serviio console automatically starting
adampg
Post Fri Oct 12, 2012 10:37 pm
All,
is there a way to stop the serviio console from automatically starting on boot, and if so, will this have any effect on using Serviio?
When I try to shutdown my computer, i always get a problem with the serviio process not being able to stop and I have to forcible click to end now before the computer reboots. This seems to go away if i manually exit the serviio console after it's started. given that the fix seems to be not having the console running, i'd rather skip the step of stopping every day and just not have it start.
I'm using windows xp sp3 if it makes a difference.
thanks for any help
grolschie
Post Fri Oct 12, 2012 11:48 pm
Re: serviio console automatically starting
Same problem for me. You can right-click the "Serviio Console" icon in the Startup folder on the Start menu (it's located in: Start -> All Programs -> Startup), and Delete it. It should then be in your recycle bin (which you can empty), and will no longer start-up automatically at login.
Users browsing this forum: Google [Bot] and 30 guests
