My Documents not listing files
YoG
Post Wed Oct 10, 2012 6:57 pm
My Serviio (v1.0.1 free edition) is having trouble listing the contents of my My Documents folder. It will also not list any subfolder like My Pictures etc.
I installed Serviio on Windows 7 Ultimate.
It doesnt work with neither my Sammy TV U40C8700, Samsung Galaxy SII cellphone or Sony Playstation 3.
All other folders and videos work fine (thanks for coding this great DLNA app !! )
I have full admin rights. I also rechecked the folder for admin rights. Everything seems to look fine..
Is this a known bug?
Here are the contents of my debug file: (the snapshot is taken when i access the My Documents folder)
2012-10-10 20:44:50,421 DEBUG [WebServer] Incoming connection from /192.168.178.21:55068
2012-10-10 20:44:50,421 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.21
2012-10-10 20:44:50,422 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.178.21:
2012-10-10 20:44:50,422 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.21
2012-10-10 20:44:50,424 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-10 20:44:50,429 DEBUG [WebServer] Incoming connection from /192.168.178.21:40414
2012-10-10 20:44:50,429 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.21
2012-10-10 20:44:50,429 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.178.21:
2012-10-10 20:44:50,432 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 7) with parameters: objectID = V_F^FOL_R13, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-10-10 20:44:50,432 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-10-10 20:44:50,432 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-10-10 20:44:50,434 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-10 20:44:50,436 DEBUG [WebServer] Incoming connection from /192.168.178.21:59307
2012-10-10 20:44:50,436 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.21
2012-10-10 20:44:50,436 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.178.21:
2012-10-10 20:44:50,439 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-10 20:44:50,441 DEBUG [WebServer] Incoming connection from /192.168.178.21:58058
2012-10-10 20:44:50,442 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.21
2012-10-10 20:44:50,442 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.178.21:
2012-10-10 20:44:50,445 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 7) with parameters: objectID = V_F^FOL_R13, browseFlag = BrowseMetadata, filter = @parentID, startIndex = 0, count = 0, sortCriteria =
2012-10-10 20:44:50,445 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-10-10 20:44:50,445 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-10-10 20:44:50,447 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-10 20:44:52,033 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-10-10 20:44:52,033 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-10-10 20:44:52,033 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2012-10-10 20:44:52,033 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2012-10-10 20:44:52,033 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 3)
2012-10-10 20:44:52,034 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 4)
2012-10-10 20:44:52,034 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 5)
2012-10-10 20:44:52,038 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 6)
2012-10-10 20:44:52,041 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2012-10-10 20:44:52,045 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 8)
2012-10-10 20:44:52,052 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 9)
2012-10-10 20:44:52,059 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 10)
2012-10-10 20:44:52,063 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 11)
2012-10-10 20:44:52,063 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 12)
Post Thu Oct 11, 2012 2:41 pm
Re: My Documents not listing files
does the user that runs the service have access rights to the folders? http://www.serviio.org/component/conten ... e?id=21#q5
YoG
Post Thu Oct 11, 2012 4:06 pm
Yes, i have full access to the folder. I rechecked the security details of the folder properties.
I have no trouble browsing the folder and subfolder within Windows Explorer
Post Thu Oct 11, 2012 7:11 pm
yes, but does the user that runs the Serviio service the access? It's most likely not the same user you are using.
YoG
Post Sat Oct 13, 2012 10:09 am
I supplied the logon and password im using (it was using System to log on the service) but its still not working.
Something similar happened today when i added a subfolder (nested in a folder that was already functioning properly - not located in My Documents). It will also not list the contents..
