Transcoding does not work (anymore)
sampath.mamilapo
Post Sun Sep 23, 2012 10:56 pm
I had transcoding of WMV files working by default in 0.62. Now I delted it and installed 1.x (both on Linux).
I have a Samsung UE C6200 TV. I edited the Profile id="7" section in profiles.xml to transcode all WMV files by default. Still it does not play on my Samsung TV.
Here is the section I added:
         <!-- transcode (actually rewrap) all WMV containers, use mp3, leave video alone -->
         <Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video" maxVBitrate="20000">
            <Matches container="asf" />
Can I get this working somehow? Also I would like to transcode all FLV files so they run on my TV. How do I do that?
Thanks,
sampy
Post Mon Sep 24, 2012 6:05 pm
Re: Transcoding does not work (anymore)
ASF files should normally play without transcoding on the C series. FLV is already set up in the C/D/E profile.
Make sure you're using the proper profile. If you do, enable detailed logging and post it here incl playing the asf file.
sampath.mamilapo
Post Mon Sep 24, 2012 7:05 pm
First some info about my system:
2012-09-24 20:53:49,593 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2012-09-24 20:53:49,603 INFO  [MediaServer] ------------------------------------------------------------------------
2012-09-24 20:53:49,603 INFO  [MediaServer] Serviio DLNA media streaming server v 1.0.1 (rev. 6dbf7c6e334f+)
2012-09-24 20:53:49,603 INFO  [MediaServer] Petr Nejedly 2009-2012
2012-09-24 20:53:49,603 INFO  [MediaServer] http://www.serviio.org
2012-09-24 20:53:49,603 INFO  [MediaServer] Java 1.7.0_07-Oracle Corporation
2012-09-24 20:53:49,603 INFO  [MediaServer] OS Linux i386 3.2.0-29-generic-pae
2012-09-24 20:53:49,603 INFO  [MediaServer] File encoding: UTF-8
2012-09-24 20:53:49,603 INFO  [MediaServer] Headless mode enabled: true
2012-09-24 20:53:49,603 INFO  [MediaServer] User home dir: /home/usul
2012-09-24 20:53:49,603 INFO  [MediaServer] Temp dir: /tmp
2012-09-24 20:53:49,604 INFO  [MediaServer] ------------------------------------------------------------------------
2012-09-24 20:53:49,702 INFO  [WebServer] Socket buffer set to 65535 bytes
2012-09-24 20:53:49,704 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2012-09-24 20:53:49,731 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2012-09-24 20:53:49,732 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2012-09-24 20:53:49,743 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-09-24 20:53:49,750 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2012-09-24 20:53:50,633 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2012-09-24 20:53:50,634 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2012-09-24 20:53:50,634 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2012-09-24 20:53:50,635 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2012-09-24 20:53:50,635 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2012-09-24 20:53:50,636 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2012-09-24 20:53:50,636 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2012-09-24 20:53:50,637 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2012-09-24 20:53:50,638 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2012-09-24 20:53:50,638 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2012-09-24 20:53:50,639 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2012-09-24 20:53:50,639 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2012-09-24 20:53:50,648 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
I tried to isolate the part where I press play on a FLV file followed by the error. Can you make any sense of this?
2012-09-24 20:57:28,426 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 12 (filter: ALL) [No_Restriction]
2012-09-24 20:57:28,430 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-09-24 20:57:28,450 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-09-24 20:57:33,537 DEBUG [WebServer] Incoming connection from /192.168.178.22:44008
2012-09-24 20:57:33,538 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.22
2012-09-24 20:57:33,539 DEBUG [ResourceTransportRequestHandler] HEAD /resource/320/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.178.25:8895]]
2012-09-24 20:57:33,540 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.22
2012-09-24 20:57:33,544 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.178.22, Profile=Samsung TV / player (C/D/E-series)'
2012-09-24 20:57:33,545 DEBUG [ResourceDeliveryProcessor] Request for resource 320 and type 'MEDIA_ITEM' received
2012-09-24 20:57:33,545 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 320 (local)
2012-09-24 20:57:33,545 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 320)
2012-09-24 20:57:33,546 DEBUG [VideoDAOImpl] Reading a Video (id = 320)
2012-09-24 20:57:33,546 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 320, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D/E-series)
2012-09-24 20:57:33,547 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file h_tapezieren.flv
2012-09-24 20:57:33,547 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file h_tapezieren.flv: MPEG_TS_SD_EU_ISO
2012-09-24 20:57:33,547 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file h_tapezieren.flv: MPEG_TS_SD_NA_ISO
2012-09-24 20:57:33,547 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file h_tapezieren.flv: MPEG_TS_SD_KO_ISO
2012-09-24 20:57:33,549 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-09-24 20:57:33,549 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Mon, 24 Sep 2012 18:57:33 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-09-24 20:57:33,562 DEBUG [WebServer] Incoming connection from /192.168.178.22:42533
2012-09-24 20:57:33,562 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.22
2012-09-24 20:57:33,563 DEBUG [ResourceTransportRequestHandler] GET /resource/320/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,TimeSeekRange.dlna.org: npt=0-,Host: 192.168.178.25:8895]]
2012-09-24 20:57:33,564 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.22
2012-09-24 20:57:33,564 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.178.22, Profile=Samsung TV / player (C/D/E-series)'
2012-09-24 20:57:33,565 DEBUG [ResourceDeliveryProcessor] Request for resource 320 and type 'MEDIA_ITEM' received
2012-09-24 20:57:33,567 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 320 (local)
2012-09-24 20:57:33,567 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 320)
2012-09-24 20:57:33,567 DEBUG [VideoDAOImpl] Reading a Video (id = 320)
2012-09-24 20:57:33,569 DEBUG [VideoDeliveryEngine] Delivering item '320' for client 'IPAddress=/192.168.178.22, Profile=Samsung TV / player (C/D/E-series)'
2012-09-24 20:57:33,569 DEBUG [VideoDeliveryEngine] Delivering file 'h_tapezieren.flv' using transcoding
2012-09-24 20:57:33,569 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.178.22, Profile=Samsung TV / player (C/D/E-series)'
2012-09-24 20:57:33,569 DEBUG [MediaItemDAOImpl] Getting file of media item 320
2012-09-24 20:57:33,570 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /media/Data/_downloads/DIY/BAUHAUS/h_tapezieren.flv
2012-09-24 20:57:33,571 DEBUG [ProcessExecutor] Starting ffmpeg -i /media/Data/_downloads/DIY/BAUHAUS/h_tapezieren.flv -y -threads 1 -copyts -c:v mpeg2video -b:v 20000k -maxrate:v 20000k -bufsize:v 20000k -r 24000/1001 -g 15 -c:a ac3 -b:a 48k -ac 1 -map 0:0 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-320-7-ORIGINAL.stf
2012-09-24 20:57:33,600 WARN  [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error.
