Samsung E5900 Series - Some AVIs crash Serviio
biggus
Post Fri Oct 12, 2012 4:26 am
Just bought a new E5900 to replace my old C5500. The C5500 was great, but it has the worst remote in history, and it suffered from random disconnects to Serviio, so I upgraded. The E5900 has a beautiful remote, but it will not play some avis, in fact, it won't play a LOT of avis. It 'crashes' the whole DLNA thing and the only fix is to stop the Serviio service, exit Serviio, restart the service then restart Serviio. Simply turning the player on and off won't fix the player not 'seeing' the DLNA server.
I am using Serviio 1.0.1 set to E5900 Profile CDE series on a 64 bit Windows 7 setup
Samsung's own All Share also crashes on the same avis that Serviio does. These files are fine on my PC of course, and when on a USB stick, play just fine. This says something I suspect, but I am not sure what. It does say that it is not the player's ability to decode the files itself, so I can only assume is it in the DLNA streaming that the fault lies?
I am not sure how to troubleshoot this, but am keen to do so. All other formats I have tried so far are fine. As I said, some or most avis are too, and I could understand if one avi was causing a problem, but it is a lot more than one, so something is amiss.
Every other problem I have encountered to date, I have been able to solve; fast forwarding of mkvs, some mkvs not playing at all, and so on, this avi one though has me stumped. I have gone through the whole reset, crash, reset process so many times trying to sus this, I think I better take a break and ask for help, before it is me who will be needing it!
ffmpeg output is...
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
g-config
[mpeg4 @ 013BC580] Invalid and inefficient vfw-avi packed B frames detected
Input #0, avi, from 'blah':
encoder : VirtualDubMod 1.5.10.2 (build 2540/release)
Duration: 01:44:40.94, start: 0.000000, bitrate: 3516 kb/s
Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv
420p, 1280x528 [SAR 1:1 DAR 80:33], 24 tbr, 24 tbn, 24.01 tbc
Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, 5.1(side), s16, 448
kb/s
Media info tells me...
Complete name :blah
Format : AVI
Format profile : OpenDML
File size : 2.57 GiB
Duration : 1h 44mn
Overall bit rate : 3 517 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDubMod build 2540/release
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 44mn
Bit rate : 3 058 Kbps
Width : 1 280 pixels
Height : 528 pixels
Display aspect ratio : 2.40:1
Frame rate : 24.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.189
Stream size : 2.24 GiB (87%)
Writing library : XviD 63
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 1h 44mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 335 MiB (13%)
Alignment : Split accross interleaves
Interleave, duration : 42 ms (1.00 video frame)
Interleave, preload duration : 500 ms
Any clues?
thanks,
Gus
Post Tue Oct 16, 2012 8:30 pm
Re: Samsung E5900 Series - Some AVIs crash Serviio
Might be caused by this in the file
The USB and DLNA players are different so the fact it plays via USB means nothing. Try to upgrade firmware on the TV.
biggus
Post Wed Oct 17, 2012 2:09 am
zip wrote:Might be caused by this in the file
I realise that USB and DLNA are different. I don't think that line is the reason, as the ffmpeg output below is from an avi file that works fine, and it contains the same line.
I have looked at several avis that will play, and several that will not, and I cannot find a common denominator. I upgraded the firmware as soon as I saw this problem, and nothing changed. As it happened, another upgrade came out last night, but the results are unchanged. I will attach a detailed log of the suspect file shortly as that may shed some light? ta
g-config
[mpeg4 @ 0036C620] Invalid and inefficient vfw-avi packed B frames detected
encoder : VirtualDubMod 1.5.10.2 (build 2542/release)
Duration: 00:44:52.08, start: 0.000000, bitrate: 1090 kb/s
420p, 624x352 [SAR 1:1 DAR 39:22], 25 tbr, 25 tbn, 25 tbc
Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16, 128 kb
/s
biggus
Post Wed Oct 17, 2012 5:04 am
I turned on debugging. Not sure where the relevent info starts, too much to paste the lot I imagine, so here's the end part of the debug log. I sure hope this helps, because I am at my wits end. I am basically not game to even try playing an avi file, since the mucking about needed to get it all running again is pretty annoying. Does the following help?
