ServiiGo Exception
geniusit
Post Mon Oct 08, 2012 1:19 pm
ServiiGo Exception
Hello, I have serviio running on a Qnap Ts-419+
I'm trying to use Pro functionality on my pc http://.......:23424/mediabrowser/
and on my sasmung galaxy S3 and I have this error (with debug option log):
2012-10-08 12:57:22,878 DEBUG [MediaItemDAOImpl] Getting file of media item 2945
2012-10-08 12:57:22,879 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /*******************************.avi
2012-10-08 12:57:22,881 DEBUG [ProcessExecutor] Starting /opt/bin/ffmpeg -i /*******************************.avi -y -copyts -c:v flv -b:v 1000k -maxrate:v 1000k -bufsize:v 1000k -g 15 -c:a libmp3lame -b:a 128k -ar 44100 -ac 2 -map 0:0 -map 0:1 -sn -f flv /share/MD0_DATA/custom/tmp/Serviio/transcoding-temp-2945-flv_player-MEDIUM.stf
2012-10-08 12:57:23,328 WARN  [ProcessExecutor] Process /opt/bin/ffmpeg has a return code of 1! This is a possible error.
2012-10-08 12:57:23,328 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2012-10-08 12:57:30,528 WARN  [ServiioStatusService] IOException occured. Returning error code 500 to the REST layer. Message: Transcoded file '/share/MD0_DATA/custom/tmp/Serviio/transcoding-temp-2945-flv_player-MEDIUM.stf' cannot be found, FFmpeg execution probably failed
2012-10-08 12:57:30,528 DEBUG [ServiioStatusService] Detailed exception:
java.io.IOException: Transcoded file '/share/MD0_DATA/custom/tmp/Serviio/transcoding-temp-2945-flv_player-MEDIUM.stf' cannot be found, FFmpeg execution probably failed
   at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:45)
   at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:125)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:95)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:120)
   at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:84)
   at org.serviio.upnp.service.contentdirectory.rest.resources.server.CDSRetrieveMediaServerResource.deliver(CDSRetrieveMediaServerResource.java:65)
   at sun.reflect.GeneratedMethodAccessor14.invoke(Unknown Source)
   at java.lang.reflect.Method.invoke(Method.java:601)
   at org.restlet.resource.ServerResource.doHandle(ServerResource.java:449)
   at org.restlet.resource.ServerResource.get(ServerResource.java:645)
   at org.restlet.resource.ServerResource.doHandle(ServerResource.java:527)
   at org.restlet.resource.ServerResource.doNegotiatedHandle(ServerResource.java:587)
   at org.restlet.resource.ServerResource.doConditionalHandle(ServerResource.java:299)
   at org.serviio.restlet.AbstractProEditionServerResource.doConditionalHandle(AbstractProEditionServerResource.java:35)
   at org.serviio.upnp.service.contentdirectory.rest.resources.server.AbstractCDSServerResource.doConditionalHandle(AbstractCDSServerResource.java:50)
   at org.serviio.upnp.service.contentdirectory.rest.resources.server.AbstractRestrictedCDSServerResource.doConditionalHandle(AbstractRestrictedCDSServerResource.java:53)
   at org.restlet.resource.ServerResource.handle(ServerResource.java:846)
   at org.restlet.resource.Finder.handle(Finder.java:510)
   at org.restlet.routing.Filter.doHandle(Filter.java:156)
   at org.restlet.routing.Filter.handle(Filter.java:203)
   at org.restlet.routing.Router.doHandle(Router.java:497)
   at org.restlet.routing.Router.handle(Router.java:737)
   at org.restlet.engine.application.StatusFilter.doHandle(StatusFilter.java:151)
   at org.restlet.engine.ChainHelper.handle(ChainHelper.java:111)
   at org.restlet.engine.application.ApplicationHelper.handle(ApplicationHelper.java:72)
   at org.restlet.Application.handle(Application.java:388)
   at org.restlet.Component.handle(Component.java:388)
   at org.restlet.Server.handle(Server.java:488)
   at org.restlet.engine.http.connector.BaseServerHelper.handle(BaseServerHelper.java:158)
   at org.restlet.engine.http.connector.BaseServerHelper.handleInbound(BaseServerHelper.java:167)
   at org.restlet.engine.http.connector.BaseHelper.handleNextInbound(BaseHelper.java:418)
   at org.restlet.engine.http.connector.Connection.readMessages(Connection.java:695)
   at org.restlet.engine.http.connector.Controller$2.run(Controller.java:95)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
   at java.lang.Thread.run(Thread.java:722)
2012-10-08 12:57:32,602 DEBUG [CDSRetrieveMediaServerResource] Request for content delivery accepted
2012-10-08 12:57:32,602 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/94.165.89.93, Profile=Flash player'
2012-10-08 12:57:32,603 DEBUG [ResourceDeliveryProcessor] Request for resource 2945 and type 'MEDIA_ITEM' received
2012-10-08 12:57:32,603 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2945 (local)
2012-10-08 12:57:32,603 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2945)
2012-10-08 12:57:32,604 DEBUG [VideoDAOImpl] Reading a Video (id = 2945)
2012-10-08 12:57:32,607 DEBUG [VideoDeliveryEngine] Delivering item '2945' for client 'IPAddress=/94.165.89.93, Profile=Flash player'
2012-10-08 12:57:32,607 DEBUG [VideoDeliveryEngine] Delivering file '*******************************.avi' using transcoding
2012-10-08 12:57:32,608 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/94.165.89.93, Profile=Flash player'
