Help wanted for SMP-N100 and live streaming
serviio-buddy
Post Fri Mar 16, 2012 6:17 pm
Re: Help wanted for SMP-N100 and live streaming
For NASA HD Media Channel now showing robot basketball:
rtmp://flash84.ustream.tv:1935/ustreamVideo/10414700/ playpath=streams/live swfUrl=http://static-cdn1.ustream.tv/swf/live/viewer.rsl:96.swf swfVfy=1 live=1
It stuttered for about 1 minute at the beginning, but now it's smooth video and audio with the Sony SMP-N100 info saying 7-8 Mbps. When it shows just text on the screen, it was showing about 1-2 Mbps. Now it's showing International Space Station streaming at about 4-6 Mbps.
serviio-buddy
SONY SMP-N100 Media Player, HP PC: Vista 32/Ubuntu 11.10, Serviio 0.6.2, XBMC, VLC, ASUS eeePC Netbook: Vista 32, XBMC, SHARP Aquos BD-HP25U DLNA Blu-Ray Player
HowTo: Provide supported formats of a device | Record a new ticket on Bitbucket | Provide details of a video file that doesn't play | Turn on detailed logging
Larzendk
Post Fri Mar 16, 2012 6:46 pm
Well you are right, NASA HD plays ok, but when i try Ex. ESPN HD and MTV HD it is not got.
I guess i shall be happy with what i got now, at least i is not a pink screen
Thanks again for at super job fixing this. your the man :P
Best regards
Morten
serviio-buddy
Post Fri Mar 16, 2012 6:50 pm
Thank you again.
Enjoy!
serviio-buddy
Post Sat Mar 17, 2012 1:39 pm
Sorry, I did not really have time to help you, but it seems you make a good job.
I tested this online stream https://sites.google.com/site/serviiors ... annels.rss link with my
- SMP-N100
- BDP-S373
--> result pink images then devices reboot.
I try your modification and know seems good for the two devices !!
Good.
serviio-buddy
Post Sat Mar 17, 2012 1:42 pm
Thanks. :D
serviio-buddy
serviio-buddy
Post Sat Mar 17, 2012 3:33 pm
As far as the stuttering problem on some streams, I was just reading on another thread on here where a user suggested turning off the "Keep library automatically updated" to eliminate the problem. Not sure if this will help.
serviio-buddy
npuser
Post Sat Mar 24, 2012 12:29 am
Serviio-Buddy - good find and good fix. Thank you. :)
Confirmed -This patch also worked for bdp-bx57 (sony bluray - US) as well.
I do have stuttering and choppy issue but i can live with that. I am not sure if this thread http://forum.serviio.org/viewtopic.php?f=41&t=5625 has any lead to a fix for this choppy issue.
NPuser
serviio-buddy
Post Sat Mar 24, 2012 12:45 am
Thanks. Yes, it should work on most of the newer Sony BD / SMP models.
The thread you referred to has some clues as to what is causing this stuttering as it may have something to do with native rendering or hardware issues with the PC Serviio is running on.
serviio-buddy
patters
Post Wed Apr 11, 2012 10:01 pm
Hi serviio-buddy. I've been busy away from this stuff for quite a while so I've only just had a proper look at your live stream profile change. It's more of a workaround than a true fix, since your modification is transcoding all H.264 content in Flash Video containers (which will catch the majority of live-streamed content). And for Serviio users running on NAS realtime video transcoding is typically impossible, even using MPEG2. I guess it just so happens that the few live streams I have tried on my BDP (successfully) must have been streaming in M2TS. I'll check that.
The SMP/BD certainly ought to play the H.264 contained within these FLV streams, so there must be some reason why remuxing it to M2TS (as the default profile specifies) using FFmpeg is not quite working properly. My suspicion is that it's something along the lines of the mp4toannexb bitstream filter we have to use when remuxing H.264 in MP4 to M2TS. Some background info on Annex B here and the precise difference between the media subtypes of AVC1 and H264 (which are often conflated):
http://wiki.multimedia.cx/index.php?title=H.264
http://msdn.microsoft.com/en-us/library/windows/desktop/dd757808(v=vs.85).aspx
http://www.mail-archive.com/ffmpeg-issues@lscube.org/msg00985.html
I'll do some research on that when I have some time, perhaps tomorrow. There's got to be a way round this...
patters
Post Thu Apr 12, 2012 10:38 am
Hmm. I can see from your previous detailed log output that the mp4toannexb option is already being used:
ffmpeg.exe -i "rtmp://s7.webport.tv/live/z050227.stream pageUrl=http://www.tvsector.com/ swfVfy=0 live=1" -y -async 1 -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec ac3 -ab 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts
npuser
Post Fri Apr 13, 2012 2:45 am
@patters - Before serviio-buddy's work around, i was only able to get online streams to work by adding maxVBitrate="1000" within online transcoding section of my renderer's profile. With that Video Bit rate, the picture quality was really bad but at least it did not cause Sony BDP-bx57 to crash (pink screen). I am not sure if this info will give you any clues as to what is going on.
<OnlineTranscoding>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384" forceInheritance="true">
            <Matches container="rtp"/>
            <Matches container="rtsp"/>
            <Matches container="applehttp"/>
         <Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video" aBitrate="192" maxVBitrate="1000">
            <Matches container="mp4" vCodec="h264" profile="baseline" ftypNotIn="isom"/>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384">
            <Matches container="asf"/> <!-- to support mms:// streams -->
         <Audio targetContainer="mp3" aBitrate="384" forceInheritance="true">
            <Matches container="flv"/>
         </Audio>
      </OnlineTranscoding>
I still remember a strange behavior exhibited by my bdp-bx57, when i set the maxVBrate to between 1100 to 2000 - the unit locked up with a red screen, between 2000 to 10000 - a purple screen, from 10000 upto 17000 - a pink screen.
Once i got serviio-buddy's work around which worked for me, i never looked back since.
thanks
NPuser
bdp-bx57.txt
(9.85 KiB) Downloaded 736 times
serviio-buddy
Post Sun Apr 15, 2012 4:45 am
Patters, thanks for looking into this. The pink screen syndrome was usually occurring on M2TS live streams. The MPEG live streams always played. Whene I commented out the line in the Sony BD /SMP profile (as shown in a previous post), it started playing the M2TS live streams also.
serviio-buddy
robertsearle
Post Mon Oct 22, 2012 5:05 am
I have a similar problem playing files wirelessly. I thought the problem was the bitrate over the wireless network. It might be the smp-n100 can't handle that fast a stream. I changed the profile to always re-encoding the mkv files and down grade the video stream bit rate and set it to 720p. viewtopic.php?t=6591&p=52709#p52709
hope it helps
Previous
