Hundreds of Devices & No Clear Button
See attached console and device Spy shots
zip wrote:You have to do it one by one. Refresh would get a new state, but only the devices that can be found by the UPnP Search method (and can be identified by their UUID). For other devices we just create a new renderer in the table when the IP address changes.
jhb50 wrote:No, I don't think that is correct. DHCP assigns an address and thats it. It would not try another. This problem does not occur on my home router nor has anyone else reported this problem.
every time a device connects to your network it is given a different ip address. Then as that device accesses the Serviio server the list grows and grows.
jhb50 wrote:every time a device connects to your network it is given a different ip address. Then as that device accesses the Serviio server the list grows and grows.
That statement is incorrect. Once the device is given an address, it will be reused the next time. The list does not grow and grow. Hence you suggestion that this is the cause is also incorrect.
