Unable to clear the online cache on 1.0.1.
Post Wed Aug 22, 2012 10:32 pm
I am attempting to clear my on-line cache using the process I think worked in previous versions
I erased C:\Program Files\Serviio\library\cache\online_technical_metadata.data
and C:\Program Files\Serviio\library\cache\online_technical_metadata.key
then restarted Serviio to rebuild the cache.
As you can see in the attached, the online sources are cached, but when I list them it says there are none.
When I look at the files online_technical_metadata.data has 14KB but online_technical_metadata.key is empty 0KB.
Is this a bug or have I done something wrong?
2012-08-22 10:11:50,499 INFO  [MediaServer] ------------------------------------------------------------------------
2012-08-22 10:11:50,499 INFO  [MediaServer] Serviio DLNA media streaming server v 1.0.1 (rev. 6dbf7c6e334f+)
2012-08-22 10:11:50,499 INFO  [MediaServer] Petr Nejedly 2009-2012
2012-08-22 10:11:50,500 INFO  [MediaServer] http://www.serviio.org
2012-08-22 10:11:50,500 INFO  [MediaServer] Java 1.7.0_04-Oracle Corporation
2012-08-22 10:11:50,500 INFO  [MediaServer] OS Windows 7 amd64 6.1
2012-08-22 10:11:50,500 INFO  [MediaServer] File encoding: windows-1252
2012-08-22 10:11:50,501 INFO  [MediaServer] Headless mode enabled: true
2012-08-22 10:11:50,501 INFO  [MediaServer] User home dir: C:\
2012-08-22 10:11:50,501 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2012-08-22 10:11:50,501 INFO  [MediaServer] ------------------------------------------------------------------------
2012-08-22 10:11:50,664 INFO  [WebServer] Socket buffer set to 65535 bytes
2012-08-22 10:11:50,667 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2012-08-22 10:11:50,716 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2012-08-22 10:11:50,716 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2012-08-22 10:11:50,743 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-08-22 10:11:50,758 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2012-08-22 10:11:52,322 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2012-08-22 10:11:52,323 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2012-08-22 10:11:52,324 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2012-08-22 10:11:52,325 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2012-08-22 10:11:52,326 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2012-08-22 10:11:52,327 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2012-08-22 10:11:52,328 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2012-08-22 10:11:52,328 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2012-08-22 10:11:52,329 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2012-08-22 10:11:52,330 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2012-08-22 10:11:52,331 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2012-08-22 10:11:52,332 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2012-08-22 10:11:52,354 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2012-08-22 10:11:52,541 INFO  [MediaServer] ------------------------------------------------------------------------
2012-08-22 10:11:52,541 INFO  [MediaServer] License: PRO (NORMAL, id: 7403f813-625d-43b8-a9cb-d9f71361f4c0)
2012-08-22 10:11:52,939 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2012-08-22 10:11:53,037 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2012-08-22 10:11:54,012 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-08-22 10:11:54,013 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2012-08-22 10:11:54,668 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-08-22 10:11:54,670 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2012-08-22 10:11:54,839 DEBUG [ServiioConsole] Initializing Serviio Console
2012-08-22 10:11:54,875 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2012-08-22 10:11:54,878 INFO  [ServiioConsole] Starting Serviio Console
2012-08-22 10:11:54,955 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2012-08-22 10:11:55,020 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-08-22 10:11:55,025 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-08-22 10:11:55,027 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2012-08-22 10:11:55,593 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-08-22 10:11:55,594 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2012-08-22 10:11:56,019 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-08-22 10:11:56,021 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2012-08-22 10:11:56,231 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-08-22 10:11:56,233 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2012-08-22 10:11:57,011 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2012-08-22 10:11:57,014 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2012-08-22 10:11:57,060 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-08-22 10:11:57,062 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2012-08-22 10:11:58,118 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2012-08-22 10:11:58,121 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2012-08-22 10:11:59,259 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-08-22 10:11:59,262 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2012-08-22 10:11:59,717 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-08-22 10:11:59,720 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2012-08-22 10:12:00,062 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-08-22 10:12:00,064 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2012-08-22 10:12:00,117 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-08-22 10:12:00,119 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2012-08-22 10:12:00,323 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-08-22 10:12:00,325 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2012-08-22 10:12:00,419 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-08-22 10:12:00,422 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2012-08-22 10:12:00,821 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-08-22 10:12:00,823 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2012-08-22 10:12:00,889 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2012-08-22 10:12:00,891 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2012-08-22 10:12:01,246 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2012-08-22 10:12:01,248 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2012-08-22 10:12:01,687 INFO  [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-08-22 10:12:01,691 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2012-08-22 10:12:01,862 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2012-08-22 10:12:01,864 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2012-08-22 10:12:01,944 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2012-08-22 10:12:01,947 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2012-08-22 10:12:02,717 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2012-08-22 10:12:02,719 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011
2012-08-22 10:12:02,826 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2012-08-22 10:12:02,829 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2012-08-22 10:12:02,927 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2012-08-22 10:12:02,929 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2012-08-22 10:12:03,131 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2012-08-22 10:12:03,134 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2012-08-22 10:12:03,285 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2012-08-22 10:12:03,287 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile DroidOrig
