Intro.. Pro Version and DTS
busterdan
Post Sun Oct 28, 2012 8:59 pm
Hi everyone, I'm new here...
I have been using Serviio Free for a few months and have been quite impressed with it... for starters the service seems to be more robust than PS3 Media Server that I also use - meaning it takes less effort to get devices to be seen.
I generally use Serviio with my PS3, am early generation Samsung 3D Plasma but also a number of Android devices. I have only just tried the pro version and was impressed how well video streamed. So all things considered I like Serviio.
I do have a few questions....
Are there any plans to release version 2 anytime soon... I only ask because I noticed that the pro licence will only cover the current version 1.xxx so should I wait? I also tried the ServiiGo and Droid Android apps... both very simple but very good.
Also I have searched but couldn't specifically find any mention of LPCM output to bypass DTS audio to my Onkyo Amp via HDMI. I haven't been able to output DTS using Serviio, I have seen it mentioned that Serviio can not do this, but it is a method that PS3MS uses successfully.
Any tips will be most welcome...
Cheers
Post Sun Oct 28, 2012 11:38 pm
Re: Intro.. Pro Version and DTS
2.x will not be out any time soon, if ever ;-)
Bypass DTS is not possible currently.
busterdan
Post Mon Oct 29, 2012 12:25 am
Thanks for the reply... good to know about the Pro version. Hopefully DTS bypass will feature at some point as it is a feature I use quite often on PS3MS.
Struggling to get Tunein radio plugin to work, I can see the folder but no stations are listed :(
I'll work it out though.... eventually.
Return to General discussion