2012-10-08 12:57:32,609 WARN  [ServiioStatusService] IOException occured. Returning error code 500 to the REST layer. Message: Transcoded file '/share/MD0_DATA/custom/tmp/Serviio/transcoding-temp-2945-flv_player-MEDIUM.stf' cannot be found, FFmpeg execution probably failed
2012-10-08 12:57:32,609 DEBUG [ServiioStatusService] Detailed exception:
2012-10-08 12:57:33,262 DEBUG [CDSRetrieveMediaServerResource] Request for content delivery accepted
2012-10-08 12:57:33,262 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/94.165.89.93, Profile=Flash player'
2012-10-08 12:57:33,263 DEBUG [ResourceDeliveryProcessor] Request for resource 2945 and type 'MEDIA_ITEM' received
2012-10-08 12:57:33,263 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2945 (local)
2012-10-08 12:57:33,263 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2945)
2012-10-08 12:57:33,264 DEBUG [VideoDAOImpl] Reading a Video (id = 2945)
2012-10-08 12:57:33,266 DEBUG [VideoDeliveryEngine] Delivering item '2945' for client 'IPAddress=/94.165.89.93, Profile=Flash player'
2012-10-08 12:57:33,267 DEBUG [VideoDeliveryEngine] Delivering file '*******************************.avi' using transcoding
2012-10-08 12:57:33,268 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/94.165.89.93, Profile=Flash player'
2012-10-08 12:57:33,269 WARN  [ServiioStatusService] IOException occured. Returning error code 500 to the REST layer. Message: Transcoded file '/share/MD0_DATA/custom/tmp/Serviio/transcoding-temp-2945-flv_player-MEDIUM.stf' cannot be found, FFmpeg execution probably failed
2012-10-08 12:57:33,269 DEBUG [ServiioStatusService] Detailed exception:
2012-10-08 12:57:36,128 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface bond0 (bond0) and address 192.168.0.18, timeout = 0
2012-10-08 12:57:36,130 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 1722b7b0-b57f-3b7d-adeb-c69358c48075
2012-10-08 12:57:38,108 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:40
2012-10-08 12:57:45,437 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-10-08 12:57:45,438 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
so I tried to execute from my nas:
and I got the error:
FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
  configuration: --enable-cross-compile --cross-prefix=/home/slug/optware/cs08q1armel/toolchain/arm-2008q1/bin/arm-none-linux-gnueabi- --arch=arm --disable-encoder=snow --disable-decoder=snow --enable-shared --disable-static --enable-gpl --enable-postproc --prefix=/opt
  libavutil version: 49.6.0
  libavcodec version: 51.54.0
  libavformat version: 52.13.0
  libavdevice version: 52.0.0
  built on Nov 23 2010 22:02:29, gcc: 4.2.3
Input #0, avi, from '/share/MD0_DATA/****************************.avi':
  Duration: 00:57:33.0, start: 0.000000, bitrate: 1713 kb/s
    Stream #0.0: Video: mpeg4, yuv420p, 720x304 [PAR 1:1 DAR 45:19], 25.00 tb(r)
    Stream #0.1: Audio: mp3, 48000 Hz, stereo, 128 kb/s
/opt/bin/ffmpeg: unrecognized option '-c:v'
So the option c:v isn't recognized, but I have ffmpeg update to last version, or I miss something?
Serviio 1.0.1 - Qnap TS-419P (8TB) - Samsung UE55C8000XP - Network cables Cat.7 for all House (no wifi)
Post Mon Oct 08, 2012 3:16 pm
Re: ServiiGo Exception
It may be the latest version in the package management system, but that ffmpeg version is over 4 years old and is too old. You will need to either compile it from source or see if anyone has supplied a more recent binary. Did you use http://pcloadletter.co.uk/2012/01/25/se ... o-package/ to install it? I would have a read around the nas subforum (viewforum.php?f=14), to see what other people are using.
geniusit
Post Tue Oct 09, 2012 8:56 am
will wrote: Did you use http://pcloadletter.co.uk/2012/01/25/se ... o-package/ to install it? I would have a read around the nas subforum (viewforum.php?f=14), to see what other people are using.
This post is for synology, I have a qnap :(
will wrote: I would have a read around the nas subforum (viewforum.php?f=14), to see what other people are using.
I can't download http://download.serviio.org/opensource/ffmpeg-26303.tar.gz isn't available anymore.
Post Tue Oct 09, 2012 9:14 am
Ah sorry, I didn't notice that.
Try http://download.serviio.org/opensource/ ... 863.tar.gz or use the latest version in the git repo.
geniusit
Post Tue Oct 09, 2012 12:05 pm
will wrote:Ah sorry, I didn't notice that.
I have error while compiling
./configure --arch=arm --enable-armv5te --prefix=/opt --extra-cflags='-I/opt/include' --extra-ldflags='-L/opt/lib' --enable-
static --disable-shared --disable-ffplay --disable-ffserver --enable-libmp3lame
License: LGPL version 2.1 or later
Creating config.mak and config.h...
cmp: config.h: No such file or directory
cmp: libavutil/avconfig.h: No such file or directory
is there any other package?
Post Tue Oct 09, 2012 12:36 pm
looks like you didn't unpack the source files correctly or the access rights are not right. The files it's complaining abut are part of the source tar ball.
geniusit
Post Tue Oct 09, 2012 1:30 pm
zip wrote:looks like you didn't unpack the source files correctly or the access rights are not right. The files it's complaining abut are part of the source tar ball.
All working, I re-downloaded and now it works
