Not supported video codec for .MTS
MisterSanders
Post Wed Oct 17, 2012 4:22 pm
I have a Sony camera which is giving me .MTS files, and I'm getting a file "not supported video codec" on my Samsung tv when trying to play them. Has anyone else had this problem and found a solution? I'm running Ubuntu 12.4.1, Serviio 1.0.1, and trying to watch on a Samsung D6050. I've posted the file info results from ffmpeg and MediaInfo below, respectively:
Input #0, mpegts, from '083a.MTS':
  Duration: 00:04:52.30, start: 1.000011, bitrate: 26544 kb/s
  Program 1
    Stream #0.0[0x1011]: Video: h264 (High), yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 59.96 fps, 59.94 tbr, 90k tbn, 119.88 tbc
    Stream #0.1[0x1100]: Audio: ac3, 48000 Hz, stereo, s16, 256 kb/s
    Stream #0.2[0x1200]: Data: [144][0][0][0] / 0x0090
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 925 MiB
Duration                                 : 4mn 52s
Overall bit rate                         : 26.5 Mbps
Maximum Overall bit rate                 : 28.0 Mbps
Menu ID                                  : 1 (0x1)
Format profile                           : High@L4.2
Format settings, ReFrames                : 2 frames
Format settings, GOP                     : M=1, N=15
Codec ID                                 : 27
Duration                                 : 4mn 52s
Bit rate                                 : 25.2 Mbps
Maximum bit rate                         : 26.0 Mbps
Height                                   : 1 080 pixels
Frame rate                               : 59.940 fps
Bits/(Pixel*Frame)                       : 0.203
Stream size                              : 879 MiB (95%)
Menu ID                                  : 1 (0x1)
Codec ID                                 : 129
Duration                                 : 4mn 52s
Bit rate                                 : 256 Kbps
Stream size                              : 8.92 MiB (1%)
Text
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Duration                                 : 4mn 51s
Post Mon Oct 22, 2012 9:40 pm
Re: Not supported video codec for .MTS
It's got quite high bitrate, the TV might be rejecting it because of that.
MisterSanders
Post Wed Oct 24, 2012 3:54 am
Thanks zip for answering. It's at least good to know there isn't an easy fix keeping the files as is that I hadn't acted on.