2012-10-17 15:49:35,059 DEBUG [WebServer] Incoming connection from /192.168.1.102:37109
2012-10-17 15:49:35,059 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,059 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=372-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,059 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,060 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,060 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,060 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,060 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,060 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,060 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,060 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,061 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,061 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,061 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 3509995148
2012-10-17 15:49:35,062 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,062 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 372-3509995519/3509995520,Content-Length: 3509995148,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,072 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,076 DEBUG [WebServer] Incoming connection from /192.168.1.102:37110
2012-10-17 15:49:35,076 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,076 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=3507495322-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,076 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,077 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,077 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,077 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,077 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,077 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,077 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,077 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,078 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,078 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,079 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 2500198
2012-10-17 15:49:35,079 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,079 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 3507495322-3509995519/3509995520,Content-Length: 2500198,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,102 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,105 DEBUG [WebServer] Incoming connection from /192.168.1.102:37111
2012-10-17 15:49:35,105 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,105 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=388-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,106 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,106 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,106 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,106 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,106 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,107 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,107 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,107 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,107 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,108 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,108 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 3509995132
2012-10-17 15:49:35,108 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,108 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 388-3509995519/3509995520,Content-Length: 3509995132,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,126 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,129 DEBUG [WebServer] Incoming connection from /192.168.1.102:37112
2012-10-17 15:49:35,129 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,129 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=3507560890-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,129 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,130 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,130 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,130 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,130 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,130 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,130 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,130 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,131 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,131 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,131 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 2434630
2012-10-17 15:49:35,131 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,132 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 3507560890-3509995519/3509995520,Content-Length: 2434630,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,158 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,162 DEBUG [WebServer] Incoming connection from /192.168.1.102:37113
2012-10-17 15:49:35,162 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,163 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=404-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,163 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,163 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,163 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,163 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,163 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,163 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,164 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,164 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,164 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,164 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,165 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,165 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 3509995116
2012-10-17 15:49:35,165 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,165 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 404-3509995519/3509995520,Content-Length: 3509995116,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,179 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,182 DEBUG [WebServer] Incoming connection from /192.168.1.102:37114
2012-10-17 15:49:35,182 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,183 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=3507626458-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,183 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,183 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,183 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,183 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,183 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,183 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,184 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,184 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,184 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,184 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,185 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,185 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 2369062
2012-10-17 15:49:35,185 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,185 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 3507626458-3509995519/3509995520,Content-Length: 2369062,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,207 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,210 DEBUG [WebServer] Incoming connection from /192.168.1.102:37115
2012-10-17 15:49:35,210 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,210 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=420-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,211 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,211 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,211 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,211 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,211 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,212 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,212 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,212 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,212 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,213 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,213 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 3509995100
2012-10-17 15:49:35,213 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,213 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 420-3509995519/3509995520,Content-Length: 3509995100,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,224 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,228 DEBUG [WebServer] Incoming connection from /192.168.1.102:37116
2012-10-17 15:49:35,228 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,228 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=3507692026-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,229 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,229 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,229 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,229 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,229 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,229 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,230 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,230 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,230 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,231 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,231 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 2303494
2012-10-17 15:49:35,231 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,231 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 3507692026-3509995519/3509995520,Content-Length: 2303494,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,259 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,264 DEBUG [WebServer] Incoming connection from /192.168.1.102:37117
