[SOLVED] No sound on some files MKV/AVC/AAC
Romfrosk
Post Fri Dec 21, 2012 12:32 pm
I'm using the Bravia 2011 profile on my KDL-65HX920 and i've been playing all files ok for some time now.
Serviio v 1.1
FFMPEG: FFmpeg git-26c531c 64-bit Static (25.11-2012)
I've gotten to some files which has no sound at all:
It seems that my TV wont play AAC files.
Is this a known problem for Sony TV/Profiles?
Tried Downmixing and keep original, both produce no sound.
No Sound:
Example 1:
Unique ID                                : 274396254103900942618723505227811297449 (0xCE6ECBD66D310405209A10E604FC98A9)
Complete name                            : Z:\Serier\Workaholics\Season 3\Workaholics - S03E01 - The Business Trip - 720p WEB-DL.mkv
File size                                : 661 MiB
Duration                                 : 21mn 23s
Overall bit rate                         : 4 322 Kbps
Movie name                               : Workaholics.S03E01.The.Business.Trip.720p.WEB.DL.AAC2.0.H.264.TiGHTBH.mkv 351
Encoded date                             : UTC 2012-05-30 16:10:36
Writing application                      : mkvmerge v5.5.0 ('Healer') built on Apr 25 2012 20:53:43
Writing library                          : libebml v1.2.2 + libmatroska v1.3.0
Format profile                           : High@L3.1
Format settings, CABAC                   : No
Format settings, ReFrames                : 2 frames
Duration                                 : 21mn 23s
Width                                    : 1 274 pixels
Codec ID                                 : A_AAC
Duration                                 : 21mn 23s
Example 2:
Unique ID                                : 240109626355700818730228522416543167209 (0xB4A36E9330133388A722F5C677ACF2E9)
Complete name                            : Z:\Serier\Homeland\Season 2\Homeland - S02E03 - State of Independence - 1080p WEB-DL.mkv
File size                                : 1.96 GiB
Duration                                 : 54mn 12s
Overall bit rate                         : 5 179 Kbps
Encoded date                             : UTC 2012-10-27 06:30:29
Writing application                      : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep  2 2012 15:37:04
Writing library                          : libebml v1.2.3 + libmatroska v1.3.0
Format profile                           : High@L4.0
Duration                                 : 54mn 12s
Height                                   : 1 080 pixels
Codec ID                                 : A_AAC
Duration                                 : 54mn 12s
Examples with Audio
Example 1
Complete name                            : Z:\Serier\Workaholics\Season 2\Workaholics - S02E01 - Heist School - 720p BluRay.mkv
File size                                : 889 MiB
Duration                                 : 21mn 38s
Overall bit rate                         : 5 744 Kbps
Writing application                      : mkvmerge v4.1.1 ('Bouncin' Back') built on Jul  3 2010 22:54:08
Writing library                          : libebml v1.0.0 + libmatroska v1.0
Format settings, ReFrames                : 5 frames
Duration                                 : 21mn 38s
Bit rate                                 : 5 106 Kbps
Bits/(Pixel*Frame)                       : 0.231
Stream size                              : 772 MiB (87%)
Writing library                          : x264 core 124 r2197 69a0443
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5106 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Duration                                 : 21mn 38s
Bit rate                                 : 640 Kbps
Stream size                              : 99.1 MiB (11%)
Menu
00:00:00.000                             : en:00:00:00.000
00:01:28.088                             : en:00:01:28.088
00:06:44.571                             : en:00:06:44.571
00:11:38.907                             : en:00:11:38.907
00:16:07.675                             : en:00:16:07.675
00:20:39.155                             : en:00:20:39.155
Example 2
Unique ID                                : 224373980246510470470910745611180956773 (0xA8CCDB52A51576618B5329A79487DC65)
Complete name                            : Z:\Serier\Homeland\Season 2\Homeland - S02E02 - Beirut is Back - 1080p WEB-DL.mkv
File size                                : 1.89 GiB
Duration                                 : 48mn 20s
Overall bit rate                         : 5 608 Kbps
Encoded date                             : UTC 2012-10-22 07:47:30
Duration                                 : 48mn 20s
Bit rate                                 : 5 112 Kbps
Bits/(Pixel*Frame)                       : 0.103
Stream size                              : 1.73 GiB (91%)
Duration                                 : 48mn 20s
Bit rate                                 : 384 Kbps
Stream size                              : 133 MiB (7%)
blokey
Post Sun Dec 23, 2012 2:06 am
Re: No sound on some files.
Try the sony BDP profile or the sony 2010 one and see if it makes any difference
Post Sun Dec 23, 2012 8:48 am
What is your model region ( US, UK, EU)?
You can try to edit profiles.xml file and change the ""Sony Bravia TV (2012)"" profile like this:
On second element:
         <!-- Remux containers with h264 video + AC3/AAC audio to MPEG-TS stream without transcoding -->
         <Video targetContainer="mpegts" forceInheritance="true">
            <Matches container="avi" vCodec="h264" aCodec="ac3" />
            <!--Matches container="avi" vCodec="h264" aCodec="aac" /-->
            <Matches container="matroska" vCodec="h264" aCodec="ac3" />
            <!--Matches container="matroska" vCodec="h264" aCodec="aac" /-->
            <Matches container="flv" vCodec="h264" aCodec="ac3" />
            <!--Matches container="flv" vCodec="h264" aCodec="aac" /-->
Save, restart serviio service or reboot.
Romfrosk
Post Sun Dec 23, 2012 1:41 pm
Thanks Illico. That worked perfectly.
At least with the files i posted.
I'll get back if there are any other problems. :D
Now i can watch the last season of workaholics :D
Users browsing this forum: Google [Bot] and 20 guests
