Plugin for "Index of" site
stit
Post Thu Nov 22, 2012 8:43 pm
Hi all,
i would like to stream the files which are on my root server.
But FTP web ressources are not working so i tried http:// links to the files. But to add every file manually is very complicated.
Is there any way to let serviio scan a http "Index of" for files, or to add an ftp: directory?
If not it would be the only way to generate a rss feed from all files with php am i right?
By the way which kind of "web ressources" are possible?
rss and rtmp, mms etc. are clear but what links are "web ressources"?
Maybe someone can code such a plugin?
I try it on my own, but i am not very good in coding.
Thanks so far.
Greeting.
stit
stit
Post Thu Nov 22, 2012 9:52 pm
Re: Plugin for "Index of" site
I wrote a php script which scans the "Index of" page for files.
My goal is to generate a RSS file which includes the directlinks to the files, but maybe ist would be easier if serviio scans for the files?
I don't know which is the best way..
<?php
function ListFiles($dir)
    if($dh = opendir($dir))
        $files = Array();
        $inner_files = Array();
        while($file = readdir($dh))
            if($file != "." && $file != ".." && $file[0] != '.')
                if(is_dir($dir . "/" . $file))
                    $inner_files = ListFiles($dir . "/" . $file);
                    if(is_array($inner_files)) $files = array_merge($files, $inner_files);
            else
                    array_push($files, $dir . "/" . $file);
        closedir($dh);
        return $files;
print_r(ListFiles('/home/pa'));
greetings
stit
EDIT:
I know generated a .php file which is a rss feed which entrys are the directlinks to the files and i add this url to serviio "ATOM/Rss" section:
http://user:password@www.dafsafa.sd/files.php
But it is not shown on my TV !?
Why ?
Return to Plugin requests
