MKVs with Dolby are unsupported TX L37ET5b
kram
Post Sun Sep 02, 2012 4:26 pm
I have made some MKV files of a couple of blu rays I have, some have DTSHD and some are DolbyHD or whatever the HD formats are called.
Anyway, the MKVs with the DTS sound track play fine but the Dolby ones are according to the TV and unsupported sound format, is this actually true or is it a profile problem? I have Transcoding turned off in Serviio, turning on transcoding will probably make it work but im trying to figure out what the TV will play on its own.
Is that TVUPNP thing from the Intel tools I posted above supposed to tell me what the TV can play without transcoding?
Post Mon Sep 03, 2012 7:51 am
Re: MKVs with Dolby are unsupported
kram wrote:-the MKVs with the DTS sound track play fine...
- but the Dolby ones are according to the TV and unsupported sound format,
So only audio tracks are different ?
kram wrote:I have Transcoding turned off in Serviio, turning on transcoding will probably make it work but im trying to figure out what the TV will play on its own.
I try to understand:
When transcoding turned off, all files are delivered in native format (without trascoding), so you can figure out what the TV will support.
Could you give some example that play fine, and other that failed?
When transcoding turned on, what formats play fine ?
kram
Post Tue Sep 04, 2012 11:46 am
Ok, Ill start again. My original enquiry was just this 'Does my TV TX-l37ET5B play MKV files with the Dolby TrueHD sound track? '
I have found a couple of profile errors for my TV so the topic is now a bit wider than originally.In Serviio the TV is set as Panasonic VIErA Panasonic Viera G/GT/DT/UT/VT (2011/2012)
Intel tools UPNP thing.
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_FLAGS=8c900000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED;DLNA.ORG_FLAGS=8c900000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG;DLNA.ORG_FLAGS=8c900000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_FLAGS=8c900000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM_ICO;DLNA.ORG_FLAGS=8c900000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG_ICO;DLNA.ORG_FLAGS=8c900000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL_XAC3;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_PS_PAL;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_PS_PAL_XAC3;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC_XAC3;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_PS_NTSC;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_PS_NTSC_XAC3;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_AC3_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_AC3_ISO;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_50_AC3_ISO;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_EU_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_EU;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_TS_SD_EU_ISO;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_EU_AC3_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_TS_SD_EU_AC3_ISO;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_50_AC3_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_50_AC3;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_AVC_TS_HD_50_AC3_ISO;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_JP_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_JP_MPEG1_L2_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_JP_AAC_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_AC3_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_X_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_60_AC3_ISO;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_T;DLNA.ORG_FLAGS=8d100000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_JP_T;ARIB.OR.JP_PN=MPEG_TTS_CP;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_JP_MPEG1_L2_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_JP_AAC_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_NA_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_NA;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_TS_SD_NA_ISO;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_HD_NA_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_HD_NA;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_TS_HD_NA_ISO;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_60_AC3_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_60_AC3_X_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_60_AC3_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_60_AC3;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_AVC_TS_HD_60_AC3_ISO;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_24_AC3_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_24_AC3;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_AVC_TS_HD_24_AC3_ISO;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_MP_HD_AAC_LTP_T;DLNA.ORG_FLAGS=8d118000000000000000000000000000,
http-get:*:audio/L16:DLNA.ORG_PN=LPCM,
http-get:*:image/jpeg:PANASONIC.COM_PN=MPO_3D,
http-get:*:image/jpeg:*,
http-get:*:video/avi:*,
http-get:*:video/x-msvideo:*,
http-get:*:video/divx:*,
http-get:*:video/x-matroska:*,
http-get:*:video/mpeg:*,
http-get:*:video/vnd.dlna.mpeg-tts:*,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":*,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":*,
http-get:*:video/mp4:*,
http-get:*:video/quicktime:*,
http-get:*:video/x-flv:*,
http-get:*:video/flv:*,
http-get:*:video/x-ms-wmv:*,
http-get:*:video/x-ms-asf:*,
http-get:*:video/3gpp:*,
http-get:*:video/3gpp2:*,
http-get:*:audio/mpeg:*,
http-get:*:audio/mp4:*,
http-get:*:audio/x-ms-wma:*,
http-get:*:audio/x-ms-asf:*,
http-get:*:audio/flac:*,
http-get:*:audio/x-flac:*,
http-get:*:audio/aac:*,
http-get:*:audio/x-aac:*,
http-get:*:audio/vnd.dlna.adts:*,
http-get:*:audio/L16:*
With Transcoding turned OFF my Blu ray rips with DTS HD format play audio fine, the rips with DOLBY True HD are unsupported audio format according to the TV. Below are two Media infos of a DTS file and a Dolby file.
