Not all files added to library available
playwithfire
Post Tue Sep 18, 2012 8:54 pm
I had been using version 0.62 with no issues and just upgraded to version 1.01 (I first uninstalled version 0.62). I just rebuilt my library and when browsing the files via my Sony Bravia not all of the video files that have been loaded into the library are being shown as in my library. It seems that it is not showing the majority of the AVI files. What is the issue here?
I always browse using the folder function and I am using Windows XP
Okay so I am following the instructions to hopefully get some feedback -
1. Make sure you give Serviio enough time to index all your files. This may take considerable amount of time if you are sharing a lot of files
Done.
2. Check serviio.log file for a list of added files and confirm it is (or is not) in the list
Added to library
3. Download Intel UPnP tools and run AV Media Controller. Select Serviio and try to find the file you're looking for using this tool's browsing function. If the file is there it means Serviio registered the file but for some reason your device doesn't display it. This could be due to the fact your device doesn't support the format or it does but doesn't understand the format in the way Serviio is serving it (this could be fixed by creating a Profile for the device) If the file is not visible using the tool above, locale FFmpeg executable (in lib folder in Serviio installation directory, or a part of your Linux distribution), run this command and post the result in the forum.
File is there.
FIXED THE ISSUE
The profile needed to be adjusted to Sony Bravia 2011 - US and not Sony Bravia 2011.
Post Wed Sep 19, 2012 11:31 am
Re: Not all files added to library available
What is your Sony device model number? What is your region ?
Users browsing this forum: Baidu [Spider] and 39 guests
