How to view shortcut to video files
mr.jaina
Post Thu May 17, 2012 4:11 pm
Is there a way to be able to create a shortcut of some of my video files in another folder on my desktop, but serviio be able to play the shortcut files. This way I do not have to copy the files in multiple locations?
Here is basically what I am trying to achieve. I have some video files in a folder. I want to organize them better based on various criteria (year, good/bad, etc). Maybe there is a way to tag them? If yes, how? and how will serviio recognize the tags?
Does this request go in new feature request or does this already exist?
jalla
Post Fri May 18, 2012 7:25 am
Re: How to view shortcut to video files
What makes you think this doesn't work? Have you tried it?
I use unix and have no problem with serviio accessing a folder of symbolic links pointing elsewhere. I guess you're on windows, but I see no reason why it shouldn't work the same there.
Post Fri May 18, 2012 12:13 pm
Windows shortcuts don't work AFAIK, there is an open ticket
mr.jaina
Post Fri May 18, 2012 5:01 pm
Thanks for the replies....I am glad that this is already been looked into.
Zip, is there an ETA for that open ticket?
I cannot say it enough....I love Serviio....
Post Fri May 18, 2012 6:50 pm
you should not have to copy the files in multiple locations, just map each one via serviio. You can have multiple drives mapped for videos.
Post Fri May 18, 2012 7:27 pm
mr.jaina wrote:Zip, is there an ETA for that open ticket?
It's been the for a long time and has very low priority, so not sure.
mr.jaina
Post Sat Sep 15, 2012 3:15 pm
Just wanted to see if this was already fixed in 1.0.1 or if there is an estimate?
Post Sat Sep 15, 2012 11:57 pm
nubbel
Post Mon Dec 16, 2013 6:50 pm
I feel really bad to necro this thread, but I found it on accident and I tried to do the same thing in the past.
The solution I came up with was creating NTFS symbolic links using the "mklink"-command (Wiki).
I built myself a drag-n-drop batch-file to create links for movie folders, all I have to do is pick the folder i want to create a link for and drag it onto the batch-file and the link will be created in X:\_Media\_Movies\Links
Beware: This exact batch script will certainly not work for your folder structure, it's for reference only!
@echo off
setlocal enabledelayedexpansion
set ORIG=%1
set FOLDER=
set DEST="X:\_Media\_Movies\Links\"
FOR /f "tokens=1,2,3,4,5 delims=\ " %%a in ("%ORIG%") DO (
   set FOLDER=%%e
echo mklink /D %DEST:~,-1%%FOLDER%" "%ORIG%"
echo.
pause
FILEBITCH_18TB » CPU: AMD FX-8350 | RAM: Corsair 2x4GB 1600MHz CL8-8-8-24 | Mainboard: ASUS M5A99X EVO | SSD: 250GB Samsung 840 | RAID: Adaptec RAID 6805 | Storage: 6x3TB Western Digital RED @ RAID6
Users browsing this forum: Baidu [Spider] and 91 guests