Unique ID                        : 316379217847383383102414771278660720647 (0xEE046BC2F27E5F6673FA030A41D35807)
Complete name                    : E:\MKV\Let the right one in.mkv
Format                           : Matroska
File size                        : 18.4 GiB
Duration                         : 1h 54mn
Overall bit rate                 : 22.9 Mbps
Encoded date                     : UTC 2012-09-02 09:38:51
Writing application              : MakeMKV v1.7.7 win(x64-release)
Writing library                  : libmakemkv v1.7.7 (1.2.0/1.1.0) win(x64-release)
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 4 frames
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 1h 54mn
Bit rate mode                    : Variable
Bit rate                         : 19.7 Mbps
Maximum bit rate                 : 38.0 Mbps
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Frame rate                       : 23.976 fps
Standard                         : NTSC
Bits/(Pixel*Frame)               : 0.397
Stream size                      : 15.8 GiB (86%)
Language                         : English
Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Format                           : DTS
Format/Info                      : Digital Theater Systems
Format profile                   : MA / Core
Codec ID                         : A_DTS
Duration                         : 1h 54mn
Bit rate                         : 2 704 Kbps / 1 510 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 24 bits
Compression mode                 : Lossless / Lossy
Delay relative to video          : 2s 85ms
Title                            : Lossless
Language                         : English
Text
Format                           : PGS
Codec ID                         : S_HDMV/PGS
Codec ID/Info                    : The same subtitle format used on BDs/HD-DVDs
Language                         : English
Menu
00:00:00.000                     : en:Chapter 00
00:06:53.996                     : en:Chapter 01
00:12:30.708                     : en:Chapter 02
00:18:36.406                     : en:Chapter 03
00:22:53.580                     : en:Chapter 04
00:29:18.882                     : en:Chapter 05
00:34:51.506                     : en:Chapter 06
00:40:27.591                     : en:Chapter 07
00:45:48.704                     : en:Chapter 08
00:50:22.436                     : en:Chapter 09
00:58:06.191                     : en:Chapter 10
01:02:24.157                     : en:Chapter 11
01:07:56.280                     : en:Chapter 12
01:13:27.569                     : en:Chapter 13
01:18:26.910                     : en:Chapter 14
01:25:03.306                     : en:Chapter 15
01:29:32.617                     : en:Chapter 16
01:35:23.426                     : en:Chapter 17
01:40:36.780                     : en:Chapter 18
01:46:38.183                     : en:Chapter 19
Unique ID                        : 56225934193739579113450064335564959718 (0x2A4CB89584FFBAB1B8D5B2C6816FEFE6)
Complete name                    : E:\MKV\Super_8_t00.mkv
Format                           : Matroska
File size                        : 21.0 GiB
Duration                         : 1h 51mn
Overall bit rate                 : 26.8 Mbps
Movie name                       : Super 8
Encoded date                     : UTC 2012-08-31 22:41:59
Duration                         : 1h 51mn
Maximum bit rate                 : 32.5 Mbps
Language                         : English
Format                           : TrueHD
Codec ID                         : A_TRUEHD
Duration                         : 1h 51mn
Maximum bit rate                 : 6 273 Kbps
Channel(s)                       : 8 channels
Channel positions                : Front: L C R, Side: L R, Back: L R, LFE
Bit depth                        : 24 bits
Title                            : 7.1
Language                         : English
Text
Format                           : PGS
Language                         : English
Menu
00:07:01.504                     : en:Chapter 01
00:11:33.275                     : en:Chapter 02
00:19:25.164                     : en:Chapter 03
00:26:43.518                     : en:Chapter 04
00:33:36.514                     : en:Chapter 05
00:40:30.511                     : en:Chapter 06
00:45:42.156                     : en:Chapter 07
00:51:57.114                     : en:Chapter 08
00:56:59.958                     : en:Chapter 09
01:02:24.365                     : en:Chapter 10
01:08:12.505                     : en:Chapter 11
01:13:30.906                     : en:Chapter 12
01:18:33.875                     : en:Chapter 13
01:25:31.334                     : en:Chapter 14
01:30:25.378                     : en:Chapter 15
01:38:20.352                     : en:Chapter 16
01:43:37.836                     : en:Chapter 17
Now with Transcoding turned ON, both of these files DO NOT PLAY, its an unsupported video format according to the TV.
