Override an audio channel per movie
robertsearle
Post Sun Oct 21, 2012 7:53 pm
On a per-movie basis, I would like to assign the movie to always use audio channel X instead of the default audio channel. Can this be done by manually changing the database entry?
Post Sun Oct 21, 2012 8:55 pm
Re: Override an audio channel per movie
Hi, not really.
robertsearle
Post Wed Oct 24, 2012 6:23 pm
So its coming in the next release.... hint, hint!
WildRushSykes
Post Wed Oct 24, 2012 6:27 pm
Can you not just change the default audio track in the source file itself? I do it using mkvmerge :D
robertsearle
Post Sat Nov 03, 2012 6:13 pm
WildRushSykes wrote:Can you not just change the default audio track in the source file itself? I do it using mkvmerge :D
Great idea! How do I tell it use track 5 or make track 5 the new track1?
Post Sat Nov 03, 2012 7:58 pm
Open your file with mkvmerg tool, change the track order then remux the file.
Return to Feature requests
