Samsung TV plays some .wtv files others fail
c957031
Post Sat Jul 14, 2012 9:37 pm
Serviio Wizards!!!
You guys have created an awesome piece of sw, thank you for that! :D
My setup is like this: I record DVB-T tv with a Windows 7 Media Center and store the files on a Linux (Ubuntu 12.04 LTS) server where I have my Serviio running. The TV Samsung UE32D6207 plays some files while others fail. When failing this is what ends up in the logs:
2012-07-14 22:52:43,129 WARN [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error.
2012-07-14 22:52:43,582 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:47)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:129)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:96)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:121)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:116)
Please find attached a text file with "media-info" on my test samples with both working and non-working examples:
(The above error was thrown by playing the file:
L:\\Bamses Lillebitte Billedbog_DR Ramasjang_2012_02_12_17_38_00.wtv
But this file worked fine:
L:\\Den travle by_DR1_2012_06_08_07_33_00.wtv)
I recognize that some of the params in the media-info are different from the files that work to the files that fail, but I have no idea how to configure my way out of it.
ANY ideas would be highly appreciated.
/David
PS: Please excuse me if this has already been answered before, I have spent some time browsing the forums without finding the clue.
test_files.txt
(7.15 KiB) Downloaded 650 times
Samsung TV UE32D6207
Samsung GALAXY TAB 7
Ubuntu 12.04 (LTS) server with Serviio Version 1.0.1
FFmpeg, built from GIT Aug 29 2012
Post Tue Jul 17, 2012 1:26 pm
Re: Samsung TV plays some .wtv files others fail
THere is some improvement on wtv files playback in 1.0, try it when it's out (couple of weeks max)
c957031
Post Tue Jul 17, 2012 9:22 pm
Thank you Zip
I got a little further, found the call to ffmpeg in the log. When run from a shell, it fails
Current (fails):
ffmpeg -i "/media/store/video/mp4/test/Bamses Lillebitte Billedbog_DR Ramasjang_2012_02_12_17_38_00.wtv" -y -async 1 -vcodec copy -vbsf h264_mp4toannexb -fflags +genpts -acodec copy -map 0:2 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-240-MPEG2TS.stf
Output attached.
Since it states that "copy" is not an option I tried to insert other options, mpeg4 and libx264, these work
Working (command line issued in the shell):
ffmpeg -i "/media/store/video/mp4/test/Bamses Lillebitte Billedbog_DR Ramasjang_2012_02_12_17_38_00.wtv" -y -async 1 -vcodec mpeg4 -vbsf h264_mp4toannexb -fflags +genpts -acodec copy -map 0:2 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-240-MPEG2TS.stf
ffmpeg -i "/media/store/video/mp4/test/Bamses Lillebitte Billedbog_DR Ramasjang_2012_02_12_17_38_00.wtv" -y -async 1 -vcodec libx264 -vbsf h264_mp4toannexb -fflags +genpts -acodec copy -map 0:2 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-240-MPEG2TS.stf
How can I tell serviio to use these options? (edit the profile?) OR Is this a bad way to solve my problem ?
Thanks for any help
/David
command_line_output.txt
(10.93 KiB) Downloaded 584 times
Post Tue Jul 17, 2012 10:17 pm
you can't change the parameters Serviio sends to FFmpeg. Wait for 1.0, hopefully it'll solve your problem.
c957031
Post Wed Jul 18, 2012 10:45 am
Thanks for your answer, I cannot wait for 1.0.
If you need some beta testing assistance I would gladly participate, especially around .wtv stuff.
In the mean time I made a minor hack to my ffmpeg (I had the source from git already) that would manipulate the command line arguments to fit my needs. Now I only have one problem left, but that does not belong in this thread. :)
/david
c957031
Post Mon Aug 20, 2012 9:05 am
HMMMRPFF
The upgrade to 1.0 and then 1.0.1 didn't do the trick for me.
I think in order to compare my result with everybody else's, I need to know which version of ffmpeg you recommend for serviio to perform best.
My ffmpeg is one I got from git about a month back:
ffmpeg version git-2012-07-06-60270eb
built on Jul 18 2012 10:44:22 with gcc 4.6.3
configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-nonfree --enable-version3 --enable-x11grab
libavformat 54. 15.100 / 54. 15.100
libavfilter 3. 0.101 / 3. 0.101
Anybody who can tell me what ffmpeg you are happy with and if possible where to get it (linux ubuntu compatible)
/David
Post Tue Aug 28, 2012 11:26 pm
You can download the sources on serviio.org
Users browsing this forum: Baidu [Spider] and 36 guests