This MKV works fine with either Transcoding ON or OFF.
Unique ID                        : 181143889308254211057109131483539462529 (0x88470B47EB5F8F127057BF036F525981)
Complete name                    : C:\Users\Mark\Videos\Test Videos\AmosOcean_DivXPlus_10Mbps.mkv
Format                           : Matroska
File size                        : 86.2 MiB
Duration                         : 1mn 20s
Overall bit rate                 : 9 006 Kbps
Movie name                       : AMOS Ocean
Writing application              : DivXMKVMux Version 1.4.3.0014
Writing library                  : libDivXMediaFormat 3.5.3.0014
Cover                            : true type font / true type font / true type font / true type font / true type font / true type font / true type font
Format profile                   : High@L4.0
Duration                         : 1mn 20s
Bit rate                         : 8 699 Kbps
Maximum bit rate                 : 20.0 Mbps
Frame rate                       : 29.970 fps
Standard                         : NTSC
Bits/(Pixel*Frame)               : 0.140
Stream size                      : 83.3 MiB (97%)
Title                            : AMOS Ocean
Language                         : English
Format                           : MPEG Audio
Format version                   : Version 1
Format profile                   : Layer 3
Mode                             : Joint stereo
Codec ID                         : A_MPEG/L3
Codec ID/Hint                    : MP3
Duration                         : 1mn 20s
Bit rate                         : 128 Kbps
Channel(s)                       : 2 channels
Sampling rate                    : 44.1 KHz
Delay relative to video          : 26ms
Stream size                      : 1.22 MiB (1%)
Title                            : MP3 Stereo
Writing library                  : LAME3.92
Language                         : English
Text #1
Format                           : UTF-8
Codec ID                         : S_TEXT/UTF8
Codec ID/Info                    : UTF-8 Plain Text
Title                            : English
Language                         : English
Text #2
Format                           : UTF-8
Title                            : German
Language                         : German
Text #3
Format                           : UTF-8
Title                            : Spanish
Language                         : Spanish
Text #4
Format                           : UTF-8
Title                            : French
Language                         : French
Text #5
Format                           : UTF-8
Title                            : Japanese
Language                         : Japanese
Text #6
Format                           : UTF-8
Title                            : Simplified Chinese
Language                         : Chinese
Text #7
Format                           : UTF-8
Title                            : Traditional Chinese
Language                         : Chinese
Menu
00:00:00.000                     : en:Chapter 1
00:00:06.552                     : en:Chapter 2
00:00:15.136                     : en:Chapter 3
00:00:33.103                     : en:Chapter 4
00:00:40.629                     : en:Chapter 5
00:00:50.978                     : en:Chapter 6
00:01:00.363                     : en:Chapter 7
00:01:15.371                     : en:Chapter 8
I have also found other files that are listed differenty on the TV depending if Transcoding is either on or off.
EG FLAC files show up as LPCM with Transcoding ON, the TV is capable of playing FLAC nativly.
