Problem after each reboot
After each reboot, I get a "The server is not accessible. Please try again later" error. I'm running Ubuntu Server 12.04, Serviio 1.0.1 and ffmpeg built from the source on the serviio download page.
I'm even running the serviio process using "root" to make sure it has all the required rights.
Here's the detail log:
- Code:
2012-09-16 11:59:47,040 DEBUG [WebServer] Incoming connection from /192.168.1.14:37496
2012-09-16 11:59:47,041 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.14
2012-09-16 11:59:47,042 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.14:
2012-09-16 11:59:47,042 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.14
2012-09-16 11:59:47,045 DEBUG [ContentDirectory] Browse() called for renderer KDL-46EX700 (profile sony2010) with parameters: objectID = V_T^INI_65, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2012-09-16 11:59:47,046 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-09-16 11:59:47,046 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-09-16 11:59:47,054 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-09-16 11:59:49,958 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-09-16 11:59:49,958 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-09-16 11:59:51,692 DEBUG [WebServer] Incoming connection from /192.168.1.14:37497
2012-09-16 11:59:51,693 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.14
2012-09-16 11:59:51,693 DEBUG [ResourceTransportRequestHandler] HEAD /resource/10/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-2/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-46EX700";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-46EX700"; mv="1.7";,Host: 192.168.1.99:8895]]
2012-09-16 11:59:51,694 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.14
2012-09-16 11:59:51,694 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.14, Profile=Sony Bravia TV (2010)'
2012-09-16 11:59:51,694 DEBUG [ResourceDeliveryProcessor] Request for resource 10 and type 'MEDIA_ITEM' received
2012-09-16 11:59:51,694 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 10 (local)
2012-09-16 11:59:51,695 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 10)
2012-09-16 11:59:51,696 DEBUG [VideoDAOImpl] Reading a Video (id = 10)
2012-09-16 11:59:51,697 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 10, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2010)
2012-09-16 11:59:51,697 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file movie.mkv
2012-09-16 11:59:51,697 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file movie.mkv: AVC_TS_MP_HD_AC3_ISO
2012-09-16 11:59:51,697 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-09-16 11:59:51,697 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Sun, 16 Sep 2012 15:59:51 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_60_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-09-16 11:59:51,707 DEBUG [WebServer] Incoming connection from /192.168.1.14:37498
2012-09-16 11:59:51,709 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.14
2012-09-16 11:59:51,710 DEBUG [ResourceTransportRequestHandler] GET /resource/10/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-2/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-46EX700";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-46EX700"; mv="1.7";,Host: 192.168.1.99:8895]]
2012-09-16 11:59:51,710 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.14
2012-09-16 11:59:51,711 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.14, Profile=Sony Bravia TV (2010)'
2012-09-16 11:59:51,711 DEBUG [ResourceDeliveryProcessor] Request for resource 10 and type 'MEDIA_ITEM' received
2012-09-16 11:59:51,711 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 10 (local)
2012-09-16 11:59:51,711 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 10)
2012-09-16 11:59:51,712 DEBUG [VideoDAOImpl] Reading a Video (id = 10)
2012-09-16 11:59:51,713 DEBUG [VideoDeliveryEngine] Delivering item '10' for client 'IPAddress=/192.168.1.14, Profile=Sony Bravia TV (2010)'
2012-09-16 11:59:51,713 DEBUG [VideoDeliveryEngine] Delivering file 'movie.mkv' using transcoding
2012-09-16 11:59:51,713 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-14-sony2010-ORIGINAL.stf', will stop the job
2012-09-16 11:59:51,713 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-14-sony2010-ORIGINAL.stf'
2012-09-16 11:59:51,713 DEBUG [TranscodingJobListener] Deleted temp file '/tmp/Serviio/transcoding-temp-14-sony2010-ORIGINAL.stf': false
2012-09-16 11:59:51,713 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.14, Profile=Sony Bravia TV (2010)'
2012-09-16 11:59:51,713 DEBUG [MediaItemDAOImpl] Getting file of media item 10
2012-09-16 11:59:51,714 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /home/media/video/movie.mkv
2012-09-16 11:59:51,714 DEBUG [ProcessExecutor] Starting ffmpeg -fflags +genpts -i /home/media/video/movie.mkv -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-10-sony2010-ORIGINAL.stf
2012-09-16 11:59:51,974 WARN [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error.