2012-08-22 10:12:03,561 INFO  [ProfilesDefinitionParser] Added profile 'Android Orig BubbleUPnP' (id=DroidOrig)
2012-08-22 10:12:03,564 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile DroidHi1
2012-08-22 10:12:03,786 INFO  [ProfilesDefinitionParser] Added profile 'Android High 1 BubbleUPnP' (id=DroidHi1)
2012-08-22 10:12:03,790 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile DroidHi2
2012-08-22 10:12:04,028 INFO  [ProfilesDefinitionParser] Added profile 'Android High 2 BubbleUPnP' (id=DroidHi2)
2012-08-22 10:12:04,032 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile DroidHi3
2012-08-22 10:12:04,237 INFO  [ProfilesDefinitionParser] Added profile 'Android High 3 BubbleUPnP' (id=DroidHi3)
2012-08-22 10:12:04,240 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile DroidHi4
2012-08-22 10:12:04,459 INFO  [ProfilesDefinitionParser] Added profile 'Android High 4 BubbleUPnP' (id=DroidHi4)
2012-08-22 10:12:04,461 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile DroidMed1
2012-08-22 10:12:04,670 INFO  [ProfilesDefinitionParser] Added profile 'Android Medium 1 BubbleUPnP' (id=DroidMed1)
2012-08-22 10:12:04,672 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile DroidMed2
2012-08-22 10:12:04,903 INFO  [ProfilesDefinitionParser] Added profile 'Android Medium 2 BubbleUPnP' (id=DroidMed2)
2012-08-22 10:12:04,905 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile DroidMed3
2012-08-22 10:12:05,142 INFO  [ProfilesDefinitionParser] Added profile 'Android Medium 3 BubbleUPnP' (id=DroidMed3)
2012-08-22 10:12:05,145 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile DroidMed4
2012-08-22 10:12:05,371 INFO  [ProfilesDefinitionParser] Added profile 'Android Medium 4 BubbleUPnP' (id=DroidMed4)
2012-08-22 10:12:05,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile DroidMed5
2012-08-22 10:12:05,598 INFO  [ProfilesDefinitionParser] Added profile 'Android Medium 5 BubbleUPnP' (id=DroidMed5)
2012-08-22 10:12:05,601 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile DroidMed6
2012-08-22 10:12:05,921 INFO  [ProfilesDefinitionParser] Added profile 'Android Medium 6 BubbleUPnP' (id=DroidMed6)
2012-08-22 10:12:05,924 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile DroidMed7
2012-08-22 10:12:06,158 INFO  [ProfilesDefinitionParser] Added profile 'Android Medium 7 BubbleUPnP' (id=DroidMed7)
2012-08-22 10:12:06,161 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile DroidMed8
2012-08-22 10:12:06,446 INFO  [ProfilesDefinitionParser] Added profile 'Android Medium 8 BubbleUPnP' (id=DroidMed8)
2012-08-22 10:12:06,449 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile Android
2012-08-22 10:12:06,722 INFO  [ProfilesDefinitionParser] Added profile 'BubbleUPnP' (id=Android)
2012-08-22 10:12:06,768 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2012-08-22 10:12:06,778 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2012-08-22 10:12:07,209 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2012-08-22 10:12:07,210 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo
2012-08-22 10:12:07,524 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2012-08-22 10:12:08,183 INFO  [Device] Created UPnP Device with UUID: 8dee68fe-0370-3fc8-a5f5-ae4a1fb10a65, bound address: 192.168.1.10
2012-08-22 10:12:08,210 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-08-22 10:12:08,211 INFO  [PluginCompilerThread] Started looking for plugins
2012-08-22 10:12:08,212 DEBUG [PluginCompilerThread] Starting plugin APVideo.groovy compilation
2012-08-22 10:12:08,213 INFO  [UpdateChecker] Checking if a new version is available
2012-08-22 10:12:08,221 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2012-08-22 10:12:08,227 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2012-08-22 10:12:08,447 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-08-22 10:12:08,448 DEBUG [AbstractTranscodingDeliveryEngine] Deleting temporary transcoded files from: C:\Windows\Temp\Serviio\Serviio
2012-08-22 10:12:08,501 INFO  [WebServer] WebServer starting on port 8895
2012-08-22 10:12:08,507 DEBUG [DiscoveryManager] UPNP device 8dee68fe-0370-3fc8-a5f5-ae4a1fb10a65 (192.168.1.10) is available
2012-08-22 10:12:08,508 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-08-22 10:12:08,508 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-08-22 10:12:08,508 INFO  [EventDispatcher] Starting EventDispatcher
2012-08-22 10:12:08,515 INFO  [RendererSearchSender] Searching for Renderer devices
2012-08-22 10:12:08,515 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2012-08-22 10:12:08,556 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net4 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.1.10, timeout = 0
2012-08-22 10:12:09,291 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface net4 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.1.10, timeout = 0
2012-08-22 10:12:09,304 INFO  [PluginCompilerThread] Added Web Resouce plugin APVideo (APVideo.groovy)
2012-08-22 10:12:09,305 DEBUG [PluginCompilerThread] Starting plugin Castalba.groovy compilation
2012-08-22 10:12:09,314 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2012-08-22 10:12:09,330 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.10:65343
2012-08-22 10:12:09,330 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2012-08-22 10:12:09,335 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net4 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.1.10, timeout = 0
2012-08-22 10:12:09,337 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 8dee68fe-0370-3fc8-a5f5-ae4a1fb10a65
2012-08-22 10:12:09,364 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.10:65343
2012-08-22 10:12:09,364 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2012-08-22 10:12:09,366 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.10:65343
2012-08-22 10:12:09,366 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2012-08-22 10:12:09,512 DEBUG [WebServer] Incoming connection from /192.168.1.10:51040
2012-08-22 10:12:09,515 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2012-08-22 10:12:09,518 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8dee68fe-0370-3fc8-a5f5-ae4a1fb10a65 from 192.168.1.10 (headers = [User-Agent: Azureus 4.2.0.2,Connection: close,Accept-Encoding: gzip,Host: 192.168.1.10:8895,Accept: text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2])
2012-08-22 10:12:09,518 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2012-08-22 10:12:09,519 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [User-Agent: Azureus 4.2.0.2,Connection: close,Accept-Encoding: gzip,Host: 192.168.1.10:8895,Accept: text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2]
2012-08-22 10:12:09,521 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2012-08-22 10:12:09,538 INFO  [PluginCompilerThread] Added Web Resouce plugin Castalba (Castalba.groovy)
2012-08-22 10:12:09,538 DEBUG [PluginCompilerThread] Starting plugin Channel4od.groovy compilation
2012-08-22 10:12:09,866 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-08-22 10:12:10,310 INFO  [PluginCompilerThread] Added Web Resouce plugin 4OD (UK only) (Channel4od.groovy)
2012-08-22 10:12:10,310 DEBUG [PluginCompilerThread] Starting plugin Cleeseblog.groovy compilation
2012-08-22 10:12:10,377 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.10:57538