An MP4 file is listed as VIdeo on the TV with transcoding ON, with it OFF it is listed as on MP4, the tv is capable of playing it either way.
There is probably more but that will do for now.
Post Tue Sep 04, 2012 7:07 pm
kram wrote:Ok, Ill start again. My original enquiry was just this 'Does my TV TX-l37ET5B play MKV files with the Dolby TrueHD sound track? '
Thanks for Intel tools UPNP, I add the result on Wiki : http://wiki.serviio.org/doku.php?id=dev ... #panasonic
Could you report from INTEL TOOLS, the following element for your model number:
<friendlyName>VIERA ???</friendlyName>
<manufacturer>Panasonic</manufacturer>
<modelName>Panasonic VIErA</modelName>
kram wrote:I have found a couple of profile errors for my TV so the topic is now a bit wider than originally.In Serviio the TV is set as Panasonic VIErA Panasonic Viera G/GT/DT/UT/VT (2011/2012)
OK, so with this profile
- when transcoding is ON:
    MATROSKA/H264/TRUEHD should be transcoded to MPEGTS/H264/AC3
    MATROSKA/H264/DTS should be delivered in native format (inherit of generic profile)
- when transcoding is OFF:
All MATROSKA should be delivered in native format
kram wrote:With Transcoding turned OFF my Blu ray rips with DTS HD format play audio fine, the rips with DOLBY True HD are unsupported audio format according to the TV.
So this means that MATROSKA/H264/DTS are supported, but MATROSKA/H264/TRUEHD are not supported by the TV.
Could you select "Generic Profile" on serviio console and check that you have the same previous result (DTS supported, TRUEHD not supported)
If you have MATROSKA/H264/AC3 on your database, could you check if your TV support it.
kram wrote:Now with Transcoding turned ON, both of these files DO NOT PLAY, its an unsupported video format according to the TV.
Humm...both not supported !! Don't really anderstand, MATROSKA/DTS should be delivered in native format.
Could you enable detailed logging (see signature link) then check if this file is transcoded?
kram wrote:This MKV works fine with either Transcoding ON or OFF.
This means that MATROSKA/H264/MP3 are supported in native format.
Could you try with "Generic Profile" selected with the same file?
kram wrote:I have also found other files that are listed differenty on the TV depending if Transcoding is either on or off.
Following protocol are supported with your model number
Then you can comment <Matches container="flac" /> element on Audio Transcoding section.
Also I see :
So you probably could comment <Matches container="asf" /> too
Idem with
comment <Matches container="adts" /> too
kram wrote:An MP4 file is listed as VIdeo on the TV with transcoding ON, with it OFF it is listed as on MP4, the tv is capable of playing it either way.
Provide information about that file.
kram
Post Tue Sep 04, 2012 10:44 pm
Here is the MP4 media info, Ill get to the rest tomorrow.
Complete name                    : C:\Users\Mark\Videos\Muse - The 2nd Law - Unsustainable_COMPUTER.mp4
Format                           : MPEG-4
Format profile                   : Base Media / Version 2
Codec ID                         : mp42
File size                        : 317 MiB
Duration                         : 3mn 47s
Overall bit rate                 : 11.7 Mbps
Encoded date                     : UTC 2012-08-09 14:33:48
Tagged date                      : UTC 2012-08-09 14:33:55
©TIM                             : 01:00:01:03
©TSC                             : 25
©TSZ                             : 1
Format settings, ReFrames        : 3 frames
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Duration                         : 3mn 47s
Bit rate                         : 11.5 Mbps
Width                            : 1 280 pixels
Height                           : 720 pixels
Frame rate mode                  : Constant
Frame rate                       : 25.000 fps
Standard                         : PAL
Bits/(Pixel*Frame)               : 0.498
Stream size                      : 311 MiB (98%)
Language                         : English
Tagged date                      : UTC 2012-08-09 14:33:48
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format profile                   : LC
Codec ID                         : 40
Duration                         : 3mn 47s
Bit rate                         : 221 Kbps
Maximum bit rate                 : 322 Kbps
Channel positions                : Front: L R
Stream size                      : 6.00 MiB (2%)
Language                         : English
Thanks for helping.
