windows 7 all users
galinhola
Post Sat Sep 15, 2012 12:04 pm
windows 7 all users
Hello :
I have a computer with 4 users
windows 7 64 bits
I installed admin users ( all users have admin) but if i log on or switch user the servio dont run in background.
Can you help
No matter user is loged i need serviio running.
Thanks a lot
Luis
Post Sat Sep 15, 2012 11:55 pm
Re: windows 7 all users
The server should be running, it's only the console that starts up for the first logged in user.
galinhola
Post Sun Sep 16, 2012 7:33 am
Thanks . Thaís true . The problem is now other.
No contents , i got the contents in a maped drive in other machine ... And if a User dont log after a restart Windows 7 dont map ...
Post Sun Sep 16, 2012 7:04 pm
Don't add folders via mapped drives, use //server/path form instead. And make sure the service runs under a user that has access to the remote drive.
galinhola
Post Sun Sep 16, 2012 7:47 pm
yes. But i dont want to login.
the maping is after the user logs.
Thnks.
Post Sun Sep 16, 2012 11:15 pm
exactly, mapping is done on login - therefore you have to avoid it and use UNC paths like //server/folder
You can run the Serviio service as an existing user without logging in - just change the user of the service in the Services panel