2012-08-22 10:12:10,378 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2012-08-22 10:12:10,380 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.10:57538
2012-08-22 10:12:10,387 INFO  [PluginCompilerThread] Added Feed plugin Cleeseblog (Cleeseblog.groovy)
2012-08-22 10:12:10,387 DEBUG [PluginCompilerThread] Starting plugin CNN.groovy compilation
2012-08-22 10:12:10,612 INFO  [PluginCompilerThread] Added Feed plugin CNN (CNN.groovy)
2012-08-22 10:12:10,613 DEBUG [PluginCompilerThread] Starting plugin Crackle.groovy compilation
2012-08-22 10:12:10,669 INFO  [PluginCompilerThread] Added Feed plugin Crackle (Crackle.groovy)
2012-08-22 10:12:10,669 DEBUG [PluginCompilerThread] Starting plugin CW.groovy compilation
2012-08-22 10:12:10,800 INFO  [PluginCompilerThread] Added Web Resouce plugin cwtv.com (CW.groovy)
2012-08-22 10:12:10,800 DEBUG [PluginCompilerThread] Starting plugin HaHaSport.groovy compilation
2012-08-22 10:12:11,227 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2012-08-22 10:12:11,424 INFO  [PluginCompilerThread] Added Web Resouce plugin HaHaSport (HaHaSport.groovy)
2012-08-22 10:12:11,424 DEBUG [PluginCompilerThread] Starting plugin HDTrailers.groovy compilation
2012-08-22 10:12:11,617 INFO  [PluginCompilerThread] Added Web Resouce plugin HDTrailers (HDTrailers.groovy)
2012-08-22 10:12:11,618 DEBUG [PluginCompilerThread] Starting plugin Hypem.groovy compilation
2012-08-22 10:12:11,721 INFO  [PluginCompilerThread] Added Feed plugin Hypem (Hypem.groovy)
2012-08-22 10:12:11,721 DEBUG [PluginCompilerThread] Starting plugin ILive.groovy compilation
2012-08-22 10:12:11,881 INFO  [PluginCompilerThread] Added Web Resouce plugin ILive (ILive.groovy)
2012-08-22 10:12:11,882 DEBUG [PluginCompilerThread] Starting plugin IPlayer.groovy compilation
2012-08-22 10:12:12,279 INFO  [PluginCompilerThread] Added Feed plugin BBC iPlayer (UK only) (IPlayer.groovy)
2012-08-22 10:12:12,279 DEBUG [PluginCompilerThread] Starting plugin LiveFeeds.groovy compilation
2012-08-22 10:12:12,347 INFO  [PluginCompilerThread] Added Feed plugin LiveFeeds (LiveFeeds.groovy)
2012-08-22 10:12:12,347 DEBUG [PluginCompilerThread] Starting plugin LiveFeedx.groovy compilation
2012-08-22 10:12:12,418 INFO  [PluginCompilerThread] Added Feed plugin LiveFeedx (LiveFeedx.groovy)
2012-08-22 10:12:12,418 DEBUG [PluginCompilerThread] Starting plugin LocalFeeds.groovy compilation
2012-08-22 10:12:12,477 INFO  [PluginCompilerThread] Added Feed plugin LocalFeeds (LocalFeeds.groovy)
2012-08-22 10:12:12,477 DEBUG [PluginCompilerThread] Starting plugin MyiPlayer.groovy compilation
2012-08-22 10:12:13,066 INFO  [PluginCompilerThread] Added Web Resouce plugin myiplayer.com (MyiPlayer.groovy)
2012-08-22 10:12:13,067 DEBUG [PluginCompilerThread] Starting plugin PBS.groovy compilation
2012-08-22 10:12:13,119 INFO  [PluginCompilerThread] Added Feed plugin PBSURLExtractor (PBS.groovy)
2012-08-22 10:12:13,119 DEBUG [PluginCompilerThread] Starting plugin PornHub.groovy compilation
2012-08-22 10:12:13,228 INFO  [PluginCompilerThread] Added Web Resouce plugin PornHub (PornHub.groovy)
2012-08-22 10:12:13,228 DEBUG [PluginCompilerThread] Starting plugin Rage.groovy compilation
2012-08-22 10:12:13,364 INFO  [PluginCompilerThread] Added Web Resouce plugin Rage (Rage.groovy)
2012-08-22 10:12:13,364 DEBUG [PluginCompilerThread] Starting plugin Refresh.groovy compilation
2012-08-22 10:12:13,454 INFO  [PluginCompilerThread] Added Web Resouce plugin Refresh (Refresh.groovy)
2012-08-22 10:12:13,454 DEBUG [PluginCompilerThread] Starting plugin ReutersCom.groovy compilation
2012-08-22 10:12:13,517 INFO  [PluginCompilerThread] Added Feed plugin ReutersCom (ReutersCom.groovy)
2012-08-22 10:12:13,518 DEBUG [PluginCompilerThread] Starting plugin RTVE.groovy compilation
2012-08-22 10:12:13,599 INFO  [PluginCompilerThread] Added Feed plugin RTVE (RTVE.groovy)
2012-08-22 10:12:13,599 DEBUG [PluginCompilerThread] Starting plugin S4c.groovy compilation
2012-08-22 10:12:13,676 INFO  [PluginCompilerThread] Added Feed plugin S4cUrlExtractor (S4c.groovy)
2012-08-22 10:12:13,676 DEBUG [PluginCompilerThread] Starting plugin Shoutcast.groovy compilation
2012-08-22 10:12:13,748 INFO  [PluginCompilerThread] Added Web Resouce plugin Shoutcast (Shoutcast.groovy)
2012-08-22 10:12:13,748 DEBUG [PluginCompilerThread] Starting plugin Top100.groovy compilation
2012-08-22 10:12:13,904 INFO  [PluginCompilerThread] Added Web Resouce plugin YouTubeTop100 (Top100.groovy)
2012-08-22 10:12:13,904 DEBUG [PluginCompilerThread] Starting plugin TrailerAddictRss.groovy compilation
2012-08-22 10:12:13,967 INFO  [PluginCompilerThread] Added Feed plugin TrailerAddictRss (TrailerAddictRss.groovy)
2012-08-22 10:12:13,967 DEBUG [PluginCompilerThread] Starting plugin TuneIn.groovy compilation
2012-08-22 10:12:14,173 INFO  [PluginCompilerThread] Added Web Resouce plugin Tune In (TuneIn.groovy)
2012-08-22 10:12:14,173 DEBUG [PluginCompilerThread] Starting plugin USTREAM.groovy compilation
2012-08-22 10:12:14,263 INFO  [PluginCompilerThread] Added Web Resouce plugin ustream.tv (USTREAM.groovy)
2012-08-22 10:12:14,264 DEBUG [PluginCompilerThread] Starting plugin Vimeo.groovy compilation
2012-08-22 10:12:14,312 INFO  [PluginCompilerThread] Added Feed plugin Vimeo (Vimeo.groovy)
2012-08-22 10:12:14,312 DEBUG [PluginCompilerThread] Starting plugin WimpCom.groovy compilation
2012-08-22 10:12:14,365 INFO  [PluginCompilerThread] Added Feed plugin WimpCom (WimpCom.groovy)
2012-08-22 10:12:14,366 DEBUG [PluginCompilerThread] Starting plugin Youtube.groovy compilation
2012-08-22 10:12:14,480 INFO  [PluginCompilerThread] Added Feed plugin YouTube (Youtube.groovy)
2012-08-22 10:12:15,315 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2012-08-22 10:12:15,737 DEBUG [ServiioConsole] Retrieving console settings
2012-08-22 10:12:15,841 DEBUG [ServiioConsole] Setting console locale to be: en
2012-08-22 10:12:15,850 INFO  [Messages] Loaded console message bundle for locale: en
2012-08-22 10:12:16,081 DEBUG [ServiioFrameView] Initializing main frame
2012-08-22 10:12:16,105 DEBUG [ServiioFrameView] System tray is supported
2012-08-22 10:12:16,322 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups
2012-08-22 10:12:16,825 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-08-22 10:12:16,866 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for Repository (id = 1)
2012-08-22 10:12:16,938 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for Repository (id = 2)
2012-08-22 10:12:16,939 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for Repository (id = 3)
2012-08-22 10:12:16,940 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for Repository (id = 4)
2012-08-22 10:12:16,942 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for Repository (id = 5)
2012-08-22 10:12:16,943 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for Repository (id = 6)
2012-08-22 10:12:16,944 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for Repository (id = 7)
2012-08-22 10:12:16,948 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-22 10:12:16,974 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for OnlineRepository (id = 6)
2012-08-22 10:12:17,086 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for OnlineRepository (id = 86)
2012-08-22 10:12:17,723 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-08-22 10:12:18,022 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups
2012-08-22 10:12:18,424 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2012-08-22 10:12:18,443 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2012-08-22 10:12:19,259 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-08-22 10:12:19,265 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=0, titleKey=pc5dczc_media_library, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = null
2012-08-22 10:12:19,301 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A, titleKey=audio, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2012-08-22 10:12:19,308 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_A, titleKey=artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:19,317 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,324 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,330 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,339 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,348 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=AL_A, titleKey=album_artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:19,376 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,383 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,390 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForAlbumArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,398 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,406 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:19,417 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=local_default
2012-08-22 10:12:19,425 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:19,433 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioGenresByNameCommand, containerClass=MUSIC_GENRE, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,440 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForGenreCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,458 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_C, titleKey=composers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:19,465 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,472 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposersForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=COM, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,480 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForComposerCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,486 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForComposerAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,494 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:19,500 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,508 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForInitialCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,517 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_R, titleKey=random, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2012-08-22 10:12:19,523 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListRandomSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=no_cache
2012-08-22 10:12:19,531 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:19,537 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioPlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,545 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForPlaylistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,552 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2012-08-22 10:12:19,561 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2012-08-22 10:12:19,569 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_S, titleKey=All songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2012-08-22 10:12:19,578 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,586 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_AS, titleKey=Artist Songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2012-08-22 10:12:19,592 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART_S, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,600 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,606 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_ALB, titleKey=All albums, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2012-08-22 10:12:19,616 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,623 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,629 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I, titleKey=image, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2012-08-22 10:12:19,638 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_A, titleKey=albums, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:19,644 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListFlatImageFoldersByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,653 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForFolderCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,661 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:19,669 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=local_default
2012-08-22 10:12:19,676 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_Y, titleKey=year, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:19,682 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,692 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,700 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_T, titleKey=month, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:19,708 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,715 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationMonthsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=MON, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,722 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationMonthAndYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,729 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:19,736 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagePlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,746 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForPlaylistCommand, containerClass=null, itemClass=PHOTO, idPrefix=S, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,753 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2012-08-22 10:12:19,761 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2012-08-22 10:12:19,768 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_AI, titleKey=All images, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2012-08-22 10:12:19,778 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListAllImagesCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,785 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V, titleKey=video, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2012-08-22 10:12:19,792 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:19,800 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,807 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,818 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_M, titleKey=movies, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:19,827 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosByNameCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,836 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_S, titleKey=series, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:19,842 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeriesByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SER, recursive=false, cacheRegion=local_resetafterplay
2012-08-22 10:12:19,857 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeasonsForSeriesCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SSN, recursive=false, cacheRegion=local_resetafterplay