Mark.
kram
Post Wed Sep 05, 2012 3:52 pm
Ok I changed to the generic profile and the results were the same as with the Panasonic profile selected and no transcoding. MVK with DTDHD plays, MKV with TrueHD dosent play sound and every file seems to be labled correctly on on the TV as well.
I found a MKV with AC3 to download from the serviio Wiki, its the Batman clip. It dosent play smoothley at all, video and audio work but its impossable to watch. Its the same with Panasonic or Generic profile.
Unique ID                        : 188017269999033100256956102686422996934 (0x8D72CF1CF01C3164A64E0A24948A17C6)
Complete name                    : C:\Users\Mark\Videos\Batman.Begins.1080p.HDDVD.x264-ESiR-Sample.mkv
Format                           : Matroska
File size                        : 68.7 MiB
Duration                         : 1mn 1s
Overall bit rate                 : 9 337 Kbps
Encoded date                     : UTC 2007-02-01 22:22:35
Writing application              : mkvmerge v2.0.0 ('After The Rain Has Fallen') built on Jan 16 2007 21:09:33
Writing library                  : libebml v0.7.7 + libmatroska v0.8.1
Format profile                   : High@L5.1
Format settings, ReFrames        : 8 frames
Duration                         : 1mn 1s
Bit rate                         : 8 703 Kbps
Height                           : 800 pixels
Display aspect ratio             : 2.40:1
Original frame rate              : 24.000 fps
Bits/(Pixel*Frame)               : 0.236
Stream size                      : 64.0 MiB (93%)
Language                         : English
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : A_AC3
Duration                         : 1mn 1s
Bit rate                         : 448 Kbps
Bit depth                        : 16 bits
Delay relative to video          : 8ms
Stream size                      : 3.30 MiB (5%)
Language                         : English
Next I tried this file, its a WMV file, with transcoding off there is no audio.
Complete name                    : C:\Users\Mark\Videos\The Fifth Element 16x9 720p WM9 HD-DVD.wmv
Format                           : Windows Media
File size                        : 4.33 GiB
Duration                         : 2h 5mn
Overall bit rate mode            : Variable
Overall bit rate                 : 4 921 Kbps
Maximum Overall bit rate         : 35.2 Mbps
Movie name                       : 'The Fifth Element' WM9 HD-DVD 1280x720p
Encoded date                     : UTC 2003-08-18 03:30:39.140
Format                           : VC-1
Format profile                   : MP@HL
Codec ID                         : WMV3
Codec ID/Info                    : Windows Media Video 9
Codec ID/Hint                    : WMV3
Description of the codec         : Windows Media Video 9 - Professional
Duration                         : 2h 5mn
Bit rate                         : 4 420 Kbps
Height                           : 720 pixels
Bits/(Pixel*Frame)               : 0.200
Stream size                      : 3.89 GiB (90%)
Language                         : English (US)
Format                           : WMA
Format profile                   : Pro
Codec ID                         : 162
Codec ID/Info                    : Windows Media Audio
Description of the codec         : Windows Media Audio 9 Professional - 384 kbps, 48 kHz, 5.1 channel 24 bit 2-pass VBR
Duration                         : 2h 5mn
Bit rate                         : 386 Kbps
Bit depth                        : 24 bits
Stream size                      : 347 MiB (8%)
Intel Tools reports the Friendly Name as VIERA ET5 Series,
Model name as Panasonic VIErA
Manufacturer as Panasonic
Thanks again.
Post Wed Sep 05, 2012 6:47 pm
Preliminary: when you edit the profile.xml, you have to restart the serviio service to reload new profiles modifications.
kram wrote:Here is the MP4 media info, Ill get to the rest tomorrow.
