Cannot connect to serviio
Wingsgb
Post Sun Aug 19, 2012 5:02 pm
Iv recently just added a new profile to my profiles.xml and then done a restart. Upon load up of the windows screen after a few min of serviio not starting up the below error pops up.
Error
Cannot connect to serviio serveer, it dose not seem to be running. Exiting
I did a msconfig and made sure it was still selected on startup,
Post Sun Aug 19, 2012 8:02 pm
Re: Cannot connect to serviio
you probably damaged your profiles.xml with the change. Look at serviio.log, there should be a more descriptive error message.
Wingsgb
Post Sun Aug 19, 2012 11:24 pm
I always make a copy before changing anything, I did revert back but still got the error. I ended up doing a new install. I will try again tomorrow, if it occurs again I will log the error.
Users browsing this forum: Baidu [Spider] and 29 guests