2012-08-22 10:12:19,867 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListEpisodesForSeriesSeasonCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2012-08-22 10:12:19,874 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:19,882 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=local_default
2012-08-22 10:12:19,889 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LV, titleKey=last_viewed, class=CONTAINER, cacheRegion=local_resetafterplay, browsable = null, editable = true
2012-08-22 10:12:19,899 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastViewedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2012-08-22 10:12:19,907 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LA, titleKey=last_added, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:19,915 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastAddedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,925 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:19,938 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoGenresByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,947 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForGenreCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,955 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_A, titleKey=actors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:19,963 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,971 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,982 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForActorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-08-22 10:12:19,989 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_D, titleKey=directors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:19,998 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2012-08-22 10:12:20,005 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2012-08-22 10:12:20,013 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForDirectorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-08-22 10:12:20,024 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_P, titleKey=producers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:20,031 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2012-08-22 10:12:20,040 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducersForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2012-08-22 10:12:20,048 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForProducerCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-08-22 10:12:20,061 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-08-22 10:12:20,069 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoPlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
Log continued in next post
Post Wed Aug 22, 2012 10:34 pm
Re: Unable to clear the online cache on 1.0.1. Continued
Remainder of log
2012-08-22 10:12:20,077 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForPlaylistCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=S, recursive=false, cacheRegion=local_default
2012-08-22 10:12:20,084 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2012-08-22 10:12:20,095 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2012-08-22 10:12:20,100 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-08-22 10:12:20,657 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-08-22 10:12:20,659 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for Repository (id = 1)
2012-08-22 10:12:20,667 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for Repository (id = 7)
2012-08-22 10:12:20,668 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-22 10:12:20,676 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for OnlineRepository (id = 6)
2012-08-22 10:12:20,743 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for OnlineRepository (id = 86)
2012-08-22 10:12:20,984 DEBUG [ServiioConsole] Reading application data
2012-08-22 10:12:20,985 DEBUG [RepositoryView$LibraryStatusCheckerThread] Starting library status checking thread
2012-08-22 10:12:21,663 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net4 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.1.10, timeout = 0
2012-08-22 10:12:21,665 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 8dee68fe-0370-3fc8-a5f5-ae4a1fb10a65
2012-08-22 10:12:23,465 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2012-08-22 10:12:33,899 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net4 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.1.10, timeout = 0
2012-08-22 10:12:33,900 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 8dee68fe-0370-3fc8-a5f5-ae4a1fb10a65
2012-08-22 10:12:35,318 INFO  [FeedUpdaterThread] Started looking for information about online resources
2012-08-22 10:12:35,318 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-08-22 10:12:35,318 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-22 10:12:35,320 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2012-08-22 10:12:35,324 DEBUG [PlaylistDAOImpl] Reading all Playlists
2012-08-22 10:12:35,329 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 26)
2012-08-22 10:12:35,346 DEBUG [OnlineContentCacheDecorator] Stored online content 'rtmp://cp105185.live.edgefcs.net:1935/live/ swfUrl=http://www.citytv.com/swf/NowPlaying.swf pageURL=http://www.citytv.com/toronto/citynews/video/liveplayer playpath=Citynewsch_online@15402 live=1' in the cache (online_feeds), returning it
2012-08-22 10:12:35,347 DEBUG [FeedUpdaterThread] Retrieving information about the video stream 'rtmp://cp105185.live.edgefcs.net:1935/live/ swfUrl=http://www.citytv.com/swf/NowPlaying.swf pageURL=http://www.citytv.com/toronto/citynews/video/liveplayer playpath=Citynewsch_online@15402 live=1'
2012-08-22 10:12:35,350 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: rtmp://cp105185.live.edgefcs.net:1935/live/ swfUrl=http://www.citytv.com/swf/NowPlaying.swf pageURL=http://www.citytv.com/toronto/citynews/video/liveplayer playpath=Citynewsch_online@15402 live=1
2012-08-22 10:12:35,350 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i rtmp://cp105185.live.edgefcs.net:1935/live/ swfUrl=http://www.citytv.com/swf/NowPlaying.swf pageURL=http://www.citytv.com/toronto/citynews/video/liveplayer playpath=Citynewsch_online@15402 live=1
2012-08-22 10:12:35,364 DEBUG [PlaylistMaintainerThread] Playlist ALL MUSIC FOR WIIMC+ has unresolved items, checking if they are in the library now
2012-08-22 10:12:35,365 DEBUG [PlaylistParser] Parsing playlist 'D:\My Music\- Playlists\ALL MUSIC FOR WIIMC+.m3u'
2012-08-22 10:12:35,365 DEBUG [PlaylistParser] Reading playlist from a local file
2012-08-22 10:12:35,409 DEBUG [PlaylistParser] Found a suitable playlist parser strategy: M3UParserStrategy
2012-08-22 10:12:35,641 DEBUG [PlaylistDAOImpl] Reading items for playlist 9
2012-08-22 10:12:35,754 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:39
2012-08-22 10:12:35,879 DEBUG [PlaylistMaintainerThread] Found playlist item that has not been added yet: D:\My Music\Freddy Fender - Forever Gold (2000)\Freddy Fender - Forever Gold 01 - Wasted Days And Wasted Nights.mp3
2012-08-22 10:12:35,880 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\My Music\Freddy Fender - Forever Gold (2000)\Freddy Fender - Forever Gold 01 - Wasted Days And Wasted Nights.mp3, ignore case: true
2012-08-22 10:12:35,931 DEBUG [PlaylistMaintainerThread] Item 'D:\My Music\Freddy Fender - Forever Gold (2000)\Freddy Fender - Forever Gold 01 - Wasted Days And Wasted Nights.mp3' cannot be resolved to an entity in the Serviio library, will try again later