MPEG-4/AVC/AAC
OK, edit profiles.xml and with <Profile id="viera2011a", on the second <Video>..</Video> element, comment following line
<Matches container="mp4" vCodec="h264" aCodec="aac" />
Retry to play your MP4 file.
kram wrote:Ok I changed to the generic profile and the results were the same as with the Panasonic profile selected and no transcoding. MVK with DTDHD plays, MKV with TrueHD dosent play sound and every file seems to be labled correctly on on the TV as well.
OK, so <Matches container="matroska" vCodec="h264" aCodec="truehd" /> line on second <video> element should be kept, but you said that this file does not play with transcoding on. you confirm?
kram wrote:I found a MKV with AC3 to download from the serviio Wiki, its the Batman clip. It dosent play smoothley at all, video and audio work but its impossable to watch. Its the same with Panasonic or Generic profile.
OK, so MKV/AVC/AC3 is a good transcoding output format. So we can keep the <Video targetContainer="mpegts" targetACodec="ac3" forceInheritance="true"> element
kram wrote:Next I tried this file, its a WMV file, with transcoding off there is no audio.
WMV/VC-1/WMAPro
OK, so WMA Pro is not supported and should be transcoded.
Could you add another <video> element with following :
            <!-- transcode audio only for wmv with wmapro -->
            <Video targetContainer="asf" targetACodec="ac3" aBitrate="256">
                <Matches container="asf" aCodec="wmapro" />
If audio does not play, you can also try with this
            <Video targetContainer="asf" targetACodec="wmav2" forceStereo="true">
kram wrote:Intel Tools reports the Friendly Name as VIERA ET5 Series,
So, if we new to create a specific profile we'll use these elements to automatically select the proper profile. Thanks
You confirm this ?
<friendlyName>VIERA ET5</friendlyName>
What about audio transcoding ?
kram
Post Sun Sep 09, 2012 4:45 pm
Had some time today to try out some of your ideas.
You confirm this ?
That is what is reported by the Intel tools package.
I have changed 2 sections so far in the profile, 1st was the audio part concerning FLAC and other audio.
<!-- unsupported audio will be transcoded into lpcm audio -->
 -<Audio targetContainer="lpcm" forceInheritance="true">
<!-- <Matches container="flac" /> -->
 <Matches container="ogg"/>
<!-- <Matches container="asf" /> -->
<!-- <Matches container="adts" /> -->
 </Audio>
ON the TV FLAC is now reported as FLAC, this bit works :)
2nd part was in the video section about MP4,
Profile name="Panasonic Viera G/GT/DT/UT/VT (2011/2012)" id="viera2011a" extendsProfileId="1">
<!-- Panasonic Viera G30, GT30, DT30, UT30 With avi (2011), xx50 (2012) With AVI Support -->
 -<Detection> -<UPnPSearch> <FriendlyName>(VIERA (G|D|U)T?(3|5)0?.*)|(VIERA VT50.*)</FriendlyName> <Manufacturer>Panasonic</Manufacturer> </UPnPSearch> </Detection> <ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.PacketVideoDLNAMessageBuilder</ContentDirectoryMessageBuilder> <SubtitlesMimeType>text/srt</SubtitlesMimeType> -<MediaFormatProfiles> <MediaFormatProfile mime-type="video/divx">AVI</MediaFormatProfile> </MediaFormatProfiles> -<Transcoding>
<!-- Transcode h264 videos with profile level > 4.1 to mpegts with ac3 audio -->
 -<Video targetACodec="ac3" targetContainer="mpegts" forceInheritance="true" targetVCodec="mpeg2video"> <Matches container="*" vCodec="h264" profile="high" levelGreaterThan="4.1"/> <Matches container="*" vCodec="h264" profile="main" levelGreaterThan="4.1"/> </Video>
<!-- remux VORBIS/FLAC/LPCM in MKV/MP4 to AC3 -->
 -<Video targetACodec="ac3" targetContainer="mpegts" forceInheritance="true">
<!-- Some models support DTS natively, so the folowing line can be removed for those -->
 <Matches container="matroska" vCodec="h264" aCodec="dca"/> <Matches container="matroska" vCodec="h264" aCodec="flac"/> <Matches container="matroska" vCodec="h264" aCodec="vorbis"/> <Matches container="matroska" vCodec="h264" aCodec="truehd"/> <Matches container="mp4" vCodec="h264" aCodec="lpcm"/>
<!-- <Matches container="mp4" vCodec="h264" aCodec="aac" /> -->
 <Matches container="3gp" vCodec="h264"/> </Video>
I took at detailed log of whats happening when I try to play the Muse MP4 video. The TV still reports that the MP4 is now listed as video not MP4, shouldnt it be listed as MP4?