2012-10-17 15:49:35,264 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,264 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=436-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,265 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,265 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,265 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,265 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,265 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,266 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,266 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,266 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,266 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,267 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,267 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 3509995084
2012-10-17 15:49:35,267 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,267 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 436-3509995519/3509995520,Content-Length: 3509995084,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,279 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,283 DEBUG [WebServer] Incoming connection from /192.168.1.102:37118
2012-10-17 15:49:35,283 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,283 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=3507757594-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,284 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,284 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,284 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,284 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,284 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,284 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,285 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,285 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,285 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,286 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,286 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 2237926
2012-10-17 15:49:35,286 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,286 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 3507757594-3509995519/3509995520,Content-Length: 2237926,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,315 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,318 DEBUG [WebServer] Incoming connection from /192.168.1.102:37119
2012-10-17 15:49:35,318 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,319 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=452-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,319 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,319 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,319 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,319 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,319 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,319 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,320 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,320 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,320 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,320 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,321 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,321 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 3509995068
2012-10-17 15:49:35,321 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,321 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 452-3509995519/3509995520,Content-Length: 3509995068,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,332 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,336 DEBUG [WebServer] Incoming connection from /192.168.1.102:37120
2012-10-17 15:49:35,336 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,336 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=3507823162-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,337 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,337 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,337 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,337 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,337 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,337 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,337 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,337 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,338 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,338 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,339 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 2172358
2012-10-17 15:49:35,339 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,339 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 3507823162-3509995519/3509995520,Content-Length: 2172358,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,366 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,370 DEBUG [WebServer] Incoming connection from /192.168.1.102:37121
2012-10-17 15:49:35,370 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,370 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=468-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,370 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,370 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,371 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,371 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,371 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,371 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,371 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,371 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,372 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,372 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,372 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 3509995052
2012-10-17 15:49:35,372 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,372 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 468-3509995519/3509995520,Content-Length: 3509995052,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,386 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,389 DEBUG [WebServer] Incoming connection from /192.168.1.102:37122
2012-10-17 15:49:35,389 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,390 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=3507888730-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,390 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,390 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,390 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,390 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,390 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,390 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,391 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,391 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,391 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,391 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,392 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,392 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 2106790
2012-10-17 15:49:35,392 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,392 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 3507888730-3509995519/3509995520,Content-Length: 2106790,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,419 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,422 DEBUG [WebServer] Incoming connection from /192.168.1.102:37123
2012-10-17 15:49:35,423 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,423 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=484-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,423 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,423 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,423 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,423 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,424 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,424 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,424 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,424 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,424 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,425 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,425 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 3509995036
2012-10-17 15:49:35,425 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,425 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 484-3509995519/3509995520,Content-Length: 3509995036,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,436 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,439 DEBUG [WebServer] Incoming connection from /192.168.1.102:37124
2012-10-17 15:49:35,439 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,440 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=3507954298-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,440 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,440 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,440 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,440 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,440 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,440 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,441 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,441 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,441 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,441 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,442 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,442 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 2041222
2012-10-17 15:49:35,442 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,442 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 3507954298-3509995519/3509995520,Content-Length: 2041222,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,464 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,467 DEBUG [WebServer] Incoming connection from /192.168.1.102:37125
