profile for philips 32pfl7605h/12
Luxx
Post Sun Oct 14, 2012 9:24 pm
Re: profile for philips 32pfl7605h/12
I downloaded your profiles, most seem to be working.
This one has less transcoding, so i choose to use this:http://forum.serviio.org/viewtopic.php?f=27&t=2231&start=10#p53350
for me it seems to be working perfect. Way less transecoding now, and it seems to play 'everything'. TNX!
Wingmann
Post Mon Oct 15, 2012 7:17 pm
Also you are transcoding all with DTS to mpeg2, it might be enough to remux the video into mpegts and only transcode the audio to ac3.
Thanks for your input.
How do I do as you suggest (remux+audio only transcoding)?
Would it be like this?
Please take a look at the whole profile
<Profile id="20" name="Philips" extendsProfileId="1">
      <Detection>
         <UPnPSearch>
            <FriendlyName>.*PHILIPS.*</FriendlyName>
         </UPnPSearch>
      </Detection>
      <MediaFormatProfiles>
         <MediaFormatProfile mime-type="video/avi" name="">AVI</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-matroska" name="">MATROSKA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">AVC_MP4_MP_SD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">AVC_MP4_MP_SD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">AVC_MP4_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">AVC_MP4_MP_HD_720p_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">AVC_MP4_MP_HD_1080i_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">AVC_MP4_HP_HD_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">AVC_MP4_LPCM</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">MPEG4_P2_MP4_ASP_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">MPEG4_P2_MP4_SP_L6_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">MPEG4_P2_MP4_NDSD</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">FLV</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/x-ms-wma" name="">WMA_BASE</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/x-ms-wma" name="">WMA_FULL</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-asf" name="">VC1_ASF_AP_L1_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-asf" name="">VC1_ASF_AP_L2_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-asf" name="">VC1_ASF_AP_L3_WMA</MediaFormatProfile>
      </MediaFormatProfiles>
         <Video targetContainer="mpeg" targetACodec="ac3" targetVCodec="mpeg2video">
            <Matches container="ogg" />
      <!-- if audio is DTS, audio must be transcoded -->
      <OnlineTranscoding>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384">
            <Matches container="mp4" />
            <Matches container="flv" />
            <Matches container="mp3"/>
            <Matches container="flv"/>
            <Matches container="asf"/>
         </Audio>
      </OnlineTranscoding>
Post Tue Oct 23, 2012 4:00 pm
Yes, that looks better. DTS -> AC3, video stays intact.
Do you know if this profile should work for all Philips TVs out there or if there are any notable differences in codec support?
Raven
Post Wed Oct 24, 2012 5:37 pm
Hi all,
i'm new to this forum.
Unfortunately i can say no. I have an 24PFL3507H and i can't see all my files : only .avi and .ts are show (no .mkv or .mp4 in the tree).
I've try different mine-type with no luck :-(
I'm newby with DLNA so i don't understand all.
Wingmann
Post Sun Dec 30, 2012 11:17 am
zip wrote:Do you know if this profile should work for all Philips TVs out there or if there are any notable differences in codec support?
It doesn't work with all models as they have different codec support, but I think it should do nicely with xxPFLxxx5 = 2010
xxPFLxxx6 = 2011 models.
welverin
Post Mon Jan 07, 2013 11:04 am
first for all : HAPPY NEW YEAR !!!
philips 2010 and 2011 version are much the same and they respond with the string "Windows2000/0.0 UPnP/1.0 PhilipsIntelSDK/1.4 DLNADOC/1.50"
the 2012 TV are different and respond with a new string, I do not know, then it will take a new dedicated profile
in the meantime could you formalize the profile here working for versions 2010 and 2011 so you do not need to edit it by hand every upgrade?
thanks
Leonardo
Philips 2010 7605
Serviio 1.4 on QNAP NAS 239 Pro II Fw 4.1
Post Thu Jan 17, 2013 4:57 pm
welverin wrote:first for all : HAPPY NEW YEAR !!!
thanks
Leonardo
Sure, can you point me in the direction of the final 2010/2011 profile? I assume it should replace the profile we have now?
welverin
Post Fri Jan 25, 2013 3:25 pm
i do not use transcoding, so my personal profile is limited to this :
- <Profile id="20" name="Philips" extendsProfileId="1">
- <Detection>
- <UPnPSearch>
  </UPnPSearch>
  </Detection>
- <MediaFormatProfiles>
for me the last profile reported here :
viewtopic.php?f=27&t=2231&start=20#p54573
is good for all 2010 and 2011 philips tv and include explacly the same command that i use
Leo
Philips 2010 7605
Wingmann
Post Wed Mar 06, 2013 7:21 pm
I'm glad to see that you have included my profile in the default profile.xml :D
welverin
Post Thu Mar 07, 2013 10:19 am
Wingmann wrote:I'm glad to see that you have included my profile in the default profile.xml :D
it's works
for me it is good enough to become default profile for philips tv, not 2012 model, but all other yes
Philips 2010 7605
marmotilla
Post Tue Aug 27, 2013 11:53 am
I've a Philips 40PFL7605H/12 TV and i'd like to run transcoding for most popular video formats (mov, avi, mpeg, wmv...) and be able to watch live streams (online transcoding formats). Anyone has a complete profile for a Philips 2010 i can use?
Thanks a lot!
welverin
Post Tue Sep 03, 2013 10:37 am
if you use latest version 1.3.1 you don't need custom profile for 7605 tv
why you need to transcode avi or mpeg ? tv render it natively
you need transcoding only for mov but i convert it to mp4 container and tv render it without problem
Philips 2010 7605
Previous
Return to Philips
