How does Library work..
gfch
Post Tue Oct 02, 2012 3:32 pm
I just installed servio and am trying to get my shows to show up on the TV.
I went to the TV and it listed a mulitude of Folders, Producer, Movie, Director etc etc. but they were all empty.
I then went to the LIBRARY tab and then selected Shared Folders and selected "ADD LOCAL" I navigated to a folder on my PC and selected it.
Went back to the TV and the folder I added was listed under FOLDERS.
My shows were there.
Some were listed under their series Titles (NCIS etc) and others were not.
How do I get them to all show under their Series name? They are not segregated on my PC.
How do I get my Folder to show on the top level so I don't have to navigate through a bunch of others to get to it?
How do I get my movies to be listed under MOVIES?
How do I get my series to be listed under SERIES? etc etc
I have since disabled the filters I dint care about (producer, artist, director etc.)
Post Tue Oct 02, 2012 3:51 pm
Re: How does Library work..
For the files to go under series/movies they have to be prperly identified as movies/series via the online metadata services. it's based on the file name, so if you are missing some, try to rename them regarding to http://www.serviio.org/index.php?option ... icle&id=12
gfch
Post Tue Oct 02, 2012 8:04 pm
Thank you...