2012-09-16 11:59:51,975 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2012-09-16 11:59:59,217 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/tmp/Serviio/transcoding-temp-10-sony2010-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/tmp/Serviio/transcoding-temp-10-sony2010-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:45)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:125)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:95)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:120)
at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:84)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:79)
at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:191)
When I try the ffmpeg using a "regular" user, i'm getting this:
- Code:
server@h0m3s3rv3r:~$ ffmpeg -fflags +genpts -i /home/media/video/movie.mkv -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-10-sony2010-ORIGINAL.stf
built on Sep 12 2012 18:46:09 with gcc 4.6.3
configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx --enable-librtmp --enable-libxvid
Input #0, matroska,webm, from '/home/media/video/movie.mkv':
creation_time : 2012-09-08 12:18:48
Duration: 02:17:04.38, start: 0.000000, bitrate: 6556 kb/s
Stream #0:0(fre): Video: h264 (High), yuv420p, 1280x720, SAR 1:1 DAR 16:9, 25 fps, 25 tbr, 1k tbn, 47.95 tbc (default)
Stream #0:1(fre): Audio: ac3, 48000 Hz, 5.1(side), s16, 384 kb/s (default)
title : French AC3 5.1 @384 Kbps
Stream #0:2(fre): Subtitle: dvd_subtitle (default) (forced)
title : Srt Forced
/tmp/Serviio/transcoding-temp-10-sony2010-ORIGINAL.stf: Permission denied
But when I run the command with sudo, all is good:
- Code:
server@h0m3s3rv3r:~$ sudo !!
sudo ffmpeg -fflags +genpts -i /home/media/video/movie.mkv -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-10-sony2010-ORIGINAL.stf
[sudo] password for server:
title : Srt Forced
[mpegts @ 0x25b8260] muxrate VBR, pcr every 2 pkts, sdt every 200, pat/pmt every 40 pkts
Output #0, mpegts, to '/tmp/Serviio/transcoding-temp-10-sony2010-ORIGINAL.stf':
encoder : Lavf54.15.102
Stream #0:0(fre): Video: h264, yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=2-31, 25 fps, 90k tbn, 23.98 tbc (default)
Stream #0:1(fre): Audio: ac3, 48000 Hz, 5.1(side), 384 kb/s (default)
Stream mapping:
Stream #0:0 -> #0:0 (copy)
Stream #0:1 -> #0:1 (copy)
frame= 607 fps=0.0 q=-1.0 size= 44246kB time=00:00:24.20 bitrate=14976.7kbitsframe= 2038 fps=2037 q=-1.0 size= 86036kB time=00:01:21.44 bitrate=8654.1kbitsframe= 3406 fps=2269 q=-1.0 size= 127402kB time=00:02:16.16 bitrate=7665.0kbitsframe= 4608 fps=2303 q=-1.0 size= 167518kB time=00:03:04.24 bitrate=7448.4kbitsframe= 5735 fps=2293 q=-1.0 size= 198958kB time=00:03:49.32 bitrate=7107.3kbitsframe= 6650 fps=2215 q=-1.0 size= 241547kB time=00:04:25.92 bitrate=7441.1kbitsframe= 7076 fps=2020 q=-1.0 size= 266825kB time=00:04:42.96 bitrate=7724.8kbitsframe= 7993 fps=1996 q=-1.0 size= 293802kB time=00:05:19.64 bitrate=7529.8kbitsframe= 8878 fps=1971 q=-1.0 size= 324964kB time=00:05:55.04 bitrate=7498.0kbitsframe=10188 fps=2036 q=-1.0 size= 357889kB time=00:06:47.44 bitrate=7195.7kbitsframe=10308 fps=2044 q=-1.0 Lsize= 361114kB time=00:06:52.24 bitrate=7176.0kbits/s
video:312936kB audio:19336kB subtitle:0 global headers:0kB muxing overhead 8.680335%
