LNC55 C series TV is using the Generic profile
misguy
Post Tue Oct 09, 2012 1:18 am
I had been using version 6 without any problems since release. Now that i have upgraded to 1.0.1 most of my movies state 'Audic Codec not supported', Video works fine. I Noticied that the profile that my TV sees is now the Generic profile. I changed the Profile in the Serviio Console and the TV appears to ignore the change even after saving or removing and re-adding,I have stopped and started the servcie as well. I also notice the Device name is coming up as Samsung DTV DMR. If i remux my movies to use AC3 instead of DTS they work fine but would rather get the profile right or add the right commands into the generic profile. I am using windows server 2008 to host Serviio. The library is stored on a NAS drive both plugged directly into the router along with the TV. Samsung LNC55C630K1FXZA, Great job overall, Serviio is the Best DLNA server around!
misguy
Post Tue Oct 09, 2012 2:39 am
Re: LNC55 C series TV is using the Generic profile
Just looked closely at my TV manual only DTS Core is supported. I have a feeling that is part of the issue. So remuxing to AC3, which has been successful for me using mkvmerge Gui (part of MKVToolNix) works jsut fine, remember to use the Muxing, add command line options,drop down and select 'clusters in meta seek' so you can fast forward and rewind after remuxing. I moved A_AC3 up above A_DTS and selected default track flag =Yes and choose ENG as language.i also changed Default track flag to NO on A_DTS.
