Use 32bit java instead of 64bit?
alan93
Post Mon Dec 17, 2012 5:03 pm
Is there a way to get serviio to use C:\Program Files (x86)\Java\jre7 when serviio is here:
C:\Program Files\Serviio
I am on win764bit but need to have java32 only.
Post Mon Dec 17, 2012 11:32 pm
Re: Use 32bit java instead of 64bit?
You can use serviio.bat instead of the service.
alan93
Post Fri Dec 21, 2012 3:28 pm
zip wrote:You can use serviio.bat instead of the service.
Ok but I have to run both serviio.bat and serviio-console.bat right?
How do I get this to start this way automatically on boot?
Post Fri Dec 21, 2012 3:37 pm
put serviio.bat into the Startup folder
alan93
Post Fri Dec 21, 2012 9:43 pm
ok thanks and you forgot to mention that i needed to change the Java_home path in system variables to 32bit java but i figured that out.
alan93
Post Fri Dec 28, 2012 6:55 pm
new problem it seems that in order for the console to show you need to run serviio-console.bat after serviio.bat.
So i guess there is no way to do this on boot?
Can the two bat files be combined?
Post Sat Dec 29, 2012 12:17 am
I assume they could, create a new .bat to run the two with a pause between them
alan93
Post Fri Jan 04, 2013 2:54 am
Not sure how to do that, are there any examples on here?
khurram23
Post Fri Jan 04, 2013 8:16 pm
Try something like this:
Save this file as something.bat in the same folder as serviio.bat and add it to startup. You should manually test it first.
Sleep 30 means wait for 30 seconds before executing next command.
@echo off
call serviio.bat
sleep 30
call serviio-console.bat
Dropbox - Get 500MB bonus space.
My pre-compiled FFMPEG, X264 packages for Linux/Ubuntu - Dropbox
alan93
Post Sat Jan 05, 2013 7:49 pm
Thanks , i understand all the commands just didn't know the exact syntax.
