[SOLVED] I can't see movies, but I see songs
roccop
Post Tue Dec 18, 2012 12:47 pm
when I connect my Sony TV KDL-40HX855 I can see my mediaserver and I can access to my photos and music, but when I try to browse my third path for movies directory is empty.
I configured 3 different paths for music, photos and movies... I already force and refresh lybrary but nothing changed...
I'm using Linux Mint 14 - 64 bit.
Can you help me please?
Post Tue Dec 18, 2012 1:54 pm
Re: I can't see movies, but I see songs
What is your ffmpeg version ? Try to use this one : http://www.serviio.org/download
This release includes FFmpeg compiled using this source code, libRTMP 2.4 compiled using this source code and Lame MP3 Encoder (v. 3.98) compiled using this source code.
If that not help, could you provide information about your movies format ? (see signature links)
roccop
Post Tue Dec 18, 2012 2:14 pm
How can I check this info?
I'm pretty sure inside my movies directory I have different video formats, but if you tell me one format I can try to check it...
Post Tue Dec 18, 2012 3:48 pm
To compile linux ffmpeg version : http://wiki.serviio.org/doku.php?id=build_ffmpeg_linux
roccop
Post Wed Dec 19, 2012 8:29 am
Yesterday I followed this page: http://wiki.serviio.org/doku.php?id=build_ffmpeg_linux
then I run:
sudo apt-get remove ffmpeg x264 libx264-dev libvpx-dev librtmp0 librtmp-dev
Well after the end my system "lost" about 500Mb and a lot of applications has been removed! (Chrome, LibreOffice, Virtualbox, Torrent, etc...).
WHY?!?!?
I know it was also my fault because I didn't care of warning message: "It will be remove the following packages for a total size of 500Mb [...] "
but why running that command I lost my applications??
What's going wrong? :roll:
roccop
Post Fri Dec 21, 2012 11:49 pm
I reinstalled my Linux Mint :evil:
I followed again this page: http://wiki.serviio.org/doku.php?id=build_ffmpeg_linux but now after this step
I answered NO when system ask me to remove 500Mb of software!
Well now everything is installed and I can watch my movies on my Sony TV.
Please note
Following the procedure I had one error and I need to set my /tmp directory to a different path:
(section)
Build and Install FFmpeg
export TMPDIR=~/tmp-ffmpeg
mkdir $TMPDIR
./configure --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx --enable-librtmp --enable-libxvid
make
sudo checkinstall --pkgname=ffmpeg --pkgversion="7:$(date +%Y%m%d%H%M)-git" --backup=no --deldoc=yes --fstrans=no --default
rm -rf $TMPDIR
export TMPDIR=
I suggest you to add this warning on the procedure.
Regards,
Rocco
