Flac on ES 7000
I have transcoding switched off (the tv does not require it as proven by other dlna servers).
I have used the generic dlna profile and the samsung c/d/e profile.
flacs play when transcoding is enabled.
thanks for help.
*edit*
ok, so i have read about profiles and how to edit them.
I have moved back to "generic dlna profile" as this=0 transcoding. The samsung C/D/E profile had some transcoding enabled, which the es does not require*. Anyone done an es profile for a 2012 tv.
Is there more to getting a file to play than the tv supporting the format/stream...do i need to modify the profile to 'present' the file to the tv in a certain way. The tv can see the file.
incidently the tv has an info button, which describes the format of the file on the dlna service and the tv knows/detects the audio format.
*the reason why i am so sure that transcoding is not required is that when i test with ps3 media server with transcoding manually switched off for flac,mkv,avi,m2ts,mp3 (ie everything), all files play and the cpu does not get burdened (hence my belief there is no transcoding going on). flacs also play natively from usb.
Serviio has better metadata support and podcast support and resume support and tvshow distinction from movies and view by album artist....so i would love to crack this one.
maybe as a short term workaround i could create a profile that inherited everything from profile 1, save transcoding flacs....but it does not yet make sense to me yet why his is necessary.
*edit 2*
Have turned on debug logging ..but waiting for library scan to complete before restart..
in the mean time think these were the info logs from the offending time
- Code:
2012-11-04 22:21:12,918 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller) and address 192.168.4.53, timeout = 0
2012-11-04 22:26:42,323 WARN [ResourceDeliveryProcessor] Invalid request, sending back 500 error
org.serviio.dlna.UnsupportedDLNAMediaFileFormatException: No media description available for required version: FLAC
at org.serviio.delivery.resource.AbstractDeliveryEngine.findMediaInfoForFileProfile(AbstractDeliveryEngine.java:254)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedMediaInfoForVersion(AbstractTranscodingDeliveryEngine.java:141)
at org.serviio.delivery.resource.AbstractDeliveryEngine.getMediaInfoForMediaItem(AbstractDeliveryEngine.java:109)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResourceInfo(MediaResourceRetrievalStrategy.java:148)
at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:91)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:79)
at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:191)
2012-11-04 22:26:43,838 WARN [ResourceDeliveryProcessor] Invalid request, sending back 500 error