2012-08-22 10:12:39,986 DEBUG [FFmpegMetadataRetriever] Retrieving H264 profile/level for file 'rtmp://cp105185.live.edgefcs.net:1935/live/ swfUrl=http://www.citytv.com/swf/NowPlaying.swf pageURL=http://www.citytv.com/toronto/citynews/video/liveplayer playpath=Citynewsch_online@15402 live=1'
2012-08-22 10:12:39,986 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve H264 header for file: rtmp://cp105185.live.edgefcs.net:1935/live/ swfUrl=http://www.citytv.com/swf/NowPlaying.swf pageURL=http://www.citytv.com/toronto/citynews/video/liveplayer playpath=Citynewsch_online@15402 live=1
2012-08-22 10:12:39,986 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i rtmp://cp105185.live.edgefcs.net:1935/live/ swfUrl=http://www.citytv.com/swf/NowPlaying.swf pageURL=http://www.citytv.com/toronto/citynews/video/liveplayer playpath=Citynewsch_online@15402 live=1 -frames:v 1 -c:v copy -f h264 -vbsf h264_mp4toannexb -an pipe:
2012-08-22 10:12:43,514 DEBUG [FFmpegMetadataRetriever] H264 Level value stored in the AVC header (3.2) is different than one based on ref_frames value (1.3), the higher will be stored
2012-08-22 10:12:43,515 DEBUG [FFmpegMetadataRetriever] File 'rtmp://cp105185.live.edgefcs.net:1935/live/ swfUrl=http://www.citytv.com/swf/NowPlaying.swf pageURL=http://www.citytv.com/toronto/citynews/video/liveplayer playpath=Citynewsch_online@15402 live=1' has H264 profile MAIN, level 3.2 and 2 ref frames
2012-08-22 10:12:43,516 DEBUG [TechnicalMetadataCacheDecorator] Stored technical metadata for online item 'rtmp://cp105185.live.edgefcs.net:1935/live/ swfUrl=http://www.citytv.com/swf/NowPlaying.swf pageURL=http://www.citytv.com/toronto/citynews/video/liveplayer playpath=Citynewsch_online@15402 live=1' in the cache (online_technical_metadata), returning it
2012-08-22 10:12:43,516 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 76)
2012-08-22 10:12:43,518 DEBUG [OnlineContentCacheDecorator] Stored online content 'http://127.0.0.1:8902' in the cache (online_feeds), returning it
2012-08-22 10:12:43,518 DEBUG [FeedUpdaterThread] Retrieving information about the video stream 'http://127.0.0.1:8902'
2012-08-22 10:12:43,518 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: http://127.0.0.1:8902
2012-08-22 10:12:43,518 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i http://127.0.0.1:8902
2012-08-22 10:12:45,039 DEBUG [FFmpegMetadataRetriever] Retrieving H264 profile/level for file 'http://127.0.0.1:8902'
2012-08-22 10:12:45,039 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve H264 header for file: http://127.0.0.1:8902
2012-08-22 10:12:45,039 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i http://127.0.0.1:8902 -frames:v 1 -c:v copy -f h264 -an pipe:
2012-08-22 10:12:46,586 DEBUG [FFmpegMetadataRetriever] File 'http://127.0.0.1:8902' has H264 profile BASELINE, level 1 and 1 ref frames
2012-08-22 10:12:46,586 DEBUG [TechnicalMetadataCacheDecorator] Stored technical metadata for online item 'http://127.0.0.1:8902' in the cache (online_technical_metadata), returning it
2012-08-22 10:12:46,586 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 80)
2012-08-22 10:12:46,588 DEBUG [OnlineContentCacheDecorator] Stored online content 'http://194.28.91.43:8080/esp_russian-8b3f33d1a1e1ca1e20669fbdfb31493d' in the cache (online_feeds), returning it
2012-08-22 10:12:46,588 DEBUG [FeedUpdaterThread] Retrieving information about the video stream 'http://194.28.91.43:8080/esp_russian-8b3f33d1a1e1ca1e20669fbdfb31493d'
2012-08-22 10:12:46,588 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: http://194.28.91.43:8080/esp_russian-8b3f33d1a1e1ca1e20669fbdfb31493d
2012-08-22 10:12:46,588 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i http://194.28.91.43:8080/esp_russian-8b3f33d1a1e1ca1e20669fbdfb31493d
2012-08-22 10:12:48,196 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2012-08-22 10:12:56,335 DEBUG [TechnicalMetadataCacheDecorator] Stored technical metadata for online item 'http://194.28.91.43:8080/esp_russian-8b3f33d1a1e1ca1e20669fbdfb31493d' in the cache (online_technical_metadata), returning it
2012-08-22 10:12:56,335 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 81)
2012-08-22 10:12:56,336 DEBUG [OnlineContentCacheDecorator] Stored online content 'http://192.168.1.10:8081' in the cache (online_feeds), returning it
2012-08-22 10:12:56,337 DEBUG [FeedUpdaterThread] Retrieving information about the video stream 'http://192.168.1.10:8081'
2012-08-22 10:12:56,337 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: http://192.168.1.10:8081
2012-08-22 10:12:56,339 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i http://192.168.1.10:8081
2012-08-22 10:12:58,196 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2012-08-22 10:13:02,308 DEBUG [TechnicalMetadataCacheDecorator] Stored technical metadata for online item 'http://192.168.1.10:8081' in the cache (online_technical_metadata), returning it
2012-08-22 10:13:02,308 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 82)
2012-08-22 10:13:02,309 DEBUG [OnlineContentCacheDecorator] Stored online content 'http://77.51.249.16:8103' in the cache (online_feeds), returning it
2012-08-22 10:13:02,309 DEBUG [FeedUpdaterThread] Retrieving information about the video stream 'http://77.51.249.16:8103'
2012-08-22 10:13:02,310 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: http://77.51.249.16:8103
2012-08-22 10:13:02,310 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i http://77.51.249.16:8103
2012-08-22 10:13:03,197 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2012-08-22 10:13:08,359 DEBUG [FFmpegMetadataRetriever] Retrieving H264 profile/level for file 'http://77.51.249.16:8103'
2012-08-22 10:13:08,359 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve H264 header for file: http://77.51.249.16:8103
2012-08-22 10:13:08,360 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i http://77.51.249.16:8103 -frames:v 1 -c:v copy -f h264 -an pipe:
2012-08-22 10:13:10,516 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.10:57538
2012-08-22 10:13:10,516 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2012-08-22 10:13:10,518 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.10:57538
2012-08-22 10:13:15,753 DEBUG [FFmpegMetadataRetriever] File 'http://77.51.249.16:8103' has H264 profile HIGH, level 3.2 and 5 ref frames
2012-08-22 10:13:15,754 DEBUG [TechnicalMetadataCacheDecorator] Stored technical metadata for online item 'http://77.51.249.16:8103' in the cache (online_technical_metadata), returning it
2012-08-22 10:13:15,754 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 83)
2012-08-22 10:13:15,755 DEBUG [OnlineContentCacheDecorator] Stored online content 'http://localhost:8902' in the cache (online_feeds), returning it
2012-08-22 10:13:15,755 DEBUG [FeedUpdaterThread] Retrieving information about the video stream 'http://localhost:8902'
2012-08-22 10:13:15,755 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: http://localhost:8902
2012-08-22 10:13:15,756 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i http://localhost:8902
2012-08-22 10:13:15,923 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net4 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.1.10, timeout = 0
2012-08-22 10:13:15,925 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 8dee68fe-0370-3fc8-a5f5-ae4a1fb10a65
2012-08-22 10:13:17,726 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:51
2012-08-22 10:13:18,198 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2012-08-22 10:13:22,320 DEBUG [FFmpegMetadataRetriever] Retrieving H264 profile/level for file 'http://localhost:8902'