Any Ideas, did i edit the right bit, its the first time ive ever tried to do this!
Mark.
serviio (2).zip
Log, MP4 listed as video.
(342.35 KiB) Downloaded 913 times
Post Sun Sep 09, 2012 6:51 pm
kram wrote:I have changed 2 sections so far in the profile, 1st was the audio part concerning FLAC and other audio.
OK, fine, what about other audio format : WMA, AAC ?
kram wrote:2nd part was in the video section about MP4,
kram wrote:I took at detailed log of whats happening when I try to play the Muse MP4 video. The TV still reports that the MP4 is now listed as video not MP4, shouldnt it be listed as MP4?
hum, according to debug log this MP4 still transcoded...
Could you try with following profile ?
   <Profile id="viera2011a" name="Panasonic Viera E/G/GT/DT/UT (2011/2012)" extendsProfileId="1">
      <!-- Panasonic Viera E30, E3, G30, GT30, DT30, UT30 With avi (2011), E50... (2012)  With AVI Support -->
      <Detection>
         <UPnPSearch>
            <FriendlyName>VIERA (G|D|U|E)T?(3|5)0?.*</FriendlyName>
         </UPnPSearch>
      </Detection>
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" forceInheritance="true">
            <Matches container="mp4" vCodec="h264" aCodec="lpcm" />
         <!-- Remux MPEG-TS with no transcoding -->
         <Video targetContainer="mpegts" forceInheritance="true">
            <!-- <Matches container="mp4" vCodec="h264" /> -->
         <!-- Remux WTV files to MPEG-PS with no transcoding -->
         <Video targetContainer="mpeg" forceInheritance="true">
            <Matches container="wtv" />
         <!-- unsupported codecs will be transcoded into mpeg-ts, mpeg2 video and ac3 audio -->
            <Matches container="mp4" vCodec="mpeg4" />
            <Matches container="mpeg" vCodec="mpeg1video" />
            <Matches container="matroska" vCodec="mpeg4" />
            <Matches container="flv" />
            <Matches container="ogg" />
            <Matches container="3gp" />
         </Audio>
kram
Post Tue Apr 09, 2013 5:58 pm
Hi, apologies for not keeping up with this thread.
I have installed the new 1.2.1 serviio and Im back to where I started with unnecessary transcoding taking place with the Panasonic Viera G/GT/DT/UT/VY (2011,2012) profile. Also now some videos are the wrong aspect ratio as well, I don't recall that happening last time.
I tried to copy and paste the profile that was posted above into the new 1.2.1 profiles.xml but serviio wouldn't run. I probably didn't paste it into the correct place, could someone give me some pointers of where exactly it should be pasted in.
Im going to have a mess around with a bit of the profile to see if I can get it back to how I remember it being before.
Mark.
kram
Post Wed Apr 10, 2013 10:51 am
OK tried that profile that Illico posted above and it seems to work fine on the TV with the files I was testing with previously. Ill try some detailed logging for my self just to check.
Most if not all of my MKV files have subtitles but non are available to select on the screen. I made the MKV files with MakeMKV and selected English subs and forced subs when making the MKV files. What is the method to get these to be displayed when I want them to be?
I have also made a few DVD rips with MakeMKV with subs included. With Transcoding off the TV plays the MKV files perfectly, with subs available if I want them. With transcoding on I think the DVD MKVs are being transcoded and subs are not available.
How do I stop the DVDs from being transcoded?
