FF broken in new version
Stevehaley
Post Mon Nov 26, 2012 3:12 am
I have been using an Ipad running the sitecom DLNA program to stream to my Samsung D8000. All worked fine until I updated to the latest version 1,0,1 from 0.6.2 at which point the ability to skip forward and back through the film using the time elapsed slider bar was broken. Any chance of an early fix? Have retrograded to previous version and all is well again. This affected both avi and mkv files.
ipad app is here https://itunes.apple.com/us/app/imediac ... ?ls=1&mt=8
Stephen
csholmq
Post Mon Nov 26, 2012 9:14 am
Re: FF broken in new version
Post detailed log.
How did you draw the conclusion that FFmpeg is broken if you retrograded to 0.6.2? It sounds more like a transcoding profile-thingy.
Post Mon Nov 26, 2012 3:11 pm
Stevehaley
Post Mon Nov 26, 2012 7:06 pm
Sorry i didnt mention ffmpeg at all merely said that ff (fast forword) wasnt working.
Not sure I understand the thread re mkvmerge. I don't use mkvmerge, I am merely playing mkv files I was given. These files play fine on the old version of serviio but not the new. Also the issue as I said was with all files not just mkv.
Works fine in all versions 0.6.2 and before.
Rgds
Stephen
Post Mon Nov 26, 2012 10:45 pm
comment out the lines mentioned in the thread from the profile
Users browsing this forum: Google [Bot] and 13 guests
