Best way to create a video play list
• Page 1 of 1
The Harry Potter series has a bunch of movies. I think it starts with Chamber of secrets and ends with Deadly Hallows Part 1 and 2. What is the simplest way to create a Harry Potter play list with all the different movies? Is there a simple text file I can create?
Re: Best way to create a video play list
you can create a .m3u playlist, like you would for music. You'll then find it in Videos/Playlist category.
Petr
Help translate Serviio
zip wrote:you can create a .m3u playlist, like you would for music. You'll then find it in Videos/Playlist category.
- Mike
Playlists wont work for online stuff yet. But there is a plugin for that.
Petr
Or use the LiveFeeds plugin.
jhb50 wrote:Or use the LiveFeeds plugin.
- Mike
Error "Provided URL is not valid" for local URLs
zip wrote:Playlists wont work for online stuff yet. But there is a plugin for that.
Local URL passes unit test in LiveFeeds plugin but raises the error in Serviio:
- Mike
To be able to store online resources (live and podcasts) as simple XML local files i have converted LiveFeeds plugin into XmlFeed plugin.
it can handle remote and local urls like this http://file:////C:/apps/Serviio/dev/myFeeds/xmlFeed_MyLiveTV.xml
- Mike
• Page 1 of 1
Users browsing this forum: Google [Bot] and 4 guests
