Can't get Serviio to work on Sony KDL-40HX750
Brinkytinky
Post Sat Dec 08, 2012 3:58 pm
So I browsed through the topics but can't seem to find any specific solution.
It's a new 2012 model from Netherlands. I use MacOS and installed it without problems:
Added some folders to my library:
And started checking my TV if it could see the server and the folders that should come with it.
Settings -> Network -> Home Network Setup -> Server Display Settings -> Options -> Update Server List -> Servers Cannot Be Recognized
I'm connected to a network, I can use all the features of the Internet Content etc.
Post Sat Dec 08, 2012 7:18 pm
Re: Can't get Serviio to work on Sony KDL-40HX750
Make sure that TCP port 8895 and UDP 1900 are open in your firewall.
http://www.serviio.org/component/conten ... e?id=21#q1
Brinkytinky
Post Sun Dec 09, 2012 2:40 am
Ok so .. I'm a total noob but what I found out was: I don't have the firewall on, so I'm guessing that TCP port and UDP are open?
Also, how do I find out what the IP address of my Mac is on which I'm running Serviio? Because as soon as I copy my Ethernet IP address (192.168.1.xxx) into the "Bound IP address" box, the two little green round bulbs in the Render Profile list go to red which seems like I'm only making things worse?
Brinkytinky
Post Sun Dec 09, 2012 8:58 pm
Brinkytinky
Post Mon Dec 10, 2012 12:42 pm
Anybody? :(
Post Mon Dec 10, 2012 1:28 pm
You use two subnet IP address, you have to use the same subnet (192.168.1.x vs 10.0.2.x ).
Suggest to use 192.168.1.x and fix all devices IP address (or fix IP address on router setting)
Post Sun Dec 16, 2012 6:06 pm
any news ?