Here is some portion of the debug log when i enter that folder
2012-10-13 12:05:23,673 DEBUG [WebServer] Incoming connection from /192.168.178.21:33289
2012-10-13 12:05:23,673 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.21
2012-10-13 12:05:23,673 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.178.21:
2012-10-13 12:05:23,676 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-13 12:05:23,681 DEBUG [WebServer] Incoming connection from /192.168.178.21:50281
2012-10-13 12:05:23,681 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.21
2012-10-13 12:05:23,681 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.178.21:
2012-10-13 12:05:23,684 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 7) with parameters: objectID = V_F^FOL_R20, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-10-13 12:05:23,684 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-10-13 12:05:23,684 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder null [No_Restriction]
2012-10-13 12:05:23,694 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [No_Restriction]
2012-10-13 12:05:23,695 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-10-13 12:05:23,697 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-13 12:05:23,700 DEBUG [WebServer] Incoming connection from /192.168.178.21:57784
2012-10-13 12:05:23,700 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.21
2012-10-13 12:05:23,700 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.178.21:
2012-10-13 12:05:23,703 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-13 12:05:23,707 DEBUG [WebServer] Incoming connection from /192.168.178.21:43557
2012-10-13 12:05:23,707 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.21
2012-10-13 12:05:23,707 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.178.21:
2012-10-13 12:05:23,709 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 7) with parameters: objectID = V_F^FOL_R20, browseFlag = BrowseMetadata, filter = @parentID, startIndex = 0, count = 0, sortCriteria =
2012-10-13 12:05:23,710 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-10-13 12:05:23,710 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 20)
2012-10-13 12:05:23,712 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [No_Restriction]
2012-10-13 12:05:23,713 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-10-13 12:05:23,715 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
..and here is some log when i start Serviio server
2012-10-13 11:58:44,916 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2012-10-13 11:58:44,920 INFO  [MediaServer] ------------------------------------------------------------------------
2012-10-13 11:58:44,921 INFO  [MediaServer] Serviio DLNA media streaming server v 1.0.1 (rev. 6dbf7c6e334f+)
2012-10-13 11:58:44,921 INFO  [MediaServer] Petr Nejedly 2009-2012
2012-10-13 11:58:44,921 INFO  [MediaServer] http://www.serviio.org
2012-10-13 11:58:44,921 INFO  [MediaServer] Java 1.6.0_21-Sun Microsystems Inc.
2012-10-13 11:58:44,921 INFO  [MediaServer] OS Windows 7 amd64 6.1
2012-10-13 11:58:44,921 INFO  [MediaServer] File encoding: windows-1252
2012-10-13 11:58:44,921 INFO  [MediaServer] Headless mode enabled: true
2012-10-13 11:58:44,922 INFO  [MediaServer] User home dir: C:\Users\YoG
2012-10-13 11:58:44,922 INFO  [MediaServer] Temp dir: C:\Users\YoG\AppData\Local\Temp\
2012-10-13 11:58:44,922 INFO  [MediaServer] ------------------------------------------------------------------------
2012-10-13 11:58:45,001 INFO  [WebServer] Socket buffer set to 65535 bytes
2012-10-13 11:58:45,002 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2012-10-13 11:58:45,024 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2012-10-13 11:58:45,024 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2012-10-13 11:58:45,033 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-10-13 11:58:45,039 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2012-10-13 11:58:45,878 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2012-10-13 11:58:45,878 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2012-10-13 11:58:45,879 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2012-10-13 11:58:45,879 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2012-10-13 11:58:45,880 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2012-10-13 11:58:45,880 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2012-10-13 11:58:45,881 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2012-10-13 11:58:45,881 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2012-10-13 11:58:45,882 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2012-10-13 11:58:45,882 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2012-10-13 11:58:45,883 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2012-10-13 11:58:45,883 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2012-10-13 11:58:45,902 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2012-10-13 11:58:46,170 INFO  [MediaServer] ------------------------------------------------------------------------
2012-10-13 11:58:46,170 INFO  [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2012-10-13 11:58:46,422 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2012-10-13 11:58:46,461 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2012-10-13 11:58:47,015 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-10-13 11:58:47,017 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2012-10-13 11:58:47,374 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-10-13 11:58:47,375 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2012-10-13 11:58:47,582 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-10-13 11:58:47,583 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2012-10-13 11:58:47,926 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-10-13 11:58:47,927 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2012-10-13 11:58:48,106 DEBUG [ServiioConsole] Initializing Serviio Console
