
message : checkForUpdates : checkForUpdates
cause-exception : com.thoughtworks.xstream.mapper.CannotResolveClassException
cause-message : checkForUpdates : checkForUpdates
class : org.serviio.ui.representation.ConsoleSettingsRepresentation
required-type : org.serviio.ui.representation.ConsoleSettingsRepresentation
path : /consoleSettings/checkForUpdates
2012-08-18 22:33:31,283 INFO [Messages] Loaded console message bundle for locale: en
2012-08-18 22:33:31,379 ERROR [ServiioConsole] Unexpected REST error: Internal Server Error (500) - edition : edition : edition : edition
message : edition : edition
cause-message : edition : edition
class : org.serviio.ui.representation.ApplicationRepresentation
required-type : org.serviio.ui.representation.ApplicationRepresentation
path : /application/edition
2012-08-18 22:33:31,380 ERROR [ServiioConsole] Unexpected exception occured: null
at org.serviio.console.ServiioConsole.main(ServiioConsole.java:110)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher.main(Unknown Source)
2012-08-18 22:33:31,387 INFO [ServiioConsole] Leaving Serviio Console
2012-08-18 22:33:50,275 INFO [ServiioConsole] Starting Serviio Console
2012-08-18 22:33:50,338 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-08-18 22:33:50,697 ERROR [ServiioConsole] Unexpected REST error: Internal Server Error (500) - checkForUpdates : checkForUpdates : checkForUpdates : checkForUpdates
2012-08-18 22:33:50,702 INFO [Messages] Loaded console message bundle for locale: en
2012-08-18 22:33:50,797 ERROR [ServiioConsole] Unexpected REST error: Internal Server Error (500) - edition : edition : edition : edition
2012-08-18 22:33:50,797 ERROR [ServiioConsole] Unexpected exception occured: null
2012-08-18 22:33:50,802 INFO [ServiioConsole] Leaving Serviio Console
2012-08-18 22:35:04,418 INFO [ServiioConsole] Starting Serviio Console
2012-08-18 22:35:04,480 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-08-18 22:35:04,882 ERROR [ServiioConsole] Unexpected REST error: Internal Server Error (500) - checkForUpdates : checkForUpdates : checkForUpdates : checkForUpdates
2012-08-18 22:35:04,887 INFO [Messages] Loaded console message bundle for locale: en
2012-08-18 22:35:04,982 ERROR [ServiioConsole] Unexpected REST error: Internal Server Error (500) - edition : edition : edition : edition
2012-08-18 22:35:04,982 ERROR [ServiioConsole] Unexpected exception occured: null
2012-08-18 22:35:04,987 INFO [ServiioConsole] Leaving Serviio Console
2012-08-18 22:48:48,113 INFO [ServiioConsole] Starting Serviio Console
2012-08-18 22:48:48,244 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-08-18 22:48:49,727 ERROR [ServiioConsole] Unexpected REST error: Internal Server Error (500) - checkForUpdates : checkForUpdates : checkForUpdates : checkForUpdates
2012-08-18 22:48:49,732 INFO [Messages] Loaded console message bundle for locale: en
2012-08-18 22:48:49,826 ERROR [ServiioConsole] Unexpected REST error: Internal Server Error (500) - edition : edition : edition : edition
2012-08-18 22:48:49,826 ERROR [ServiioConsole] Unexpected exception occured: null
2012-08-18 22:48:49,829 INFO [ServiioConsole] Leaving Serviio Console
2012-08-18 22:51:53,758 INFO [ServiioConsole] Starting Serviio Console
2012-08-18 22:51:53,820 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-08-18 22:52:04,061 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2012-08-18 22:52:16,049 ERROR [ServiioConsole] Unexpected REST error: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:16,049 INFO [Messages] Loaded console message bundle for locale: en
2012-08-18 22:52:19,118 ERROR [RepositoryView] Unexpected REST error: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:19,196 ERROR [StatusView] Unexpected REST error: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:19,586 ERROR [MetadataView] Unexpected REST error: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:19,633 ERROR [TranscodingView] Unexpected REST error: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:20,272 ERROR [PresentationView] Unexpected REST error: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:20,615 ERROR [SystemTrayView] Unexpected REST error: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:20,725 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:20,834 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:20,943 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:21,052 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:21,161 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:21,271 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:21,380 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:21,489 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:21,598 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:21,707 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:22,363 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:22,472 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:22,581 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:22,690 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:22,799 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:22,909 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:23,018 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:23,127 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Internal Server Error (500) - Internal Server Error
2012-08-18 22:52:40,537 WARN [StatusView] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2012-08-18 22:52:40,552 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:52:49,741 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:52:59,881 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:53:00,801 WARN [StatusView] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2012-08-18 22:53:10,052 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:53:10,973 WARN [StatusView] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2012-08-18 22:53:20,195 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:53:30,323 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:53:40,470 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:53:50,595 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:54:00,669 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:54:10,809 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:54:14,569 WARN [StatusView] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2012-08-18 22:54:20,981 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:54:31,183 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:54:41,323 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:54:51,439 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:55:01,563 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:55:11,703 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:55:21,859 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:55:31,999 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:55:42,139 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:55:52,342 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:56:02,503 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:56:12,652 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:56:22,793 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:56:32,979 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:56:43,182 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:56:53,369 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:57:03,509 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:57:13,649 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:57:23,820 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:57:33,992 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-08-18 22:57:41,948 INFO [ServiioConsole] Leaving Serviio Console
2012-08-19 10:15:50,400 INFO [MediaServer] Serviio server instance is already running
2012-08-19 10:15:50,509 INFO [MediaServer] ------------------------------------------------------------------------
2012-08-19 10:15:50,509 INFO [MediaServer] Homestream DLNA media streaming server v 1.1 (rev. d545abee9a9a)
2012-08-19 10:15:50,509 INFO [MediaServer] (c) 2012 Penline Consulting Ltd.
