Which Java is working best? Ubuntu
• Page 1 of 1
Which linux is running best right now on Ubuntu server 12.04? I have install oracle 6 and it does great. The problem with it is the media browser doesnt work. I installed 7u9 and the lag is awful, audio breaks up on me. Is there any one that works good for this?
Re: Which Java is working best? Ubuntu
Why MB doesn't work? It should work with 6.
Petr
Help translate Serviio
The problem is with Oracle 6 is the Media browser always has a 404 java error when you look at it with browser.
if you post some detailed logs with the error we might help. It should work.
Petr
I checked the detailed logs and its working with java 6. here is what it shows me with the browser.
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<result>
<httpCode>404</httpCode>
</result>
<result>
</result>
is there an error in serviio.log?
Petr
Nope, It shows to be processing everything. This happened before to me, I had to upgrade to java 7 for media browser to work.
• Page 1 of 1