2012-08-22 10:13:22,321 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve H264 header for file: http://localhost:8902
2012-08-22 10:13:22,321 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i http://localhost:8902 -frames:v 1 -c:v copy -f h264 -an pipe:
2012-08-22 10:13:28,876 DEBUG [FFmpegMetadataRetriever] File 'http://localhost:8902' has H264 profile BASELINE, level 1 and 1 ref frames
2012-08-22 10:13:28,877 DEBUG [TechnicalMetadataCacheDecorator] Stored technical metadata for online item 'http://localhost:8902' in the cache (online_technical_metadata), returning it
2012-08-22 10:13:28,877 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 84)
2012-08-22 10:13:28,878 DEBUG [OnlineContentCacheDecorator] Stored online content 'http://localhost:8081' in the cache (online_feeds), returning it
2012-08-22 10:13:28,878 DEBUG [FeedUpdaterThread] Retrieving information about the video stream 'http://localhost:8081'
2012-08-22 10:13:28,878 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: http://localhost:8081
2012-08-22 10:13:28,878 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i http://localhost:8081
2012-08-22 10:13:33,198 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2012-08-22 10:13:34,842 DEBUG [TechnicalMetadataCacheDecorator] Stored technical metadata for online item 'http://localhost:8081' in the cache (online_technical_metadata), returning it
2012-08-22 10:13:34,842 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 85)
2012-08-22 10:13:34,843 DEBUG [OnlineContentCacheDecorator] Stored online content 'http://192.168.1.10:8902' in the cache (online_feeds), returning it
2012-08-22 10:13:34,844 DEBUG [FeedUpdaterThread] Retrieving information about the video stream 'http://192.168.1.10:8902'
2012-08-22 10:13:34,844 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: http://192.168.1.10:8902
2012-08-22 10:13:34,844 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i http://192.168.1.10:8902
2012-08-22 10:13:36,389 DEBUG [FFmpegMetadataRetriever] Retrieving H264 profile/level for file 'http://192.168.1.10:8902'
2012-08-22 10:13:36,389 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve H264 header for file: http://192.168.1.10:8902
2012-08-22 10:13:36,389 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i http://192.168.1.10:8902 -frames:v 1 -c:v copy -f h264 -an pipe:
2012-08-22 10:13:37,912 DEBUG [FFmpegMetadataRetriever] H264 Level value stored in the AVC header (1) is different than one based on ref_frames value (1.3), the higher will be stored
2012-08-22 10:13:37,913 DEBUG [FFmpegMetadataRetriever] File 'http://192.168.1.10:8902' has H264 profile BASELINE, level 1.3 and 1 ref frames
2012-08-22 10:13:37,913 DEBUG [TechnicalMetadataCacheDecorator] Stored technical metadata for online item 'http://192.168.1.10:8902' in the cache (online_technical_metadata), returning it
2012-08-22 10:13:37,913 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 86)
2012-08-22 10:13:37,914 DEBUG [OnlineContentCacheDecorator] Stored online content 'http://127.0.0.1:8081' in the cache (online_feeds), returning it
2012-08-22 10:13:37,914 DEBUG [FeedUpdaterThread] Retrieving information about the video stream 'http://127.0.0.1:8081'
2012-08-22 10:13:37,914 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: http://127.0.0.1:8081
2012-08-22 10:13:37,916 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i http://127.0.0.1:8081
2012-08-22 10:13:38,199 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2012-08-22 10:13:44,140 DEBUG [TechnicalMetadataCacheDecorator] Stored technical metadata for online item 'http://127.0.0.1:8081' in the cache (online_technical_metadata), returning it
2012-08-22 10:13:48,199 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2012-08-22 10:14:09,673 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net4 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.1.10, timeout = 0
2012-08-22 10:14:09,674 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 8dee68fe-0370-3fc8-a5f5-ae4a1fb10a65
2012-08-22 10:14:10,687 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.10:57538
2012-08-22 10:14:10,687 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2012-08-22 10:14:10,689 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.10:57538
2012-08-22 10:14:11,475 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:37
2012-08-22 10:14:44,140 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-08-22 10:14:44,140 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-22 10:14:44,149 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 26)
2012-08-22 10:14:44,150 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 76)
2012-08-22 10:14:44,150 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 80)
2012-08-22 10:14:44,151 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 81)
2012-08-22 10:14:44,152 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 82)
2012-08-22 10:14:44,152 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 83)
2012-08-22 10:14:44,153 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 84)
2012-08-22 10:14:44,154 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 85)
2012-08-22 10:14:44,155 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 86)
2012-08-22 10:14:49,049 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net4 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.1.10, timeout = 0
2012-08-22 10:14:49,050 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 8dee68fe-0370-3fc8-a5f5-ae4a1fb10a65
2012-08-22 10:14:50,850 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:51
2012-08-22 10:15:10,820 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.10:57538
2012-08-22 10:15:10,820 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2012-08-22 10:15:10,822 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.10:57538
2012-08-22 10:15:42,861 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net4 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.1.10, timeout = 0
2012-08-22 10:15:42,862 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 8dee68fe-0370-3fc8-a5f5-ae4a1fb10a65
2012-08-22 10:15:44,156 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-08-22 10:15:44,156 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-22 10:15:44,162 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 26)
2012-08-22 10:15:44,163 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 76)
2012-08-22 10:15:44,163 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 80)
2012-08-22 10:15:44,164 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 81)
2012-08-22 10:15:44,165 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 82)
2012-08-22 10:15:44,165 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 83)
2012-08-22 10:15:44,166 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 84)
2012-08-22 10:15:44,170 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 85)
2012-08-22 10:15:44,171 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 86)
2012-08-22 10:15:44,663 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:37
2012-08-22 10:16:10,954 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.10:57538
2012-08-22 10:16:10,954 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2012-08-22 10:16:10,956 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.10:57538
2012-08-22 10:16:12,575 DEBUG [LoginServerResource] Successful login, generating security token
2012-08-22 10:16:13,322 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for AUDIO [Any]
2012-08-22 10:16:13,348 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for IMAGE [Any]