2012-09-24 20:57:33,600 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2012-09-24 20:57:41,074 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/tmp/Serviio/transcoding-temp-320-7-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/tmp/Serviio/transcoding-temp-320-7-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
   at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:45)
   at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:125)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:95)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:120)
   at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:84)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:79)
   at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:191)
2012-09-24 20:57:41,242 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface vmnet1 (vmnet1) and address 172.16.108.1, timeout = 0
2012-09-24 20:57:41,242 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 7b29969c-e86a-32b6-a341-5b48c546bf04
2012-09-24 20:57:42,179 DEBUG [WebServer] Incoming connection from /192.168.178.22:60948
2012-09-24 20:57:42,180 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.22
2012-09-24 20:57:42,181 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.178.22:
2012-09-24 20:57:42,181 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.22
2012-09-24 20:57:42,188 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-09-24 20:57:43,046 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface vmnet8 (vmnet8) and address 172.16.192.1, timeout = 0
2012-09-24 20:57:43,047 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 7b29969c-e86a-32b6-a341-5b48c546bf04
2012-09-24 20:57:44,851 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.178.25, timeout = 0
2012-09-24 20:57:44,852 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 7b29969c-e86a-32b6-a341-5b48c546bf04
2012-09-24 20:57:46,657 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:36
sampath.mamilapo
Post Tue Sep 25, 2012 5:01 am
In case this is important: the folder '/tmp/Serviio' does exist.
Post Tue Sep 25, 2012 1:29 pm
Run the command
and post the output. It will show the errors that caused ffmpeg to fail. Unfortunately Serviio does not display these messages in its log.
sampath.mamilapo
Post Tue Sep 25, 2012 7:34 pm
Unrecognized option 'c:v'
ffmpeg version 0.8.3-4:0.8.3-0ubuntu0.12.04.1, Copyright (c) 2000-2012 the Libav developers
  built on Jun 12 2012 16:37:58 with gcc 4.6.3
[flv @ 0x8c650e0] warning: first frame is no keyframe
[flv @ 0x8c63240] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 1000.00 (1000/1) -> 15.00 (15/1)
Input #0, flv, from '/media/Data/_downloads/DIY/BAUHAUS/h_tapezieren.flv':
    datasize        : 29741111
    lasttimestamp   : 619667
    audiosize       : 4002893
    videosize       : 25737964
    metadatacreator : inlet media - FLVTool2
    encoder         : Riva FLV Encoder
  Duration: 00:10:19.73, start: 0.000000, bitrate: 388 kb/s
    Stream #0.0: Video: flv, yuv420p, 384x288, 338 kb/s, 15 tbr, 1k tbn, 1k tbc
    Stream #0.1: Audio: mp3, 44100 Hz, mono, s16, 49 kb/s
Failed to set value 'mpeg2video' for option 'c:v'
sampath.mamilapo
Post Tue Sep 25, 2012 7:38 pm
When I use avconv instead of ffmpeg it transcodes the file successfully. I just played it in VLC.
Maybe Serviio can just use avconv on Linux instead of ffmpeg?
Post Tue Sep 25, 2012 7:56 pm
You really should use the latest ffmpeg, having said that, add -Dffmpeg.location=/path/to/avconv to the JAVA_OPTS line at the bottom of serviio.sh and Serviio will use it
sampath.mamilapo
Post Tue Sep 25, 2012 8:30 pm
I will try that. Thanks!
I have the default ffmpeg 4:0.8.3-0ubuntu0.12.04.1 that comes with Ubuntu. What should I do to install the current ffmpeg?
I think avconv is just a wrapper around ffmpeg, right?
Post Tue Sep 25, 2012 8:39 pm
There is a guide on the wiki under Linux.
sampath.mamilapo
Post Wed Sep 26, 2012 7:57 am
The tip to include avconv in serviio.sh worked great. Thanks!!!
Maybe Serviio could check the ffmpeg version or something like that and warn the user via Swing-Dialog that something is wrong with ffmpeg.
Cheers,
Sampy