Thanks again Illico for the previous profile.
kram
Post Wed Apr 10, 2013 3:40 pm
I have managed to get MKV dvds working without being transcoded and the DVD SUBs work again. I also managed to get another video to stop being transcoded. Here is the profile in case its of any use to anyone else.
<Profile id="viera2011a" name="Panasonic Viera G/GT/DT/UT/VT (2011/2012)" extendsProfileId="1">
      <Detection>
         <UPnPSearch>
         </UPnPSearch>
      </Detection>
         <!-- Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" forceInheritance="true">
         </Video -->
         <!--    <Matches container="matroska" vCodec="h264" aCodec="dca" /> --> <!-- ST50 supports DTS, remove this line -->
         <!--   <Matches container="mp4" vCodec="h264" aCodec="lpcm" />  -->
         <!--   <Matches container="matroska" vCodec="mpeg2video" />  -->
            <Matches container="mp4" vCodec="dvvideo" />
            <Matches container="rm" />
         </Audio>
      <Subtitles>
         <SoftSubs mime-type="text/srt" />
         <HardSubs>
            <RequiredFor container="mp4" />
         </HardSubs>
      </Subtitles>
Now, how to get subs working on the bluray MKVs?
Almost forgot, this bluray MKV isn't playing any sound as its Dolby TrueHD but its not being transcoded as I think the video codec is different from my other dolby trueHD MKV films.
Unique ID                        : 95451619018620095317202335644653470741 (0x47CF5029576865929FD892D7412C4415)
Complete name                    : E:\MKV\The_Hangover_t02.mkv
Format                           : Matroska
File size                        : 12.5 GiB
Duration                         : 1h 39mn
Overall bit rate                 : 17.9 Mbps
Movie name                       : The Hangover
Encoded date                     : UTC 2012-09-02 10:19:18
Format                           : VC-1
Format profile                   : AP@L3
Codec ID                         : WVC1
Codec ID/Hint                    : Microsoft
Duration                         : 1h 39mn
Language                         : English
Format                           : TrueHD
Codec ID                         : A_TRUEHD
Duration                         : 1h 39mn
Maximum bit rate                 : 2 601 Kbps
Bit depth                        : 24 bits
Title                            : 5.1
Language                         : English
Text
Format                           : PGS
Language                         : English
Menu
00:03:43.389                     : en:Chapter 01
00:09:15.012                     : en:Chapter 02
00:14:10.182                     : en:Chapter 03
00:18:59.221                     : en:Chapter 04
00:23:19.022                     : en:Chapter 05
00:28:59.696                     : en:Chapter 06
00:34:03.374                     : en:Chapter 07
00:37:03.596                     : en:Chapter 08
00:39:53.974                     : en:Chapter 09
00:42:51.193                     : en:Chapter 10
00:47:34.977                     : en:Chapter 11
00:52:08.375                     : en:Chapter 12
00:57:48.173                     : en:Chapter 13
01:01:08.998                     : en:Chapter 14
01:05:28.257                     : en:Chapter 15
01:07:57.990                     : en:Chapter 16
01:12:32.431                     : en:Chapter 17
01:16:24.079                     : en:Chapter 18
01:22:40.163                     : en:Chapter 19
01:25:50.061                     : en:Chapter 20
01:30:21.624                     : en:Chapter 21
01:32:48.187                     : en:Chapter 22
01:36:00.880                     : en:Chapter 23
kram
Post Sun Apr 14, 2013 8:05 pm
Re: MKVs with Dolby are unsupported TX L37ET5b
Today I managed to get Subs working for Bluray MKV rips today, but it only works with Transcoding OFF at the moment. I used Subtitle edit to extract the subs from the MKV which then saves them as a SRT file. At the moment this is subs for the entire film, which isn't something I use very often but Forced subs are essential for some films so that is next on the list to try out.
How can I adjust the Profile to make subs work when transcoding is set to ON?
Post Fri Apr 19, 2013 3:55 pm
kram wrote:How can I adjust the Profile to make subs work when transcoding is set to ON?
It should work, post details about the files/srt file and also detailed log when playing the file.
Return to Panasonic