2012-08-19 10:15:50,509 INFO [MediaServer] Powered by Serviio (www.serviio.org)
2012-08-19 10:15:50,509 INFO [MediaServer] Java 1.7.0_05-Oracle Corporation
2012-08-19 10:15:50,509 INFO [MediaServer] OS Windows NT (unknown) x86 6.2
2012-08-19 10:15:50,509 INFO [MediaServer] File encoding: windows-1252
2012-08-19 10:15:50,509 INFO [MediaServer] Headless mode enabled: true
2012-08-19 10:15:50,509 INFO [MediaServer] User home dir: C:\
2012-08-19 10:15:50,509 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-08-19 10:15:50,774 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-08-19 10:15:50,821 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-08-19 10:15:54,316 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-08-19 10:15:54,643 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-08-19 10:15:54,768 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-08-19 10:15:55,002 INFO [ProfilesDefinitionParser] Added profile 'Sony BRAVIA' (id=9)
2012-08-19 10:15:55,330 INFO [ProfilesDefinitionParser] Added profile 'Sony Blu-ray / Blu-ray Home Theatre' (id=10)
2012-08-19 10:15:55,532 INFO [ProfilesDefinitionParser] Added profile 'Sony Netbox (SMP-Nx00)' (id=11)
2012-08-19 10:15:56,687 INFO [WebServer] Socket buffer set to 65535 bytes
2012-08-19 10:15:56,687 INFO [Device] Created UPnP Device with UUID: 30aa9ca7-d12a-30f8-9172-94b008f5cc4f, bound address: 127.0.0.1
2012-08-19 10:15:56,827 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Homestream\bin\..\plugins
2012-08-19 10:15:57,264 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-08-19 10:15:57,467 INFO [WebServer] WebServer starting on port 8895
2012-08-19 10:15:57,498 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-08-19 10:15:57,498 INFO [EventDispatcher] Starting EventDispatcher
2012-08-19 10:15:57,498 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-08-19 10:15:57,498 INFO [RendererSearchSender] Searching for Renderer devices
2012-08-19 10:15:57,498 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-08-19 10:15:57,540 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface lo (Software Loopback Interface 1) and address 127.0.0.1, timeout = 0
2012-08-19 10:16:18,500 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-08-19 10:16:18,500 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-08-19 10:16:18,828 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-08-19 10:16:18,844 INFO [ServiioConsole] Starting Serviio Console
2012-08-19 10:16:18,922 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-08-19 10:16:20,263 INFO [Messages] Loaded console message bundle for locale: en
2012-08-19 10:16:20,289 INFO [UpdateChecker] Checking if a new version is available
2012-08-19 10:16:31,412 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-08-19 10:16:31,796 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-08-19 12:45:15,486 INFO [ServiioConsole] Starting Serviio Console
2012-08-19 12:45:15,624 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-08-19 12:45:17,390 INFO [Messages] Loaded console message bundle for locale: en
2012-08-19 13:55:25,802 INFO [ServiioConsole] Leaving Serviio Console
2012-08-19 13:57:28,177 INFO [ServiioConsole] Starting Serviio Console
2012-08-19 13:57:28,271 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-08-19 13:57:29,254 INFO [Messages] Loaded console message bundle for locale: en
2012-08-19 14:26:17,214 INFO [ServiioConsole] Leaving Serviio Console
2012-08-19 14:52:11,333 INFO [ServiioConsole] Starting Serviio Console
2012-08-19 14:52:11,398 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-08-19 14:52:11,997 INFO [Messages] Loaded console message bundle for locale: en
2012-08-19 15:07:03,891 INFO [ServiioConsole] Leaving Serviio Console
Post Sun Aug 19, 2012 7:27 pm
It all looks very broken. try uninstalling all your java versions and get the latest one. Then try Serviio 1.0.1 (Homestream is based on 0.6.2), add your folders again and try then.
strawsy
Post Sun Aug 19, 2012 11:10 pm
Yeah it does look very broken. I will try uninstalling and then report back.
strawsy
Post Thu Aug 23, 2012 12:45 am
Ok so I got it working again on 0.6.2 after uninstaling java and reinstalling. Going to install the newest version when I get a chance.
Return to General discussion
