UE40EH5300 playing certain 1080p only when renamed to avi
secon
Post Mon Sep 17, 2012 7:19 pm
My UE40EH5300 is having some problem with playing certain 1080p mkv files. Renaming them to avi has fixed the problem.
This is only happening with certain mkv files while other 1080p are working without problem.
I'm using servio 1.0.1 on Linux Mint. I'm using Samsung TV (C, D, E series).
Is there a way to set up profile so I don't have to rename them each time I wish to play them?
Bellow is media info from problematic files.
eneral
Unique ID                                : 241209915032241791024112113245890674643 (0xB57756FEBAD985DC9C80BE7016ADFFD3)
Complete name                            : I:\sample.mkv
Format version                           : Version 1
File size                                : 102 MiB
Duration                                 : 1mn 3s
Overall bit rate                         : 13.5 Mbps
Movie name                               : Sample
Encoded date                             : UTC 2007-05-19 23:48:15
Writing application                      : mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55
Writing library                          : libebml v0.7.7 + libmatroska v0.8.1
Attachment                               : Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes
Format profile                           : High@L5.1
Format settings, ReFrames                : 9 frames
Bit rate                                 : 12.6 Mbps
Height                                   : 792 pixels
Display aspect ratio                     : 2.40:1
Frame rate mode                          : Variable
Original frame rate                      : 23.976 fps
Title                                    : The Matrix
Duration                                 : 1mn 3s
Bit rate                                 : 640 Kbps
Delay relative to video                  : 17ms
Stream size                              : 4.82 MiB (5%)
Title                                    : AC3 5.1 640 kbps
Text #1
Format                                   : ASS
Codec ID                                 : S_TEXT/ASS
Codec ID/Info                            : Advanced Sub Station Alpha
Compression mode                         : Lossless
Text #2
Format                                   : ASS
Language                                 : Romanian
Text #3
Format                                   : ASS
Language                                 : Swedish
Text #4
Format                                   : ASS
Language                                 : Finnish
Text #5
Format                                   : ASS
Language                                 : Norwegian
Text #6
Format                                   : ASS
Language                                 : Danish
Text #7
Format                                   : ASS
Language                                 : German
Text #8
Format                                   : ASS
Language                                 : Dutch
Text #9
Format                                   : ASS
Language                                 : French
Text #10
Format                                   : ASS
Language                                 : Polish
Text #11
Format                                   : ASS
Language                                 : Czech
Text #12
Format                                   : ASS
Language                                 : Hungarian
Text #13
Format                                   : ASS
Language                                 : Slovenian
Text #14
Format                                   : ASS
Language                                 : Hebrew
If you need any additional information let me know
Post Mon Sep 17, 2012 10:02 pm
Re: UE40EH5300 playing certain 1080p only when renamed to av
I doubt that is the cause. you can post ffmpeg -i for the file with mkv and avi extensions - the output should be the same.
secon
Post Tue Sep 18, 2012 6:24 am
Okie, everything seems to be working now. Looks like i had to trun off everything for the night and now everything is ok.
Sorry for bothering you
Users browsing this forum: No registered users and 87 guests
