Samsung TV C - Series - Manual Resume
rizi
Post Tue Sep 25, 2012 5:52 am
Is it possible to set the resume position for a certain movie manually?
E.q: I have an MKV-movie which is 3 hours long and seeking is really slow, so it would be great if I could set the resume position manually to 1:25.
It would be great if you tell me if I can do that, btw. I don't need an UI, just tell me how serviio stores this information.
Thx in advanced.
rizi
Post Tue Sep 25, 2012 4:41 pm
Re: Samsung TV C - Series - Manual Resume
you could set in on the DB level (Apache Derby), in lib folder - if you are familiar with SQL.
rizi
Post Tue Sep 25, 2012 5:14 pm
Thx for the answer, can you provide a little bit more details, where exactly is the db located and do I need a username/pwd to connect to the db, which version of derby are you using?
thx in advance
Post Thu Sep 27, 2012 5:46 pm
latest version, db in in the lib folder.