2012-10-17 15:49:35,467 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,468 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=500-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,468 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,468 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,468 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,468 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,468 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,468 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,469 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,469 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,469 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,469 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,470 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,470 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 3509995020
2012-10-17 15:49:35,470 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,470 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 500-3509995519/3509995520,Content-Length: 3509995020,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,481 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,485 DEBUG [WebServer] Incoming connection from /192.168.1.102:37126
2012-10-17 15:49:35,485 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,485 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=3508019866-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,485 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,485 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,485 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,485 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,486 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,486 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,486 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,486 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,486 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,487 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,487 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 1975654
2012-10-17 15:49:35,487 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,487 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 3508019866-3509995519/3509995520,Content-Length: 1975654,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,509 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,513 DEBUG [WebServer] Incoming connection from /192.168.1.102:37127
2012-10-17 15:49:35,513 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,513 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=516-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,514 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,514 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,514 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,514 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,514 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,514 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,514 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,514 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,515 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,515 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,516 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 3509995004
2012-10-17 15:49:35,516 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,516 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 516-3509995519/3509995520,Content-Length: 3509995004,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,527 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,531 DEBUG [WebServer] Incoming connection from /192.168.1.102:37128
2012-10-17 15:49:35,531 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,531 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=3508085434-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,532 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,532 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,532 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,532 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,532 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,532 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,533 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,533 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,533 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,533 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,533 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 1910086
2012-10-17 15:49:35,534 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,534 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 3508085434-3509995519/3509995520,Content-Length: 1910086,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,554 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,557 DEBUG [WebServer] Incoming connection from /192.168.1.102:37129
2012-10-17 15:49:35,557 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,557 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=532-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,558 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,558 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,558 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,558 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,558 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,558 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,559 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,559 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,559 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,559 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,560 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,560 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 3509994988
2012-10-17 15:49:35,560 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,560 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 532-3509995519/3509995520,Content-Length: 3509994988,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,576 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,579 DEBUG [WebServer] Incoming connection from /192.168.1.102:37130
2012-10-17 15:49:35,579 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,580 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=3508151002-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,580 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,580 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,580 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,580 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,580 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,580 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,581 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,581 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,581 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,581 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,582 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,582 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 1844518
2012-10-17 15:49:35,582 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,582 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 3508151002-3509995519/3509995520,Content-Length: 1844518,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,604 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:35,607 DEBUG [WebServer] Incoming connection from /192.168.1.102:37131
2012-10-17 15:49:35,607 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2012-10-17 15:49:35,607 DEBUG [ResourceTransportRequestHandler] GET /resource/2436/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=548-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.103:8895]]
2012-10-17 15:49:35,608 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,608 DEBUG [ResourceDeliveryProcessor] Request for resource 2436 and type 'MEDIA_ITEM' received
2012-10-17 15:49:35,608 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2436 (local)
2012-10-17 15:49:35,608 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2436)
2012-10-17 15:49:35,608 DEBUG [VideoDAOImpl] Reading a Video (id = 2436)
2012-10-17 15:49:35,608 DEBUG [VideoDeliveryEngine] Delivering item '2436' for client 'IPAddress=/192.168.1.102, Profile=Samsung TV / player (C/D/E-series)'
2012-10-17 15:49:35,608 DEBUG [VideoDeliveryEngine] Delivering file 'AV2ak.avi' in native format
2012-10-17 15:49:35,609 DEBUG [MediaItemDAOImpl] Getting file of media item 2436
2012-10-17 15:49:35,609 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2436) as read
2012-10-17 15:49:35,609 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-17 15:49:35,610 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 3509994972
2012-10-17 15:49:35,610 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-17 15:49:35,610 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 548-3509995519/3509995520,Content-Length: 3509994972,Date: Wed, 17 Oct 2012 04:49:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-10-17 15:49:35,619 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-10-17 15:49:46,553 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Intel(R) 82574L Gigabit Network Connection) and address 192.168.1.103, timeout = 0
2012-10-17 15:49:46,553 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device d5d83c03-42e3-377d-afa7-8f5cd9997f2a
2012-10-17 15:49:48,353 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:51
2012-10-17 15:50:12,162 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
biggus
Post Wed Oct 17, 2012 6:01 am
After some more poking around, it seems that all the AVIs that crash DLNA connectivity are AC3 6 channel audio. AC3 2 channel plays just fine. Does this help at all?
Post Tue Oct 23, 2012 4:42 pm
Maybe. More likely it's caused by the way the AVI is encoded. from the log you can see it looks at the beginning of the file, then the end, then beginning, the end again... until it probably gives up. So might be something in the file structure.
biggus
Post Thu Oct 25, 2012 1:14 pm
hmm, oh well, looks like for now at least... we give up.
Thanks anwyay, Serviio is still the best :)
