Deleted files still show on List
gfch
Post Mon Oct 01, 2012 9:42 pm
I installed Serviio to get around an issue I was having with apparently WMP. I would delete files but they wouldn't delete from my file list on the TV
I installed serviio set it, up added a folder, and put some videos in it.
I went to my TV and watched them. I then went back to my PC and deleted the files.
all good except they still show up on my list when I connect on the TV.
The files are GONE from my PC, how do I get rid of them off the TV list? # hours later they are still there. TVs been off two or 3 times. PC rebooted.
Most annoying to have to scroll through a bunch of non existent files to find the one I want.
SAMSUNG UN55D6050
Post Mon Oct 01, 2012 9:44 pm
Re: Deleted files still show on List
Do you have checking for updates on in the console (default setting)? It normally takes about an hour to remove the items from the list. Are there any errors in the log?
gfch
Post Tue Oct 02, 2012 4:15 am
If its a default setting then yes it's checked. Where do I find this setting option in the console? I just went through every tab and did not see anything that said "Check for updates"
I haven't done anything except add a folder with videos
Sorry the # above should have been a 3. Its been 6 plus now anyways.
Is it so difficult that when its deleted on my computer, it's gone?
When I delete a file on my PC it doesn't hang around forever
Post Tue Oct 02, 2012 10:53 pm
Should be the orange and red boxes here: http://wiki.serviio.org/doku.php?id=ser ... _explained
Do you have actual files still visible in the library, or just the folders?
Users browsing this forum: Baidu [Spider] and 14 guests