2012-10-13 11:58:48,130 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2012-10-13 11:58:48,131 INFO  [ServiioConsole] Starting Serviio Console
2012-10-13 11:58:48,152 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-10-13 11:58:48,153 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2012-10-13 11:58:48,252 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2012-10-13 11:58:48,298 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-10-13 11:58:48,300 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2012-10-13 11:58:48,421 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-10-13 11:58:48,951 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2012-10-13 11:58:48,953 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2012-10-13 11:58:49,002 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-10-13 11:58:49,003 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2012-10-13 11:58:49,625 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2012-10-13 11:58:49,626 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2012-10-13 11:58:50,221 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-10-13 11:58:50,224 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2012-10-13 11:58:50,460 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-10-13 11:58:50,461 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2012-10-13 11:58:50,669 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-10-13 11:58:50,670 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2012-10-13 11:58:50,695 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-10-13 11:58:50,696 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2012-10-13 11:58:50,804 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-10-13 11:58:50,807 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2012-10-13 11:58:50,849 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-10-13 11:58:50,851 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2012-10-13 11:58:51,077 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-10-13 11:58:51,079 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2012-10-13 11:58:51,122 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2012-10-13 11:58:51,123 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2012-10-13 11:58:51,365 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2012-10-13 11:58:51,367 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2012-10-13 11:58:51,634 INFO  [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-10-13 11:58:51,636 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2012-10-13 11:58:51,731 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2012-10-13 11:58:51,732 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2012-10-13 11:58:51,776 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2012-10-13 11:58:51,778 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2012-10-13 11:58:52,290 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2012-10-13 11:58:52,292 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011
2012-10-13 11:58:52,353 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2012-10-13 11:58:52,354 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2012-10-13 11:58:52,412 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2012-10-13 11:58:52,414 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2012-10-13 11:58:52,500 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2012-10-13 11:58:52,501 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2012-10-13 11:58:52,594 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2012-10-13 11:58:52,628 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2012-10-13 11:58:52,631 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2012-10-13 11:58:52,878 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2012-10-13 11:58:52,879 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo
2012-10-13 11:58:53,106 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2012-10-13 11:58:53,468 INFO  [Device] Created UPnP Device with UUID: 12d319fc-a960-3e7f-a77e-ba4d14775b40, bound address: 192.168.178.20
2012-10-13 11:58:53,486 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-10-13 11:58:53,492 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2012-10-13 11:58:53,495 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2012-10-13 11:58:53,495 INFO  [UpdateChecker] Checking if a new version is available
2012-10-13 11:58:53,506 INFO  [PluginCompilerThread] Started looking for plugins
2012-10-13 11:58:53,511 DEBUG [PluginCompilerThread] Starting plugin RedTube.groovy compilation
2012-10-13 11:58:53,575 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-10-13 11:58:53,575 DEBUG [AbstractTranscodingDeliveryEngine] Deleting temporary transcoded files from: C:\Windows\TEMP\Serviio
2012-10-13 11:58:53,637 INFO  [WebServer] WebServer starting on port 8895
2012-10-13 11:58:53,642 DEBUG [DiscoveryManager] UPNP device 12d319fc-a960-3e7f-a77e-ba4d14775b40 (192.168.178.20) is available
2012-10-13 11:58:53,643 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-10-13 11:58:53,643 INFO  [EventDispatcher] Starting EventDispatcher
2012-10-13 11:58:53,647 INFO  [RendererSearchSender] Searching for Renderer devices
2012-10-13 11:58:53,650 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2012-10-13 11:58:53,652 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-10-13 11:58:53,668 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller) and address 192.168.178.20, timeout = 0
Post Tue Oct 16, 2012 8:39 pm
Does it anywhere in the log say something about starting to look for files in the provided documents? It might complain about not having access rights at that point.