2012-08-22 10:16:13,353 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [Any]
2012-08-22 10:16:14,980 DEBUG [RepositoryDAOImpl] Retrieving list of Repositories for VIDEO (from=0, count=2147483647) [Any]
2012-08-22 10:16:15,014 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: CONTAINERS) [Any]
2012-08-22 10:16:15,225 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: CONTAINERS) [Any]
2012-08-22 10:16:15,289 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: CONTAINERS) [Any]
2012-08-22 10:16:15,350 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: CONTAINERS) [Any]
2012-08-22 10:16:15,417 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: CONTAINERS) [Any]
2012-08-22 10:16:15,481 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [Any]
2012-08-22 10:16:15,502 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [Any]
2012-08-22 10:16:17,784 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [Any]
2012-08-22 10:16:17,787 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [Any]
2012-08-22 10:16:18,984 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [Any]
2012-08-22 10:16:19,003 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000260001 and profile Flash player
2012-08-22 10:16:19,007 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtmp://cp105185.live.edgefcs.net:1935/live/ swfUrl=http://www.citytv.com/swf/NowPlaying.swf pageURL=http://www.citytv.com/toronto/citynews/video/liveplayer playpath=Citynewsch_online@15402 live=1: FLV
2012-08-22 10:16:19,010 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000760001 and profile Flash player
2012-08-22 10:16:19,011 ERROR [ContainerNode] Cannot retrieve results of action command: Cannot execute library command for list: null
org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: null
   at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItemList(AbstractCommand.java:135)
   at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.executeListAction(ContainerNode.java:242)
   at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.findContainerItems(ContainerNode.java:182)
   at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.retrieveContainerItems(ContainerNode.java:83)
   at org.serviio.upnp.service.contentdirectory.ContentDirectoryEngine.browse(ContentDirectoryEngine.java:102)
   at org.serviio.upnp.service.contentdirectory.rest.resources.server.CDSBrowseServerResource.browse(CDSBrowseServerResource.java:108)
   at org.restlet.resource.ServerResource.doHandle(ServerResource.java:449)
   at org.restlet.resource.ServerResource.get(ServerResource.java:645)
   at org.restlet.resource.ServerResource.doHandle(ServerResource.java:527)
   at org.restlet.resource.ServerResource.doNegotiatedHandle(ServerResource.java:587)
   at org.restlet.resource.ServerResource.doConditionalHandle(ServerResource.java:299)
   at org.serviio.restlet.AbstractProEditionServerResource.doConditionalHandle(AbstractProEditionServerResource.java:35)
   at org.serviio.upnp.service.contentdirectory.rest.resources.server.AbstractCDSServerResource.doConditionalHandle(AbstractCDSServerResource.java:50)
   at org.serviio.upnp.service.contentdirectory.rest.resources.server.AbstractRestrictedCDSServerResource.doConditionalHandle(AbstractRestrictedCDSServerResource.java:53)
   at org.restlet.resource.ServerResource.handle(ServerResource.java:846)
   at org.restlet.resource.Finder.handle(Finder.java:510)
   at org.restlet.routing.Filter.doHandle(Filter.java:156)
   at org.restlet.routing.Filter.handle(Filter.java:203)
   at org.restlet.routing.Router.doHandle(Router.java:497)
   at org.restlet.routing.Router.handle(Router.java:737)
   at org.restlet.engine.application.StatusFilter.doHandle(StatusFilter.java:151)
   at org.restlet.engine.ChainHelper.handle(ChainHelper.java:111)
   at org.restlet.engine.application.ApplicationHelper.handle(ApplicationHelper.java:72)
   at org.restlet.Application.handle(Application.java:388)
   at org.restlet.Component.handle(Component.java:388)
   at org.restlet.Server.handle(Server.java:488)
   at org.restlet.engine.http.connector.BaseServerHelper.handle(BaseServerHelper.java:158)
   at org.restlet.engine.http.connector.BaseServerHelper.handleInbound(BaseServerHelper.java:167)
   at org.restlet.engine.http.connector.BaseHelper.handleNextInbound(BaseHelper.java:418)
   at org.restlet.engine.http.connector.Connection.readMessages(Connection.java:695)
   at org.restlet.engine.http.connector.Controller$2.run(Controller.java:95)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
   at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.NullPointerException
   at org.serviio.dlna.MediaFormatProfileResolver.resolveVideoMPEG2TSFormat(MediaFormatProfileResolver.java:258)
   at org.serviio.dlna.MediaFormatProfileResolver.resolveVideoFormat(MediaFormatProfileResolver.java:100)
   at org.serviio.dlna.MediaFormatProfileResolver.resolve(MediaFormatProfileResolver.java:48)
   at org.serviio.delivery.resource.VideoDeliveryEngine.retrieveOriginalMediaInfo(VideoDeliveryEngine.java:79)
   at org.serviio.delivery.resource.VideoDeliveryEngine.retrieveOriginalMediaInfo(VideoDeliveryEngine.java:45)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.getMediaInfoForProfile(AbstractDeliveryEngine.java:70)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.getMediaInfoForAvailableProfiles(MediaResourceRetrievalStrategy.java:74)
   at org.serviio.upnp.service.contentdirectory.command.ResourceValuesBuilder.buildResources(ResourceValuesBuilder.java:58)
   at org.serviio.upnp.service.contentdirectory.command.AbstractListOnlineObjectsByHierarchyCommand.retrieveList(AbstractListOnlineObjectsByHierarchyCommand.java:126)
   at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItemList(AbstractCommand.java:129)
   ... 57 more
2012-08-22 10:16:23,006 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net4 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.1.10, timeout = 0
2012-08-22 10:16:23,007 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 8dee68fe-0370-3fc8-a5f5-ae4a1fb10a65
2012-08-22 10:16:24,807 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:59
2012-08-22 10:16:44,171 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-08-22 10:16:44,171 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-22 10:16:44,177 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 26)
2012-08-22 10:16:44,178 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 76)
2012-08-22 10:16:44,178 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 80)
2012-08-22 10:16:44,179 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 81)
2012-08-22 10:16:44,180 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 82)
2012-08-22 10:16:44,180 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 83)
2012-08-22 10:16:44,181 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 84)
2012-08-22 10:16:44,182 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 85)
2012-08-22 10:16:44,182 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 86)
Post Wed Aug 22, 2012 11:55 pm
I dont know how the caching system stores the data, I just delete the whole cache folder.
Post Thu Aug 23, 2012 12:31 am
Huh? Isn't it your code?
You are correct, the cache folder itself must be deleted. It will not work if both the metadata and thumbnails are deleted leaving an empty cache folder.
Never seen anything like that. Should be sufficient to delete the data files.
Post Mon Aug 27, 2012 10:19 pm
It's a library.
Users browsing this forum: No registered users and 125 guests
