Problem with external hard drive
honam
Post Wed Sep 19, 2012 11:43 am
Hi all,
I don't leave my external hard drive on all time. So the problem is, everytime I turn on my external hard drive, serviio will have to readd all my data again.
Is there a way to fix this?
Post Wed Sep 19, 2012 12:22 pm
Re: Problem with external hard drive
Yes.
Disable all orange box on serviio console.
When you want to refresh a folder, enable box then save, check the status button to see new files added (the screenshot is not uptodate), then disable box and save.
honam
Post Wed Sep 19, 2012 1:45 pm
Thank you I will give this a try
