DNS-320 not hibernating with Serviio 0.6.1
pi3_14159265359
Post Mon Aug 27, 2012 9:04 am
Hey!
With Serviio running my Nas woun't hibernate. The HDD hibernation is enabled and set to 5 Minutes.
I disabled the option "Keep library automatically updated" but still no hibernation.
Thanks!
pi3_14159265359
Post Tue Aug 28, 2012 4:23 pm
Re: DNS-320 not hibernating with Serviio 0.6.1
nothing?
Post Tue Aug 28, 2012 4:24 pm
viewtopic.php?f=5&t=6878 is for 1.0, not sure it applies to 0.6.1 which is now rather old. Use the fix and if that doesn't work, use the technique used to find out the problem to see if that can give some insight.
pi3_14159265359
Post Tue Sep 04, 2012 4:35 pm
thanks for the link!
but where can I find the file on my dns-320?
Post Sun Sep 09, 2012 10:22 pm
If you cannot hibernate with 0.6.1 then this tipo will not help you.
